Skip Navigation Links
Exit Print View
Sun Network 10GbE Switch 72p
User’s Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Understanding the Switch
Switch Overview
Front Panel Components
Rear Panel Components
Confirming Switch Specifications
Physical Specifications
Electrical Specifications
Environmental Specifications
Acoustic Noise Emissions
Installing the Switch
Preparing to Install the Switch
Verify Shipping Kit Contents
Antistatic Precautions
Install the Switch in the Rack
Connecting Management Cables
Management Cable Requirements
NET MGT Port
Connect the NET MGT Cable
SER MGT Port
Connect the SER MGT Cable
Powering On the Switch
Power Cord Specifications
Power On the Switch
Connecting Ethernet Cables
QSFP Cables
SFP+ Cables
Splitter Cables
Ethernet Cable Cautions
Connect Ethernet Cables
Finish the Switch Installation
Administering the Switch
Connecting to the Service Processor
Oracle ILOM Overview
Oracle ILOM Features Not Supported
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From CLI (SER MGT)
Log Into Oracle ILOM Web (NET MGT)
Log Into Oracle ILOM CLI (NET MGT)
Log Into Oracle ILOM CLI (SER MGT)
SER MGT Port Configuration Parameters
Configure Network Management From Web
Configure Network Management From CLI (NET MGT)
Log Out of ILOM
Configuring SEFOS User Privileges
Create a SEFOS User
Change a SEFOS User Privilege Level
Update the Firmware
Connecting to SEFOS
SEFOS Overview
Connect to SEFOS
Disconnect From SEFOS
Servicing the Switch
Troubleshooting the Switch
Identifying LEDs
Sensors Overview
Check Switch Status (LEDs)
Check Switch Status (Oracle ILOM)
Component Sensor Targets
Motherboard Sensor Targets
Tools Needed for Service
Replaceable Components
Servicing Power Supplies
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Remove a Fan
Install a Fan
Servicing Ethernet Cables
Remove an Ethernet Cable
Install an Ethernet Cable
Servicing the Battery
Remove the Battery
Install the Battery
Glossary
Index
Airflow can be established with two different configurations, depending on where you choose to locate the I/O connectors (front of the switch).
  1. Verify that the rack meets the switch specifications.
    See Confirming Switch Specifications.
  2. If installed, open the rack doors.
  3. Assemble the front mounting brackets.
    Perform Steps a-d for each bracket.
    1. Slide the attachment bracket over the long rail, so that the tab on the bracket is opposite the flange of the rail.
      The flat end of the tab is toward the flange, the open end of the tab is toward the rear of the rail.
      image:Figure shows the attachement bracket sliding over the long rail
    2. Place the attachment plate on the flange side of the long rail, opposite the attachment bracket.
    3. Use two screws to sandwich the bracket and plate to the rail, in the most forward position.
      image:Figure shows the bracket and plate sandwiching to the rail
    4. Using a No. 2 Phillips screwdriver, tighten the two screws.
  4. Attach the front mounting brackets to the rack using two captive nuts and two screws for each bracket.
    Tighten the screws securely.
    image:Figure shows the front brackets being installed
  5. Carefully lift the switch and slide it into the rack, from the rear forward.
    Ensure that the ends of the long rails slide into the C-shaped brackets at the front of the switch chassis.
    image:Figure shows the switch sliding into the rack
  6. Mount the rear of the switch chassis to the rack posts with two captive nuts and two screws at each side.
    image:Figure shows the switch being secured to the rack
  7. Install the cable management bracket to the tabs of the attachment brackets.
    Tightening the thumbscrews on each side of the cable management bracket.
    image:Figure shows the cable management bracket being installed to the switch
  8. Install the cable management bracket cover.
    image:Figure shows the cable management bracket cover being installed
  9. Tighten the thumbscrews on each side of the cover.
    image:Figure shows the thumbscrews being tightened
  10. Attach the management cables.
    See Connecting Management Cables.
Related Information
