Go to main content
Sun Server X2-4 (formerly Sun Fire X4470 M2) Product Notes
Exit Print View
Updated: January 2017
Supported Memory Configurations
The Sun Server X2-4 supports dual-rank 4-GB and 8-GB RDIMMs and quad-rank 16-GB RDIMMs. A two-processor system using four riser modules populated with 16-GB RDIMMs supports a maximum of 512 GB of system memory. A four-processor system using eight riser modules populated with 16-GB RDIMMs supports a maximum of 1 TB of system memory.
  • Dual-rank DIMMs (marked 2Rx4) do not include heat spreaders.
  • Quad-rank DIMMs (marked 4Rx4) include heat spreaders. DIMMs with heat spreaders have two U-shaped metal clips on the top of the DIMM.
Note -  Mixing dual-rank and quad-rank DIMMs on the same memory riser degrades performance.
