Skip Navigation Links
Exit Print View
Programming Interfaces Guide     Oracle Solaris 11 Express 11/10
search filter icon
search icon
Document Information
1.  Memory and CPU Management
2.  Remote Shared Memory API for Solaris Clusters
3.  Session Description Protocol API
4.  Process Scheduler
5.  Locality Group APIs
6.  Input/Output Interfaces
7.  Interprocess Communication
8.  Socket Interfaces
SunOS 4 Binary Compatibility
Overview of Sockets
Socket Libraries
Socket Types
Interface Sets
Socket Basics
Socket Creation
Binding Local Names
Connection Establishment
Connection Errors
Data Transfer
Closing Sockets
Connecting Stream Sockets
Input/Output Multiplexing
Datagram Sockets
Standard Routines
Host and Service Names
Host Names - hostent
Network Names - netent
Protocol Names - protoent
Service Names - servent
Other Routines
Client-Server Programs
Sockets and Servers
Sockets and Clients
Connectionless Servers
Advanced Socket Topics
Out-of-Band Data
Nonblocking Sockets
Asynchronous Socket I/O
Interrupt-Driven Socket I/O
Signals and Process Group ID
Selecting Specific Protocols
Address Binding
Socket Options
inetd Daemon
Broadcasting and Determining Network Configuration
Using Multicast
Sending IPv4 Multicast Datagrams
Receiving IPv4 Multicast Datagrams
Sending IPv6 Multicast Datagrams
Receiving IPv6 Multicast Datagrams
Stream Control Transmission Protocol
SCTP Stack Implementation
SCTP Socket Interfaces
Branched-off Association
Code Examples of SCTP Use
9.  Programming With XTI and TLI
10.  Packet Filtering Hooks
11.  Transport Selection and Name-to-Address Mapping
12.  Real-time Programming and Administration
13.  The Solaris ABI and ABI Tools
A.  UNIX Domain Sockets
Overview of Sockets
Sockets have been an integral part of SunOS releases since 1981. A socket is an endpoint of communication to which a name can be bound. A socket has a type and an associated process. Sockets were designed to implement the client-server model for interprocess communication where:
Sockets make network protocols available while behaving like UNIX files. Applications create sockets as sockets are needed. Sockets work with the close(2), read(2), write(2), ioctl(2), and fcntl(2) interfaces. The operating system differentiates between the file descriptors for files and the file descriptors for sockets.
Socket Libraries
The socket interface routines are in a library that must be linked with the application. The library is contained in /usr/lib with the rest of the system service libraries. Use for dynamic linking.
Socket Types
Socket types define the communication properties that are visible to a user. The Internet family sockets provide access to the TCP/IP transport protocols. The Internet family is identified by the value AF_INET6, for sockets that can communicate over both IPv6 and IPv4. The value AF_INET is also supported for source compatibility with old applications and for raw access to IPv4.
The SunOS environment supports four types of sockets:
See Selecting Specific Protocols for further information.
Interface Sets
The SunOS 5.10 platform provides two sets of socket interfaces. The BSD socket interfaces are provided and, since SunOS version 5.7, the XNS 5 (UNIX03) socket interfaces are also provided. The XNS 5 interfaces differ slightly from the BSD interfaces.
The XNS 5 socket interfaces are documented in the following man pages:
The traditional BSD Socket behavior is documented in the corresponding 3N man pages. In addition, the following new interfaces have been added to section 3N:
See the standards(5) man page for information on building applications that use the XNS 5 (UNIX03) socket interface.
