Skip Navigation Links
Exit Print View
Sun Server X2-4 (formerly Sun Fire X4470 M2)
Installation Guide for Windows Operating System
search filter icon
search icon
Document Information
Using This Documentation
Part I  Windows Server Installations
1.  Assisted OS Installation With Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Task Overview
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
2.  Getting Started
Supported Windows Server Operating Systems
Windows Installation Prerequisites
Windows Server Installation Task Overview
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
3.  Installing Windows Server 2008
Before You Begin
Installing Windows Server Using Local or Remote Media
Windows Server Installation Using a PXE Network Boot
4.  Post Installation of Windows Server 2008
Before You Begin
Installing Critical Device Drivers and Supplemental Software
Install Server-Specific Device Drivers
Installing Supplemental Software
Install the Supplemental Software
Configuring Support for TPM
Configuring Intel NIC Teaming
5.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Installing Updates
Part II  Windows Server System Administrator References
A.  Supported Installation Methods
Console Outputs
Installation Boot Media
Installation Targets
B.  Supported Operating Systems
C.  BIOS Defaults for New Installations
Verification of BIOS Factory Defaults
D.  Incorporating Device Drivers Into Windows Server 2008 WIM Images for Windows Deployment Services
Getting Started
Procedures for Incorporating Drivers Into WIM Image(s)
An installation wizard is provided on the Tools and Drivers firmware DVD to install server-specific device drivers and Supplemental Software. The server-specific device drivers are provided to support optional hardware devices that can be installed on your server.
  1. Insert the Tools and Drivers firmware DVD into a local or remote USB DVD drive and do one of the following:
    • If the DVD automatically starts, click Install Drivers and Supplement Software.
    • If the DVD does not automatically start, navigate to one of the following folders containing the appropriate InstallPack file (for example, InstallPack_1_0_1.exe), and double-click it.
      • <DVD>/Windows/W2K8/Packages
      • <DVD>/Windows/W2K8R2/Packages
      The Server Installation Package dialog appears.
  2. In the Install Pack dialog, click Next to accept the default installable items.
    Note - You should always accept the “default installable items” to ensure that the most recent versions of the drivers are installed.
    The Install Pack notice dialog appears.
  3. In the Install Pack notice dialog, read the message, then click Next.
    The Welcome to the Sun Fire Installation Wizard appears.
  4. In the Welcome to the Sun Fire Installation Wizard dialog, click Next.
    The End User License Agreement page appears.
  5. In the End User License Agreement page, select I Accept This Agreement, then click Next.
    The platform-specific drivers are installed. A green check mark verifies that each driver was installed successfully.
  6. In the Driver Installation Pack dialog, click Finish.
    The System Settings Change dialog appears.
    Note - If you plan on installing Supplemental Software (highly recommended), do not restart your system at this time. Once the Supplemental Software has been installed, you will be prompted to restart the system.
  7. Perform one of the following:
    • If you accepted the default installable settings in Step 2, click No to proceed to Installing Supplemental Software.
    • If you are not installing the Supplemental Software, click Yes to restart your computer.
