Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.0
Supplement for Sun Server X2-4
search filter icon
search icon
Document Information
Using This Documentation
1.  Determining Your Server Management Strategy
Common Server Management Tasks
Server Management Software Benefits
Oracle Hardware Management Pack
Oracle Hardware Management Agents
Oracle Server CLI Tools
IPMItool
Oracle Hardware Installation Assistant
Evaluating Your Server Environment
Which Operating System Do You Plan to Install?
From Which Platform Do You Want to Run the Software?
Do You Want to Update or Monitor Your System Components?
Do You Have a Modular System Environment?
Server Management Downloads and Documentation
2.  Oracle ILOM 3.0 Documentation
Oracle ILOM 3.0 Documentation Collection
Oracle ILOM 3.0 Server-Specific Documentation
3.  Oracle ILOM Platform Features for the Sun Server X2-4
Supported Sun Server X2-4 Firmware
Power Management Policies
Host Power Throttling and Recovery
Service Processor Power-On Policy
Low Line AC Override Policy
Oracle ILOM Sideband Management
Special Considerations for Sideband Management
Switch Serial Port Output Between SP and Host Console
Switch Serial Port Output Using the Web Interface
Switch Serial Port Output Using the CLI
Server Chassis Intrusion Sensor
How the /SYS/INTSW Sensor Works
Fault Management
Determining Faults
Clearing Faults
Components With No Fault Diagnosis
Viewing Sensors Using IPMItool
Sensors and Indicators Reference Information
System Components
System Indicators
Temperature Sensors
Power Supply Fault Sensors
Fan Speed and Physical Security Sensors
Power Supply Unit Current, Voltage, and Power Sensors
Entity Presence Sensors
SNMP and PET Message Reference Information
SNMP Traps
PET Event Messages
4.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Request Physical Media (By Phone)
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
Index
This section can help you to decide which type of server management option or combination of options is best for your server environment.
The evaluation covers the following questions:
Most of the server management software will work with most operating systems that are supported for Oracle servers. However, there are some exceptions that are important to note. See the following table for detailed information.
Operating System Limitations
There are no operating system limitations with Oracle ILOM, because the software runs on the system service processor, not on the operating system.
There are some limitations on which operating systems are supported with the Hardware Management Pack components. For details, refer to the Support Matrix at http://www.oracle.com/goto/hmp.
You can only install Windows and Linux (Oracle Linux, Red Hat Enterprise Linux, and SUSE Linux) operating systems with the Oracle Hardware Installation Assistant.
If you have Oracle Solaris or Oracle VM installed on the server, you can update firmware and perform additional server management tasks.
When deciding on your server management strategy, you need to determine whether you want to run your server management tasks from the system host, embedded firmware, or bootable media.
Platform
Embedded service processor firmware
Host operating system
Bootable media (CD/DVD or USB drive) from a local or remote source
The server management software tools are designed primarily to update or monitor system software and components. The following table lists the main functions of each software option.
Update Functions
Monitoring Functions
Updates ILOM and BIOS firmware.
Monitors component status and reports faults.
Configures ILOM and BIOS firmware.
Updates HBA and expander firmware.
Configures RAID.
Monitors component status and reports fault.
Updates and configures ILOM, BIOS, and HBA firmware.
Assists in operating system and driver installation.
Configures RAID.
Provides minimal system status information.
All of the server management software can be used with modular systems (blades) or rack servers, but only one of the software tools, Oracle ILOM, can be used to manage blade servers from both the modular system chassis monitoring module (CMM) and blade server interfaces.
Modular System CMM Interface?
Server Module Interface?
Yes
Yes
No
Yes
No
Yes
