The configuration restrictions in this section apply only to Sun Cluster HA for SWIFTAlliance Gateway.
If your data service configuration does not conform to these restrictions, the data service configuration might not be supported.
For restrictions that apply to all data services, see Sun Cluster 3.2 Release Notes for Solaris OS.
Sun Cluster HA for SWIFTAlliance Gateway supports SWIFTAlliance Gateway version 5.5 or higher.
You can only install the SWIFTNet Link and the SWIFTAlliance Gateway software on a failover file system. If Websphere MQ client software is needed for the operation of SWIFTAlliance Gateway, install Websphere MQ client software on the local file system on each node and in the same path. The default path is /opt/mqm.
You cannot configure Sun Cluster HA for SWIFTAlliance Gateway as a scalable data service.
