Skip Navigation Links
Exit Print View
Sun Server X2-4 (formerly Sun Fire X4470 M2)
Installation Guide for Windows Operating System
search filter icon
search icon
Document Information
Using This Documentation
Part I  Windows Server Installations
1.  Assisted OS Installation With Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Task Overview
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
2.  Getting Started
Supported Windows Server Operating Systems
Windows Installation Prerequisites
Windows Server Installation Task Overview
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
3.  Installing Windows Server 2008
Before You Begin
Installing Windows Server Using Local or Remote Media
Windows Server Installation Using a PXE Network Boot
4.  Post Installation of Windows Server 2008
Before You Begin
Installing Critical Device Drivers and Supplemental Software
Installing Supplemental Software
Configuring Support for TPM
Configuring Intel NIC Teaming
5.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Installing Updates
Part II  Windows Server System Administrator References
A.  Supported Installation Methods
Console Outputs
Installation Boot Media
Installation Targets
B.  Supported Operating Systems
C.  BIOS Defaults for New Installations
Verification of BIOS Factory Defaults
D.  Incorporating Device Drivers Into Windows Server 2008 WIM Images for Windows Deployment Services
Getting Started
Procedures for Incorporating Drivers Into WIM Image(s)
This installation guide contains installation and configuration procedures for Windows operating systems. You perform these procedures to bring the server to a configurable and usable state.
Note - The Sun Server X2-4 was formerly named the Sun Fire X4470 M2 server. This former name might still appear in the software. The new product name does not indicate any change in system features or functionality.
This document is intended for system administrators, network administrators, and service technicians who have an understanding of server systems.
Getting the Latest Software and Firmware
Firmware, drivers, and other hardware-related software for each Oracle x86 server, server module (blade), and blade chassis are updated periodically.
For instructions, see Chapter 5, Getting Server Firmware and Software.
About This Documentation
This documentation set is available in both PDF and HTML formats. A PDF version that includes all information on a particular topic subject (such as hardware installation or product notes) can be generated by clicking the PDF button in the upper left corner of the HTML page.
Related Documentation
All Oracle documentation
Sun Server X2-4
Oracle Integrated Lights Out Manager (ILOM) 3.0
Oracle Integrated Lights Out Manager (ILOM) 3.1 (for Sun Server X2-4 Software Release 1.3 and above)
You can provide feedback on this documentation at:
Support and Accessibility
Access electronic support through My Oracle Support
Learn about Oracle's commitment to accessibility
