Skip Navigation Links | |
Exit Print View | |
Sun Server X2-4 (formerly Sun Fire X4470 M2) Installation Guide for Windows Operating System |
Part I Windows Server Installations
1. Assisted OS Installation With Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Task Overview
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
Supported Windows Server Operating Systems
Windows Installation Prerequisites
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
3. Installing Windows Server 2008
Installing Windows Server Using Local or Remote Media
Windows Server Installation Using a PXE Network Boot
4. Post Installation of Windows Server 2008
Installing Critical Device Drivers and Supplemental Software
Installing Supplemental Software
5. Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Part II Windows Server System Administrator References
A. Supported Installation Methods
B. Supported Operating Systems
C. BIOS Defaults for New Installations
Verification of BIOS Factory Defaults
D. Incorporating Device Drivers Into Windows Server 2008 WIM Images for Windows Deployment Services
To manually install Windows Server 2008 (SP2 or R2), complete the following procedures in order:
Obtain the tools and drivers firmware by downloading the latest drivers and utilities available for your Sun x86 server platform as described in Chapter 5, Getting Server Firmware and Software.
The install program for the Windows Server 2008 SP2 does not include the LSI drivers for the Sun Storage SAS PCIe HBA options. Therefore, if you have a SAS PCIe HBA configured on your server and you are installing Windows 2008 SP2, the LSI mass storage driver for the SAS PCIe HBA option must be made accessible from the tools and drivers firmware DVD during the installation process.
For a list of SAS PCIe HBAs supported on the Sun Server X2-4, see SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2.
Note - Optionally, advanced users might prefer to incorporate the drivers into WDS images. For instructions on how to incorporate the drivers into WDS images, see Appendix D, Incorporating Device Drivers Into Windows Server 2008 WIM Images for Windows Deployment Services.
Choose and set up an installation method for deploying the Windows Server installation as described in Appendix A, Supported Installation Methods.
Follow the instructions for performing a manual installation of the Windows Server operating system as described in Chapter 3, Installing Windows Server 2008.
Follow the instructions for performing the Windows Server post installation tasks as described in Chapter 4, Post Installation of Windows Server 2008.
