Skip Navigation Links
Exit Print View
Sun Server X2-4 (formerly Sun Fire X4470 M2)
Installation Guide for Windows Operating System
search filter icon
search icon
Document Information
Using This Documentation
Part I  Windows Server Installations
1.  Assisted OS Installation With Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Task Overview
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
2.  Getting Started
Supported Windows Server Operating Systems
Windows Installation Prerequisites
Windows Server Installation Task Overview
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
3.  Installing Windows Server 2008
Before You Begin
Installing Windows Server Using Local or Remote Media
Windows Server Installation Using a PXE Network Boot
4.  Post Installation of Windows Server 2008
Before You Begin
Installing Critical Device Drivers and Supplemental Software
Install Server-Specific Device Drivers
Installing Supplemental Software
Install the Supplemental Software
Configuring Support for TPM
Configuring Intel NIC Teaming
5.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Installing Updates
Part II  Windows Server System Administrator References
A.  Supported Installation Methods
Console Outputs
Installation Boot Media
Installation Targets
B.  Supported Operating Systems
C.  BIOS Defaults for New Installations
Verification of BIOS Factory Defaults
D.  Incorporating Device Drivers Into Windows Server 2008 WIM Images for Windows Deployment Services
Getting Started
Procedures for Incorporating Drivers Into WIM Image(s)
There are several Supplemental Software components available for your Sun Server X2-4. You have two options for installation:
Install Pack Optional Supplemental Software  identifies the optional Supplemental Software components available for your server.
Table 4-1 Install Pack Optional Supplemental Software¬†
Available Supplemental Software Components
Servers With LSI Integrated RAID Controller
Servers With Intel Integrated Disk Controller
LSI MegaRAID Storage Manager, click Yes to restart your computer
Enables you to configure, monitor, and maintain RAID on the SAS internal RAID host bus adapter.
Not applicable
IPMItool command-line utility
The IPMItool command-line utility reads the sensor data repository (SDR) and displays sensor values, system event log (SEL), and field- replaceable unit (FRU) inventory information; gets and sets LAN configuration parameters; and performs chassis power control operations via the BMC, which is also called the service processor (SP).
Intel NIC Teaming
Enables the network interfaces on a server to be grouped together into a team of physical ports called a virtual interface.
Caution - If you have already installed the Supplemental Software, running the installation again will not necessarily reinstall the Supplemental Software. It might result in the components being removed. Carefully review the dialog boxes during Supplemental Software installation to ensure that the results are as expected.
  1. Do one of the following:
  2. In the Install Pack Supplemental Software dialog, click Next to accept the typical settings; or select Custom to choose the options to install (see descriptions of the Supplemental Software in Install Pack Optional Supplemental Software ).
    The Component Installation wizard will guide you through the installation of each of the selected Supplemental Software components.
  3. After the Supplemental Software has been installed, click Finish.
  4. Click Yes at the System Setting Change dialog to restart your system.
    If you ran the Sun Server Installation Package software from the Tools and Drivers firmware DVD, remove the DVD from your system.
