Skip Navigation Links
Exit Print View
Sun Server X2-4 (formerly Sun Fire X4470 M2)
Installation Guide for Windows Operating System
search filter icon
search icon
Document Information
Using This Documentation
Part I  Windows Server Installations
1.  Assisted OS Installation With Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Task Overview
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
2.  Getting Started
Supported Windows Server Operating Systems
Windows Installation Prerequisites
Windows Server Installation Task Overview
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
3.  Installing Windows Server 2008
Before You Begin
Installing Windows Server Using Local or Remote Media
Windows Server Installation Using a PXE Network Boot
4.  Post Installation of Windows Server 2008
Before You Begin
Installing Critical Device Drivers and Supplemental Software
Installing Supplemental Software
Configuring Support for TPM
Configuring Intel NIC Teaming
5.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Installing Updates
Part II  Windows Server System Administrator References
A.  Supported Installation Methods
Console Outputs
Installation Boot Media
Installation Targets
B.  Supported Operating Systems
C.  BIOS Defaults for New Installations
Verification of BIOS Factory Defaults
D.  Incorporating Device Drivers Into Windows Server 2008 WIM Images for Windows Deployment Services
Getting Started
Procedures for Incorporating Drivers Into WIM Image(s)
Index
Supported SAS PCIe HBAs Requiring LSI Mass Storage Driver identifies the SAS PCIe host bus adapter options that are supported on the Sun Server X2-4. If you have one of these SAS PCIe HBA options configured on your server and you are installing Windows Server 2008 SP2, you will need to load the LSI mass storage driver for the PCIe HBA option from the tools and drivers firmware DVD during installation.
Note - To determine which HBA option cards are supported and available for purchase on the Sun Server X2-4, go to the Sun x86 Servers web site and navigate to the Sun Server X2-4 page: http://www.oracle.com/technetwork/server-storage/sun-x86/overview/index.html.
Table 2-2 Supported SAS PCIe HBAs Requiring LSI Mass Storage Driver
Option Number
Driver Required During Installation
Sun Storage 6 Gb SAS PCIe RAID HBA, Internal
SG-SAS6-R-INT-Z
LSI MegaRAID SAS 92xx-xx
Sun Storage 6 Gb SAS PCIe HBA, Internal
SG-SAS6-INT-Z
LSI Adapter SAS 2008 Falcon
Sun Storage 6 Gb SAS PCIe HBA, External
SG-SAS6-EXT-Z
Instructions for loading the LSI mass storage driver during the Windows Server 2008 SP2 installation are provided in Step 8 of the Install Windows Server 2008 (SP2 or R2) Using Local or Remote Media.
If you do not have the tools and drivers firmware, you can download the ISO image for the tools and drivers firmware. For details, see Chapter 5, Getting Server Firmware and Software.
