Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.0
Supplement for Sun Server X2-4
search filter icon
search icon
Document Information
Using This Documentation
1.  Determining Your Server Management Strategy
Common Server Management Tasks
Server Management Software Benefits
Oracle Hardware Management Pack
Oracle Hardware Installation Assistant
Evaluating Your Server Environment
Which Operating System Do You Plan to Install?
From Which Platform Do You Want to Run the Software?
Do You Want to Update or Monitor Your System Components?
Do You Have a Modular System Environment?
Server Management Downloads and Documentation
2.  Oracle ILOM 3.0 Documentation
Oracle ILOM 3.0 Documentation Collection
Oracle ILOM 3.0 Server-Specific Documentation
3.  Oracle ILOM Platform Features for the Sun Server X2-4
Supported Sun Server X2-4 Firmware
Power Management Policies
Host Power Throttling and Recovery
Service Processor Power-On Policy
Low Line AC Override Policy
Configure SP Power Management Policies Using the Web Interface
Configure SP Power Management Policies Using the CLI
Oracle ILOM Sideband Management
Special Considerations for Sideband Management
Configure Sideband Management Using the Web Interface
Configure Sideband Management Using the CLI
Configure Sideband Management Using the Host BIOS Setup Utility
Switch Serial Port Output Between SP and Host Console
Switch Serial Port Output Using the Web Interface
Switch Serial Port Output Using the CLI
Server Chassis Intrusion Sensor
How the /SYS/INTSW Sensor Works
Fault Management
Determining Faults
Clearing Faults
Components With No Fault Diagnosis
Viewing Sensors Using IPMItool
Sensors and Indicators Reference Information
System Components
System Indicators
Temperature Sensors
Power Supply Fault Sensors
Fan Speed and Physical Security Sensors
Power Supply Unit Current, Voltage, and Power Sensors
Entity Presence Sensors
SNMP and PET Message Reference Information
SNMP Traps
PET Event Messages
4.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Request Physical Media (By Phone)
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
Index
The server includes several sensors and indicators that report on hardware conditions. Many of the sensor readings are used to adjust the fan speeds and perform other actions, such as illuminating LEDs and powering off the server.
This section describes the sensors and indicators that Oracle ILOM monitors for the Sun Server X2-4.
The following types of sensors are described:
System Components
System Components  describes the system components.
Table 3-2 System Components
Component Name
Description
/SYS/DBP
Disk backplane
/SYS/DBP/HDDn
Hard disks n
/SYS/FB
Fan board
/SYS/FB/FANn
Fan n
/SYS/MB
Motherboard
/SYS/MB/NETn
Host network interfaces n
/SYS/MB/Pn
Processor n
/SYS/MB/Pn/MRn
Processor n; Memory riser n
/SYS/MB/Pn/MRn/Dn
Processor n; Memory riser n; DIMM n
/SYS/MB/PCIE[n, CC]
PCIe slot n, or cluster card
/SYS/PSn
Power supply n
/SYS/SP
Service processor
/SYS/SP/NETn
SP network interface n
System Indicators
System Indicators  describes the system indicators.
Table 3-3 System Indicators
Indicator Name
Description
/SYS/CPU_FAULT
System CPU Fault LED
/SYS/DBP/HDDn/OK2RM
Hard disk n OK-to-Remove LED
/SYS/DBP/HDDn/SERVICE
Hard disk n Service LED
/SYS/FAN_FAULT
System fan Fault LED
/SYS/FB/FANn/OK
Fan n OK LED
/SYS/FB/FANn/SERVICE
Fan n Service LED
/SYS/LOCATE
System Locate indicator LED
/SYS/MB/Pn/SERVICE
Processor n Service LED
/SYS/MB/Pn/MRn/SERVICE
Processor n; Memory riser n Service LED
/SYS/MB/Pn/MRn/Dn/SERVICE
Processor n; Memory riser n; DIMM n; Service indicator
/SYS/MEMORY_FAULT
System memory Fault LED
/SYS/OK
System OK LED
/SYS/PS_FAULT
System power supply Fault LED
/SYS/SERVICE
System Service LED
/SYS/SP/OK
SP OK LED
/SYS/SP/SERVICE
SP Service LED
/SYS/TEMP_FAULT
System temperature Fault LED
Temperature Sensors
Temperature Sensors  describes the environmental sensors.
Table 3-4 Temperature Sensors
Sensor Name
Sensor Type
Description
/SYS/DBP/T_AMB
Temperature
Disk back plane ambient temperature sensor
/SYS/MB/T_OUTn
Temperature
Motherboard exhaust temperature n sensor
Note - These sensors are located in the rear of the chassis.
/SYS/T_AMB
Temperature
System ambient temperature sensor
Note - This sensor is located on the underside of the fan board.
/SYS/PSn/T_OUT
Temperature
Power supply n exhaust temperature sensors
Power Supply Sensors  describes the power supply fault sensors. In the table, n designates the numbers 0-1.
Table 3-5 Power Supply Sensors
Sensor Name
Sensor Type
Description
/SYS/PSn/V_OUT_OK
Fault
Power supply n output voltage OK
/SYS/PSn/V_IN_ERR
Fault
Power supply n input voltage error
/SYS/PSn/V_IN_WARN
Fault
Power supply n input voltage warning
/SYS/PSn/V_OUT_ERR
Fault
Power supply n output voltage error
/SYS/PSn/I_OUT_ERR
Fault
Power supply n output current error
/SYS/PSn/I_OUT_WARN
Fault
Power supply n output current warning
/SYS/PSn/T_ERR
Fault
Power supply n temperature error
/SYS/PSn/T_WARN
Fault
Power supply n temperature warning
/SYS/PSn/FAN_ERR
Fault
Power supply n fan error
/SYS/PSn/FAN_WARN
Fault
Power supply n fan warning
/SYS/PSn/ERR
Fault
Power supply n error
Fan and Security Sensors  describes the fan and security sensors. In the table, n designates numbers 0, 1, 2, etc.
Table 3-6 Fan and Security Sensors
Sensor Name
Sensor Type
Description
/SYS/FB/FANn/TACH
Fan speed
Fan board; Fan n tachometer
/SYS/INTSW
Physical security
This sensor tracks the state of the chassis intrusion switch. If the server's top cover is opened while the AC power cords are still connected so that power is being applied to the server, this sensor asserts. If the top cover is subsequently replaced, this sensor is de-asserted.
For more information, see Server Chassis Intrusion Sensor.
Power Supply Unit Current, Voltage, and Power Sensors  describes the power supply unit current, voltage, and power sensors. In the table, n designates numbers 0-1.
Table 3-7 Power Supply Unit Current, Voltage, and Power Sensors
Sensor Name
Sensor Type
Description
/SYS/PSn/V_IN
Voltage
Power supply n AC input voltage sensor
/SYS/PSn/V_12V
Voltage
Power supply n 12 volt output sensor
/SYS/PSn/V_3V3
Voltage
Power supply n 3.3 volt output sensor
/SYS/PSn/P_IN
Power
Power supply n input power sensor
/SYS/PSn/P_OUT
Power
Power supply n output power sensor
/SYS/VPS
Power
Server total input power consumption sensor
Presence Sensors  describes the entity presence sensors. In the table, n designates numbers 0, 1, 2, etc.
Table 3-8 Presence Sensors
Sensor Name
Sensor Type
Description
/SYS/DBP/HDDn/PRSNT
Entity presence
Hard drive device present monitor
/SYS/DBP/PRSNT
Entity presence
Disk backplane present monitor
/SYS/FB/FANn/PRSNT
Entity presence
Fan board; Fan n present monitor
/SYS/MB/Pn/PRSNT
Entity presence
Motherboard; CPU n present monitor
/SYS/MB/Pn/MRn/PRSNT
Entity presence
Motherboard; CPU n; Memory riser n present monitor
/SYS/MB/Pn/MRn/Dn/PRSNT
Entity presence
Motherboard; CPU n; Memory riser n; DIMM n present monitor
/SYS/MB/PCIEn/PRSNT
Entity presence
PCIe card n present monitor
Note - n represents PCIe cards 0-9 or the cluster controller (cc) card.
/SYS/PSn/PRSNT
Entity presence
Power supply n present monitor
