Sun Gathering Debug Data for Sun Java System Directory Server 5
ProcedureTo Collect Required Debug Data For a Crashed Directory Server Process
This procedure describes what data to collect when a Directory Server process unexpectedly dies.
  1. Try to restart Directory Server and record the results.
  2. Collect statistics about the system running Directory Server.
    Solaris OS
    ps -aux | grep server-root
    vmstat 5 5
    iostat -x
    top
    uptime
    HP-UX
    vmstat 5 5
    iostat -x
    top
    sar
    Red Hat
    vmstat 5 5
    top
    uptime
    sar
    Windows
    Get the process ID using the tlist.exe command, then get process details using the same command.
    win-dbg-root\tlist.exe pid
  3. Collect swap information.
    Solaris OS
    swap -l
    HP-UX
    swapinfo
    Red Hat
    free
    Windows
    Already provided in C:\report.txt.
  4. Collect system logs.
    Solaris OS
    /var/adm/messages
    /var/log/syslog
    HP-UX
    /var/adm/syslog/syslog.log
    Red Hat
    /var/log/messages
    /var/log/syslog
    Windows
    Retrieve the Event log files.
    From the Control Panel, open the Event Viewer. Select the event log. Then select Action > Save log file as to save the log.
  5. Collect core files.
    For instructions on preparing your system to produce core files or crash dumps in the event of a crash, see 1.6 Configuring the Operating System to Generate Core Files.
    1. For each core file on Solaris OS, collect output from the following commands.
      cd server-root/bin/slapd/server
      file core-file
      pstack core-file
      pmap core-file
      pflags core-file
    2. For at least one of the core files on Solaris OS, collect output from the pkg_app script.
      ./pkg_app.ksh pid core-file
      Here, pid is the server process ID number. See To Run the pkg_app Script for instructions on using pkg_app.
