Skip Navigation Links
Exit Print View
Sun Server X2-4 (formerly Sun Fire X4470 M2)
Installation Guide for Oracle VM Software
search filter icon
search icon
Document Information
Using This Documentation
Part I  Oracle VM Software Installation
1.  Getting Started
Supported Virtual Machine Software
Oracle VM Software Installation Prerequisites
Oracle VM Software Installation Task Overview
2.  Installing Oracle VM
Installing Oracle VM Using Local or Remote Media
Oracle VM Post Installation Tasks
3.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Installing Updates
Part II  Oracle VM System Administrator References
A.  Supported Installation Methods
Console Outputs
Installation Boot Media
Installation Targets
B.  Supported Operating Systems
C.  BIOS Defaults for New Installations
Verification of BIOS Factory Defaults
Before You Begin
View or Edit BIOS Settings for New Installations
Appendix C
When installing a new operating system on a disk drive, you should verify that the following BIOS settings are properly configured before you perform the operating system installation:
