Name | Synopsis | Description | Options | Operands | Examples | Exit Status
ping-connection-pool [--terse={true|false}][ --echo={true|false} ] [ --interactive={true|false} ] [ --host host] [--port port] [--secure| -s ] [ --user admin_user] [--passwordfile filename] [--help] pool_name
This command tests if a connection pool is usable for both JDBC connection pools and connector connection pools. For example, if you create a new JDBC connection pool for an application that is expected to be deployed later, the JDBC pool is tested with this command before deploying the application.
A JDBC connection pool or a connector connection pool with authentication can be created. You can either use a -property option to specify user, password, or other connection information using the command line, or specify the connection information in the xml descriptor file.
Before pinging a connection pool, you must create the connection pool with authentication and ensure that the enterprise server or database is started.
This command is supported in remote mode only.
Indicates that any output data must be very concise, typically avoiding human-friendly sentences and favoring well-formatted data for consumption by a script. Default is false.
If set to true, the command-line statement is echoed on the standard output. Default is false.
If set to true (default), only the required password options are prompted.
The machine name where the domain administration server is running. The default value is localhost.
The HTTP port or HTTPS port for administration. This port is the port in the URL that you specify in your web browser to manage the domain, for example, http://localhost:4848.
The default port number for administration is 4848.
If set to true, uses SSL/TLS to communicate with the domain administration server.
The default is false.
The user name of the authorized administrative user of the domain administration server.
If you have authenticated to a domain by using the asadmin login command, you need not specify the --user option for subsequent operations on the domain.
Specifies the name, including the full path, of a file that contains the password entries in a specific format.
The entry for a password must have the AS_ADMIN_ prefix followed by the password name in uppercase letters. For example, to specify the password for the domain administration server, use an entry with the following format:
AS_ADMIN_PASSWORD=password
In this example, password is the actual administrator password.
The following other passwords can also be specified:
AS_ADMIN_MAPPEDPASSWORD
AS_ADMIN_USERPASSWORD
AS_ADMIN_ALIASPASSWORD
All remote commands must specify the administration password to authenticate to the domain administration server. The password can be specified by one of the following means:
Through the --passwordfile option
Through the asadmin login command
Interactively at the command prompt
The asadmin login command can be used only to specify the administration password. For other passwords that remote commands require, use the --passwordfile option or specify them at the command prompt.
After authenticating to a domain by using the asadmin login command, you need not specify the administration password through the --passwordfile option for subsequent operations on the domain. However, only the AS_ADMIN_PASSWORD option is not required. You still must provide the other passwords, for example, AS_ADMIN_USERPASSWORD, when required by individual commands, such as update-file-user.
For security reasons, a password that is specified as an environment variable is not read by the asadmin command.
The default value for AS_ADMIN_MASTERPASSWORD is changeit.
Displays the help text for the command.
This option is deprecated.
asadmin> ping-connection-pool --user admin1 --passwordfile pwordfile Command ping-connection-pool executed successfully |
Where: asadmin is the command prompt and sampleConnectionPool is the name of the connection pool to ping.
