Skip Navigation Links
Exit Print View
Sun Server X2-4 (formerly Sun Fire X4470 M2)
Installation Guide for Windows Operating System
search filter icon
search icon
Document Information
Using This Documentation
Part I  Windows Server Installations
1.  Assisted OS Installation With Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Task Overview
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
2.  Getting Started
Supported Windows Server Operating Systems
Windows Installation Prerequisites
Windows Server Installation Task Overview
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
3.  Installing Windows Server 2008
Before You Begin
Installing Windows Server Using Local or Remote Media
Windows Server Installation Using a PXE Network Boot
4.  Post Installation of Windows Server 2008
Before You Begin
Installing Critical Device Drivers and Supplemental Software
Install Server-Specific Device Drivers
Installing Supplemental Software
Install the Supplemental Software
Configuring Support for TPM
Configuring Intel NIC Teaming
5.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Installing Updates
Part II  Windows Server System Administrator References
A.  Supported Installation Methods
Console Outputs
Installation Boot Media
Installation Targets
B.  Supported Operating Systems
C.  BIOS Defaults for New Installations
Verification of BIOS Factory Defaults
D.  Incorporating Device Drivers Into Windows Server 2008 WIM Images for Windows Deployment Services
Getting Started
Procedures for Incorporating Drivers Into WIM Image(s)
Index
For more information on setting up NIC teaming for your environment, refer to the Intel Connectivity web page on Advanced Networking Services Teaming at:
http://support.intel.com/support/network/sb/CS-009747.htm
Additionally, you can download the complete set of Intel Network Connections User Guides for your server's network adapters at:
http://support.intel.com/support/network/sb/cs-009715.htm
