This procedure describes how to install the SUNWscdev package and set the compiler and linker options for data service development.
Become superuser or assume a role that provides solaris.cluster.modify RBAC authorization.
Change directory to the CD-ROM directory that you want.
# cd cd-rom-directory |
Install the SUNWscdev package in the current directory.
# pkgadd -d . SUNWscdev |
In the makefile, specify compiler and linker options that identify the include and library files for your data service code.
Specify the -I option to identify the Sun Cluster header files, the -L option to specify the compile-time library search path on the development system, and the -R option to specify the library search path to the runtime linker in the cluster.
# Makefile for sample data service ... -I /usr/cluster/include -L /usr/cluster/lib -R /usr/cluster/lib ...
