Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1
Supplement for Sun Server X2-4
search filter icon
search icon
Document Information
Using This Documentation
1.  Determining Your Server Management Strategy
Common System Management Tasks
Server Management Software Benefits
Oracle Hardware Management Pack
Oracle Hardware Installation Assistant
Server Management Downloads and Documentation
2.  Oracle ILOM 3.1 Documentation
Oracle ILOM 3.1 Documentation Collection
3.  Oracle ILOM Features for the Sun Server X2-4
Sun Server X2-4 Supported Firmware
Oracle ILOM 3.1 Features Supported on All Servers
Oracle ILOM 3.1 Features Supported on Oracle x86 Servers
Sideband Management
Power Control Policies
Local Host Interconnect Management Connection
Diagnostics Using Pc-Check and NMI
Control Next Boot Device
FRU TLI Auto-Update
Switch Serial Port Output to Host Management Console
Administer Open Problems and Clear Server Faults
Oracle ILOM 3.1 Features Not Supported on Sun Server X2-4
4.  Sensors and Indicators Reference Information
System Components
System Indicators
Temperature Sensors
Power Supply Fault Sensors
Fan Speed and Physical Security Sensors
Power Supply Unit Current, Voltage, and Power Sensors
Entity Presence Sensors
SNMP and PET Message Reference Information
SNMP Traps
PET Event Messages
5.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Request Physical Media (Online)
Request Physical Media (By Phone)
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
Index
Downloads on My Oracle Support are grouped by product family, then product, then version. The version contains one or more downloads (patches).
For servers and blades, the pattern is similar. The product is the server. Each server contains a set of releases. These releases are not true software product releases, but rather are releases of updates for the server. These updates are called software releases and comprise several downloads, all tested together. Each download contains firmware, drivers, or utilities.
My Oracle Support has the same set of download types for this server family as shown in the following table. These can also be requested through a physical media request (PMR).
Package Name
Description
When to Download This Package
X4470 M2 SERVER SW 1.3 – ILOM_AND_BIOS
Oracle ILOM and BIOS
You need the latest platform firmware.
X4470 M2 SERVER SW 1.3 – ORACLE_HARDWARE_INSTAL LATION_ASSISTANT
Oracle Hardware Installation Assistant recovery and ISO update image.
You need to manually recover or update Oracle Hardware Installation Assistant.
X4470 M2 SERVER SW 1.3 – TOOLS_DRIVERS_AND_FIRMW ARE_DVD
Includes the tools and drivers and platform firmware. This DVD image does not include Oracle VTS.
You need to update a combination of system firmware and OS-specific software.
X4470 M2 SERVER SW 1.0 - DIAGNOSTICS
Oracle VTS diagnostics image.
You need the Oracle VTS diagnostics image.
