Skip Navigation Links
Exit Print View
man pages section 9: DDI and DKI Driver Entry Points     Oracle Solaris 11 Express 11/10
search filter icon
search icon
Document Information
Preface
Introduction
Driver Entry Points
aread(9E)
attach(9E)
audio_engine_channels(9E)
audio_engine_chinfo(9E)
audio_engine_close(9E)
audio_engine_count(9E)
audio_engine_format(9E)
audio_engine_open(9E)
audio_engine_playahead(9E)
audio_engine_qlen(9E)
audio_engine_rate(9E)
audio_engine_start(9E)
audio_engine_stop(9E)
audio_engine_sync(9E)
awrite(9E)
chpoll(9E)
close(9E)
csx_event_handler(9E)
detach(9E)
devmap(9E)
devmap_access(9E)
devmap_contextmgt(9E)
devmap_dup(9E)
devmap_map(9E)
devmap_unmap(9E)
dump(9E)
_fini(9E)
getinfo(9E)
gld(9E)
gldm_get_stats(9E)
gldm_intr(9E)
gldm_ioctl(9E)
gldm_reset(9E)
gldm_send(9E)
gldm_set_mac_addr(9E)
gldm_set_multicast(9E)
gldm_set_promiscuous(9E)
gldm_start(9E)
gldm_stop(9E)
identify(9E)
_info(9E)
_init(9E)
ioctl(9E)
ks_snapshot(9E)
ks_update(9E)
mac(9E)
mc_getcapab(9E)
mc_getprop(9E)
mc_getstat(9E)
mc_ioctl(9E)
mc_multicst(9E)
mc_propinfo(9E)
mc_setpromisc(9E)
mc_setprop(9E)
mc_start(9E)
mc_stop(9E)
mc_tx(9E)
mc_unicst(9E)
mmap(9E)
open(9E)
power(9E)
print(9E)
probe(9E)
prop_op(9E)
put(9E)
quiesce(9E)
read(9E)
segmap(9E)
srv(9E)
strategy(9E)
tran_abort(9E)
tran_bus_reset(9E)
tran_destroy_pkt(9E)
tran_dmafree(9E)
tran_getcap(9E)
tran_init_pkt(9E)
tran_pkt_constructor(9E)
tran_pkt_destructor(9E)
tran_quiesce(9E)
tran_reset(9E)
tran_reset_notify(9E)
tran_setcap(9E)
tran_setup_pkt(9E)
tran_start(9E)
tran_sync_pkt(9E)
tran_teardown_pkt(9E)
tran_tgt_free(9E)
tran_tgt_init(9E)
tran_tgt_probe(9E)
tran_unquiesce(9E)
write(9E)
audio_engine_rate
- return the sample rate of an audio engine
Synopsis
#include <sys/audio/audio_driver.h>
int prefix_rate(void *state);
Parameters
state
pointer to driver supplied soft state
Interface Level
Solaris DDI specific (Solaris DDI)
Description
The audio_engine_rate() function is called by the framework to determine the sample rate of the engine, represented in Hz.
Return Values
The audio_engine_rate() function returns the sample rate of the engine expressed in Hz.
Context
This function may be called from user or interrupt context.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
See Also
attributes(5), audio(7D), audio_engine_ops(9S)
