Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
RMON Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
RMON Overview
Protocol Description
Topology Example
Configuring RMON
Enabling the RMON Module
Enable the RMON Module
Disable the RMON Module
Configuring the Ethernet Statistics Group
Enable the Ethernet Statistics Group
Disable the Ethernet Statistics Group
Configuring the Ethernet History Group
Enable the Ethernet History Group
Disable the Ethernet History Group
Configuring Events
Create an Event
Disable an Event
Configuring Alarms
Create an Alarm
Disable an Alarm
You also can configure history collection over port 2.
  1. Enter Global Configuration mode for the interface.
    SEFOS# configure terminal
    SEFOS(config)# interface extreme-ethernet 0/15
  2. Enable the history group on the specified interface (port 15).
    SEFOS(config-if)# rmon collection history 1 buckets 25 interval 30
    SEFOS(config-if)# end
  3. Verify the entries.
    SEFOS# show rmon history 1
    RMON is enabled
    Entry 1 is active,  and owned by myTest
     Monitors ifEntry.1.15 every 30 second(s)
     Requested # of time intervals, ie buckets, is 25,
     Granted # of time intervals, ie buckets, is 25,
      Sample 1 began measuring at Jul  9 03:51:07 2010
       Received 3124 octets, 31 packets,
       0 broadcast and 0 multicast packets,
       0 undersized and 0 oversized packets,
       0 fragments and 0 jabbers,
       0 CRC alignment errors and 0 collisions,
       # of dropped packet events is 0
       Network utilization is estimated at 0
      Sample 2 began measuring at Jul  9 03:51:37 2010
      Sample 3 began measuring at Jul  9 03:52:07 2010
