Name | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
create-audit-module --classname classname [--help] [--property(name=value)[:name=value]*] audit_module_name
The create-audit-module subcommand adds the named audit module for the Java class that implements the audit capabilities. Audit modules collect and store information on incoming requests (from, for example, servlets and EJB components) and outgoing responses.
This subcommand is supported in remote mode only.
The name of the Java class that implements this audit module. If not specified, this option defaults to com.sun.enterprise.security.Audit.
Displays the help text for the subcommand.
Optional keyword-value pairs that specify additional properties for the audit module.
Audit module properties that are defined by GlassFish Server are as follows:
If true, specifies that the audit module is loaded and called by the GlassFish Server audit library at audit points.
Other available properties are determined by the implementation of the audit module.
Do not specify this option. This option is retained for compatibility with other releases. If you specify this option, a syntax error does not occur. Instead, the subcommand runs successfully and the option is silently ignored.
asadmin> create-audit-module --classname com.sun.appserv.auditmodule --property defaultuser=admin:Password=admin sampleAuditModule Command create-audit-module executed successfully |
