Skip Navigation Links
Exit Print View
Oracle Directory Server Enterprise Edition Man Page Reference 11g Release 1 (11.1.1.5.0)
search filter icon
search icon
Document Information
Preface
User Commands
Administration Commands
Directory Server Configuration
Directory Proxy Server Configuration
aci-data-view(5dpconf)
aci-manager-bind-dn(5dpconf)
aci-manager-bind-pwd(5dpconf)
aci-manager-bind-pwd-file(5dpconf)
aci-source(5dpconf)
action(5dpconf)
add-weight(5dpconf)
allow-add-operations(5dpconf)
allow-bind-operations(5dpconf)
allow-cert-based-auth(5dpconf)
allow-compare-operations(5dpconf)
allow-delete-operations(5dpconf)
allowed-auth-methods(5dpconf)
allowed-comparable-attrs(5dpconf)
allowed-ldap-controls(5dpconf)
allowed-ldap-ports(5dpconf)
allowed-search-scopes(5dpconf)
allowed-subtrees(5dpconf)
allow-extended-operations(5dpconf)
allow-heuristic-search(5dpconf)
allow-inequality-search-operations(5dpconf)
allow-ldapv2-clients(5dpconf)
allow-modify-operations(5dpconf)
allow-partial-search(5dpconf)
allow-persistent-searches(5dpconf)
allow-rename-operations(5dpconf)
allow-sasl-external-authentication(5dpconf)
allow-search-operations(5dpconf)
allow-unauthenticated-operations(5dpconf)
allow-unauthenticated-operations-mode(5dpconf)
alternate-search-base-dn(5dpconf)
attr-name(5dpconf)
attr-name-mappings(5dpconf)
attrs(5dpconf)
base-dn(5dpconf)
bind-dn(5dpconf)
bind-dn-filters(5dpconf)
bind-pwd(5dpconf)
bind-pwd-attr(5dpconf)
bind-weight(5dpconf)
cert-data-view-routing-custom-list(5dpconf)
cert-data-view-routing-policy(5dpconf)
cert-search-attr-mappings(5dpconf)
cert-search-base-dn(5dpconf)
cert-search-bind-dn(5dpconf)
cert-search-bind-pwd(5dpconf)
cert-search-bind-pwd-file(5dpconf)
cert-search-user-attr(5dpconf)
client-affinity-bind-dn-filters(5dpconf)
client-affinity-criteria(5dpconf)
client-affinity-ip-address-filters(5dpconf)
client-affinity-policy(5dpconf)
client-affinity-timeout(5dpconf)
client-cred-mode(5dpconf)
close-client-connection(5dpconf)
compare-weight(5dpconf)
compat-flag(5dpconf)
configuration-manager-bind-dn(5dpconf)
configuration-manager-bind-pwd(5dpconf)
configuration-manager-bind-pwd-file(5dpconf)
connection-idle-timeout(5dpconf)
connection-pool-wait-interval(5dpconf)
connection-pool-wait-timeout(5dpconf)
connection-read-data-timeout(5dpconf)
connection-write-data-timeout(5dpconf)
connect-timeout(5dpconf)
connect-to-parent(5dpconf)
contains-shared-entries(5dpconf)
coordinated-data-view(5dpconf)
custom-distribution-algorithm(5dpconf)
data-source-read-timeout(5dpconf)
data-view-automatic-routing-mode(5dpconf)
data-view-use-internal-client-identity(5dpconf)
db-name(5dpconf)
db-pwd(5dpconf)
db-pwd-encryption(5dpconf)
db-pwd-file(5dpconf)
db-url(5dpconf)
db-user(5dpconf)
db-vendor(5dpconf)
default-log-level(5dpconf)
delete-weight(5dpconf)
denied-presence-filter-attr(5dpconf)
denied-presence-filter-enabled(5dpconf)
description(5dpconf)
dn-join-rule(5dpconf)
dn-mapping-attrs(5dpconf)
dn-mapping-source-base-dn(5dpconf)
dn-pattern(5dpconf)
domain-name-filters(5dpconf)
down-monitoring-interval(5dpconf)
driver-class(5dpconf)
driver-url(5dpconf)
email-alerts-enabled(5dpconf)
email-alerts-message-from-address(5dpconf)
email-alerts-message-subject(5dpconf)
email-alerts-message-subject-includes-alert-code(5dpconf)
email-alerts-message-to-address(5dpconf)
email-alerts-smtp-host(5dpconf)
email-alerts-smtp-port(5dpconf)
enable-client-affinity(5dpconf)
enabled-admin-alerts(5dpconf)
enable-data-view-affinity(5dpconf)
enabled-ssl-cipher-suites(5dpconf)
enabled-ssl-protocols(5dpconf)
enable-log-rotation(5dpconf)
enable-remote-user-mapping(5dpconf)
enable-user-mapping(5dpconf)
encrypt-configuration(5dpconf)
excluded-subtrees(5dpconf)
extension-jar-file-url(5dpconf)
filter-join-rule(5dpconf)
group-dn-filters(5dpconf)
group-search-bind-dn(5dpconf)
group-search-bind-pwd(5dpconf)
group-search-bind-pwd-file(5dpconf)
internal-value(5dpconf)
is-enabled(5dpconf)
is-read-only(5dpconf)
is-restart-required(5dpconf)
is-routable(5dpconf)
is-single-row-table(5dpconf)
is-ssl-mandatory(5dpconf)
jdbc-attr-date-format(5dpconf)
jdbc-attr-time-format(5dpconf)
jdbc-attr-timestamp-format(5dpconf)
jdbc-data-source-pool(5dpconf)
join-rule-control-enabled(5dpconf)
ldap-address(5dpconf)
ldap-data-source-pool(5dpconf)
ldap-port(5dpconf)
ldaps-port(5dpconf)
ldap-syntax(5dpconf)
ldif-data-source(5dpconf)
lexicographic-attrs(5dpconf)
lexicographic-lower-bound(5dpconf)
lexicographic-upper-bound(5dpconf)
listen-address(5dpconf)
listen-port(5dpconf)
load-balancing-algorithm(5dpconf)
log-buffer-size(5dpconf)
log-etimes-in-seconds(5dpconf)
log-file-compression(5dpconf)
log-file-name(5dpconf)
log-file-perm(5dpconf)
log-level-bind(5dpconf)
log-level-client-connections(5dpconf)
log-level-client-disconnections(5dpconf)
log-level-client-operations(5dpconf)
log-level-configuration(5dpconf)
log-level-connection-handlers(5dpconf)
log-level-data-source(5dpconf)
log-level-data-sources(5dpconf)
log-level-data-sources-detailed(5dpconf)
log-level-internal(5dpconf)
log-level-operation-decode(5dpconf)
log-level-operation-processing(5dpconf)
log-level-plugin(5dpconf)
log-level-shutdown(5dpconf)
log-level-startup(5dpconf)
log-min-size(5dpconf)
log-rotation-frequency(5dpconf)
log-rotation-policy(5dpconf)
log-rotation-size(5dpconf)
log-rotation-start-day(5dpconf)
log-rotation-start-time(5dpconf)
log-search-filters(5dpconf)
mapped-bind-dn(5dpconf)
mapped-bind-pwd(5dpconf)
mapped-bind-pwd-file(5dpconf)
max-age(5dpconf)
max-client-connections(5dpconf)
max-connection-queue-size(5dpconf)
max-connections(5dpconf)
max-ldap-message-size(5dpconf)
max-log-files(5dpconf)
max-op-count-per-interval(5dpconf)
max-simultaneous-operations-per-connection(5dpconf)
max-size(5dpconf)
max-total-operations-per-connection(5dpconf)
min-free-disk-space-size(5dpconf)
minimum-search-filter-substring-length(5dpconf)
minimum-total-weight(5dpconf)
model(5dpconf)
modify-dn-weight(5dpconf)
modify-weight(5dpconf)
monitoring-bind-dn(5dpconf)
monitoring-bind-pwd(5dpconf)
monitoring-bind-pwd-file(5dpconf)
monitoring-bind-timeout(5dpconf)
monitoring-entry-dn(5dpconf)
monitoring-entry-timeout(5dpconf)
monitoring-inactivity-timeout(5dpconf)
monitoring-mode(5dpconf)
monitoring-retry-count(5dpconf)
monitoring-search-filter(5dpconf)
monitoring-search-scope(5dpconf)
non-viewable-attr(5dpconf)
non-writable-attr(5dpconf)
number-of-psearch-threads(5dpconf)
number-of-search-threads(5dpconf)
number-of-threads(5dpconf)
number-of-worker-threads(5dpconf)
num-bind-incr(5dpconf)
num-bind-init(5dpconf)
num-bind-limit(5dpconf)
num-connection-incr(5dpconf)
num-connection-init(5dpconf)
num-connection-limit(5dpconf)
numeric-attrs(5dpconf)
numeric-default-data-view(5dpconf)
numeric-lower-bound(5dpconf)
numeric-upper-bound(5dpconf)
num-read-incr(5dpconf)
num-read-init(5dpconf)
num-read-limit(5dpconf)
num-write-incr(5dpconf)
num-write-init(5dpconf)
num-write-limit(5dpconf)
one-level-search-base-dn(5dpconf)
op-count-per-interval-timeout(5dpconf)
pattern-matching-base-dn-regular-expression(5dpconf)
pattern-matching-base-object-search-filter(5dpconf)
pattern-matching-dn-regular-expression(5dpconf)
pattern-matching-one-level-search-filter(5dpconf)
pattern-matching-subtree-search-filter(5dpconf)
perform-distinct-select(5dpconf)
primary-table(5dpconf)
primary-view(5dpconf)
priority(5dpconf)
process-bind(5dpconf)
prohibited-comparable-attrs(5dpconf)
prohibited-subtrees(5dpconf)
proportion(5dpconf)
proxied-auth-check-timeout(5dpconf)
proxied-auth-use-v1(5dpconf)
referral-bind-policy(5dpconf)
referral-hop-limit(5dpconf)
referral-policy(5dpconf)
remote-user-mapping-bind-dn-attr(5dpconf)
replication-role(5dpconf)
request-filtering-policy(5dpconf)
request-grouping-size(5dpconf)
require-data-view-availability(5dpconf)
resource-limits-policy(5dpconf)
revert-add-on-failure(5dpconf)
rule-action(5dpconf)
sample-size(5dpconf)
schema-check-enabled(5dpconf)
scriptable-alerts-command(5dpconf)
scriptable-alerts-enabled(5dpconf)
search-mode(5dpconf)
search-retry-count(5dpconf)
search-size-limit(5dpconf)
search-time-limit(5dpconf)
search-wait-timeout(5dpconf)
search-weight(5dpconf)
secondary-table(5dpconf)
secondary-view(5dpconf)
sql-column(5dpconf)
sql-syntax(5dpconf)
sql-table(5dpconf)
ssl-client-cert-alias(5dpconf)
ssl-policy(5dpconf)
ssl-server-cert-alias(5dpconf)
subtree-search-base-dn(5dpconf)
super-class(5dpconf)
supported-ssl-cipher-suites(5dpconf)
supported-ssl-protocols(5dpconf)
syslog-alerts-enabled(5dpconf)
syslog-alerts-facility(5dpconf)
syslog-alerts-host(5dpconf)
target-attr-value-assertions(5dpconf)
target-dn-regular-expressions(5dpconf)
target-dns(5dpconf)
time-resolution(5dpconf)
time-resolution-mode(5dpconf)
use-cert-subject-as-bind-dn(5dpconf)
use-external-schema(5dpconf)
user-bind-dn(5dpconf)
user-bind-pwd(5dpconf)
user-bind-pwd-file(5dpconf)
use-read-connections-for-writes(5dpconf)
user-filter(5dpconf)
user-mapping-anonymous-bind-dn(5dpconf)
user-mapping-anonymous-bind-pwd(5dpconf)
user-mapping-anonymous-bind-pwd-file(5dpconf)
user-mapping-default-bind-dn(5dpconf)
user-mapping-default-bind-pwd(5dpconf)
user-mapping-default-bind-pwd-file(5dpconf)
use-tcp-keep-alive(5dpconf)
use-tcp-no-delay(5dpconf)
verify-certs(5dpconf)
view-value(5dpconf)
vlv-control-enabled(5dpconf)
vlv-control-page-size(5dpconf)
vlv-control-sorting-attr(5dpconf)
warning-op-count-per-interval(5dpconf)
File Formats
LDAP Schema Collections
LDAP Schema Attribute Types
LDAP Schema Object Classes
Index
max-connections
- Directory Proxy Server configuration property
Description
Syntax
integer
Default value
unlimited
Must be set
No
Is modifiable
Yes
Is multivalued
No
Requires restart
No
This property specifies the maximum number of simultaneous connections permitted by associated connection handlers.
This property takes an integer.
The value of this property must be at least 1.
The default behavior for this property is as follows: No limit
This property is used to configure the following features:
Resource limit policies define the maximum resources that Directory Proxy Server can process for a given connection handler.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Availability
SUNWdsee7
Stability Level
Evolving
See Also
dpconf(1M)
