Skip Navigation Links
Exit Print View
Programming Interfaces Guide     Oracle Solaris 11 Express 11/10
search filter icon
search icon
Document Information
1.  Memory and CPU Management
2.  Remote Shared Memory API for Solaris Clusters
3.  Session Description Protocol API
4.  Process Scheduler
5.  Locality Group APIs
6.  Input/Output Interfaces
7.  Interprocess Communication
8.  Socket Interfaces
SunOS 4 Binary Compatibility
Overview of Sockets
Socket Libraries
Socket Types
Interface Sets
Socket Basics
Socket Creation
Binding Local Names
Connection Establishment
Connection Errors
Data Transfer
Closing Sockets
Connecting Stream Sockets
Input/Output Multiplexing
Datagram Sockets
Standard Routines
Host and Service Names
Host Names - hostent
Network Names - netent
Protocol Names - protoent
Service Names - servent
Other Routines
Client-Server Programs
Sockets and Servers
Sockets and Clients
Connectionless Servers
Advanced Socket Topics
Out-of-Band Data
Nonblocking Sockets
Asynchronous Socket I/O
Interrupt-Driven Socket I/O
Signals and Process Group ID
Selecting Specific Protocols
Address Binding
Socket Options
inetd Daemon
Broadcasting and Determining Network Configuration
Using Multicast
Sending IPv4 Multicast Datagrams
Receiving IPv4 Multicast Datagrams
Sending IPv6 Multicast Datagrams
Receiving IPv6 Multicast Datagrams
Stream Control Transmission Protocol
SCTP Stack Implementation
SCTP Socket Interfaces
Branched-off Association
Code Examples of SCTP Use
9.  Programming With XTI and TLI
10.  Packet Filtering Hooks
11.  Transport Selection and Name-to-Address Mapping
12.  Real-time Programming and Administration
13.  The Solaris ABI and ABI Tools
A.  UNIX Domain Sockets
The most common form of distributed application is the client-server model. In this scheme, client processes request services from a server process.
An alternate scheme is a service server that can eliminate dormant server processes. An example is inetd(1M), the Internet service daemon. inetd(1M) listens at a variety of ports, determined at startup by reading a configuration file. When a connection is requested on an inetd(1M) serviced port, inetd(1M) spawns the appropriate server to serve the client. Clients are unaware that an intermediary has played any part in the connection. inetd(1M) is described in more detail in inetd Daemon.
Sockets and Servers
Most servers are accessed at well-known Internet port numbers or UNIX family names. The service rlogin is an example of a well-known UNIX family name. The main loop of a remote login server is shown in Example 8-7.
The server dissociates from the controlling terminal of its invoker unless the server is operating in DEBUG mode.
(void) close(0);
(void) close(1);
(void) close(2);
(void) open("/", O_RDONLY);
(void) dup2(0, 1);
(void) dup2(0, 2);
Dissociating prevents the server from receiving signals from the process group of the controlling terminal. After a server has dissociated from the controlling terminal, the server cannot send reports of errors to the terminal. The dissociated server must log errors with syslog(3C).
The server gets its service definition by calling getaddrinfo(3SOCKET).
bzero(&hints, sizeof (hints));
hints.ai_flags = AI_ALL|AI_ADDRCONFIG;
hints.ai_socktype = SOCK_STREAM;
error = getaddrinfo(NULL, "rlogin", &hints, &api);
The result, which is returned in api, contains the Internet port at which the program listens for service requests. Some standard port numbers are defined in /usr/include/netinet/in.h.
The server then creates a socket, and listens for service requests. The bind(3SOCKET) routine ensures that the server listens at the expected location. Because the remote login server listens at a restricted port number, the server runs as superuser. The main body of the server is the following loop.
Example 8-7 Server Main Loop
/* Wait for a connection request. */
for (;;) {
    faddrlen = sizeof (faddr);
    new_sock = accept(sock, (struct sockaddr *)api->ai_addr,
    if (new_sock == -1) {
        if (errno != EINTR && errno != ECONNABORTED) {
            perror("rlogind: accept");
    if (fork() == 0) {
        close (sock);
        doit (new_sock, &faddr);
    close (new_sock);
accept(3SOCKET) blocks messages until a client requests service. Furthermore, accept(3SOCKET) returns a failure indication if accept is interrupted by a signal, such as SIGCHLD. The return value from accept(3SOCKET) is checked, and an error is logged with syslog(3C), if an error occurs.
The server then forks a child process, and invokes the main body of the remote login protocol processing. The socket used by the parent to queue connection requests is closed in the child. The socket created by accept(3SOCKET) is closed in the parent. The address of the client is passed to the server application's doit() routine, which authenticates the client.
Sockets and Clients
This section describes the steps taken by a client process. As in the server, the first step is to locate the service definition for a remote login.
error = getaddrinfo(hostname, servicename, &hints, &res);
if (error != 0) {
    (void) fprintf(stderr, "getaddrinfo: %s for host %s service %s\n",
        gai_strerror(error), hostname, servicename);
    return (-1);
getaddrinfo(3SOCKET) returns the head of a list of addresses in res. The desired address is found by creating a socket and trying to connect to each address returned in the list until one works.
for (aip = res; aip != NULL; aip = aip->ai_next) {
     * Open socket.  The address type depends on what
     * getaddrinfo() gave us.
    sock = socket(aip->ai_family, aip->ai_socktype,
    if (sock == -1) {
        return (-1);
    /* Connect to the host. */
    if (connect(sock, aip->ai_addr, aip->ai_addrlen) == -1) {
        (void) close(sock);
        sock = -1;
The socket has been created and has been connected to the desired service. The connect(3SOCKET) routine implicitly binds sock, because sock is unbound.
Some services use datagram sockets. The rwho(1) service provides status information on hosts that are connected to a local area network. Avoid running in.rwhod(1M) because in.rwho causes heavy network traffic. The rwho service broadcasts information to all hosts connected to a particular network. The rwho service is an example of datagram socket use.
A user on a host that is running the rwho(1) server can get the current status of another host with ruptime(1). Typical output is illustrated in the following example.
Example 8-8 Output of ruptime(1) Program
itchy up 9:45, 5 users, load 1.15, 1.39, 1.31
scratchy up 2+12:04, 8 users, load 4.67, 5.13, 4.59
click up 10:10, 0 users, load 0.27, 0.15, 0.14
clack up 2+06:28, 9 users, load 1.04, 1.20, 1.65
ezekiel up 25+09:48, 0 users, load 1.49, 1.43, 1.41
dandy 5+00:05, 0 users, load 1.51, 1.54, 1.56
peninsula down 0:24
wood down 17:04
carpediem down 16:09
chances up 2+15:57, 3 users, load 1.52, 1.81, 1.86
Status information is periodically broadcast by the rwho(1) server processes on each host. The server process also receives the status information. The server also updates a database. This database is interpreted for the status of each host. Servers operate autonomously, coupled only by the local network and its broadcast capabilities.
Use of broadcast is fairly inefficient because broadcast generates a lot of net traffic. Unless the service is used widely and frequently, the expense of periodic broadcasts outweighs the simplicity.
The following example shows a simplified version of the rwho(1) server. The sample code receives status information broadcast by other hosts on the network and supplies the status of the host on which the sample code is running. The first task is done in the main loop of the program: Packets received at the rwho(1) port are checked to be sure they were sent by another rwho(1) server process and are stamped with the arrival time. The packets then update a file with the status of the host. When a host has not been heard from for an extended time, the database routines assume the host is down and logs this information. Because a server might be down while a host is up, this application is prone to error.
Example 8-9 rwho(1) Server
    sp = getservbyname("who", "udp");
    net = getnetbyname("localnet");
    sin.sin6_addr = inet_makeaddr(net->n_net, in6addr_any);
    sin.sin6_port = sp->s_port;
    s = socket(AF_INET6, SOCK_DGRAM, 0);
    on = 1;
    if (setsockopt(s, SOL_SOCKET, SO_BROADCAST, &on, sizeof on)
            == -1) {
        syslog(LOG_ERR, "setsockopt SO_BROADCAST: %m");
    bind(s, (struct sockaddr *) &sin, sizeof sin);
    signal(SIGALRM, onalrm);
    while(1) {
        struct whod wd;
        int cc, whod, len = sizeof from;
        cc = recvfrom(s, (char *) &wd, sizeof(struct whod), 0,
            (struct sockaddr *) &from, &len);
        if (cc <= 0) {
            if (cc == -1 && errno != EINTR)
                syslog(LOG_ERR, "rwhod: recv: %m");
        if (from.sin6_port != sp->s_port) {
            syslog(LOG_ERR, "rwhod: %d: bad from port",
        if (!verify( wd.wd_hostname)) {
            syslog(LOG_ERR, "rwhod: bad host name from %x",
        (void) sprintf(path, "%s/whod.%s", RWHODIR, wd.wd_hostname);
        whod = open(path, O_WRONLY|O_CREAT|O_TRUNC, 0666);
        (void) time(&wd.wd_recvtime);
        (void) write(whod, (char *) &wd, cc);
        (void) close(whod);
The second server task is to supply the status of its host. This requires periodically acquiring system status information, packaging it in a message, and broadcasting it on the local network for other rwho(1) servers to hear. This task is run by a timer. This task is triggered by a signal.
Status information is broadcast on the local network. For networks that do not support broadcast, use multicast.
