Use this procedure to configure the Sun Cluster HA for SWIFTAlliance Gateway data service as a failover service.
Become superuser on one of the nodes in the cluster that is the host for SWIFTAlliance Gateway.
Register the SUNW.gds resource type.
# clresourcetype register SUNW.gds |
Register the SUNW.HAStoragePlus resource type.
# clresourcetype register SUNW.HAStoragePlus |
Create the failover resource group.
# clresourcegroup create sag-rg |
Create a resource for the Sun Cluster Disk Storage.
# clreseource create -gsag-rg \ -t SUNW.HAStoragePlus \ -x FilesystemMountPoints=/swift sag-ds-rs |
Specifies that the resource that you are creating is named sag-ds-rs.
Specifies that the resource is to be added to the SWIFTAlliance Gateway resource group.
Specifies a list of valid mount points for the file system. For more information, see the SUNW.HAStoragePlus(5) man page.
Create a resource for the Sun Cluster logical hostname.
# clreslogicalhost create -g sag-rg \ -h gatewayhostname sag-lh-rs |
Enable the failover resource that contains the Sun Cluster Disk Storage and the Logical hostname resources.
# clresourcegroup online sag-rg |
Create a resource for SWIFTAlliance Gateway.
Change the user name, password, and path variable in the /opt/SUNWscsag/etc/settings.sh file.
For information about this file, see Configuration Files and Registration Script.
Change the group name, resource name and, if necessary, the port number in the /opt/SUNWscsag/util/sag_config file.
Run the registration script to register the data service and application.
For information about this script, see Configuration Files and Registration Script.
# /opt/SUNWscsag/util/sag_register |
Enable the SWIFTAlliance Gateway resource.
# clresource enable sag-resource-rs |
Go to Verifying the Sun Cluster HA for SWIFTAlliance Gateway Installation and Configuration.
