Confirming Switch Specifications
Preparing to Install the Switch
Install the Switch in the Rack
Finish the Switch Installation
Connecting to the Service Processor
Oracle ILOM Features Not Supported
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From CLI (SER MGT)
Log Into Oracle ILOM Web (NET MGT)
Log Into Oracle ILOM CLI (NET MGT)
Log Into Oracle ILOM CLI (SER MGT)
SER MGT Port Configuration Parameters
Configure Network Management From Web
Configure Network Management From CLI (NET MGT)
Configuring SEFOS User Privileges
Change a SEFOS User Privilege Level
Check Switch Status (Oracle ILOM)
The SEFOS# prompt appears. For example:
-> cd /SYS/fs_cli/ cd: Connecting to Fabric Switch CLI as user root SEFOS#
You can now configure SEFOS. Refer to the Sun Network 10GbE Switch 72p Software Configuration Guide for the Sun Ethernet Fabric Operating System for those instructions.
