Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1
Supplement for Sun Server X2-4
search filter icon
search icon
Document Information
Using This Documentation
1.  Determining Your Server Management Strategy
Common System Management Tasks
Server Management Software Benefits
Oracle Hardware Management Pack
Oracle Hardware Installation Assistant
Server Management Downloads and Documentation
2.  Oracle ILOM 3.1 Documentation
Oracle ILOM 3.1 Documentation Collection
3.  Oracle ILOM Features for the Sun┬áServer X2-4
Sun Server X2-4 Supported Firmware
Oracle ILOM 3.1 Features Supported on All Servers
Oracle ILOM 3.1 Features Supported on Oracle x86 Servers
Sideband Management
Power Control Policies
Local Host Interconnect Management Connection
Diagnostics Using Pc-Check and NMI
Control Next Boot Device
FRU TLI Auto-Update
Switch Serial Port Output to Host Management Console
Administer Open Problems and Clear Server Faults
Oracle ILOM 3.1 Features Not Supported on Sun Server X2-4
4.  Sensors and Indicators Reference Information
System Components
System Indicators
Temperature Sensors
Power Supply Fault Sensors
Fan Speed and Physical Security Sensors
Power Supply Unit Current, Voltage, and Power Sensors
Entity Presence Sensors
SNMP and PET Message Reference Information
SNMP Traps
PET Event Messages
5.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Request Physical Media (By Phone)
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
Index
Each system management tool has unique capabilities, but some of the functions of the tools overlap. You can use each tool independently, or, depending on your platform, you can use the tools together for more comprehensive system management. Each system management tool is freely available.
The following table gives examples of common system management tasks that you can perform with the available system management tools.
Task
Oracle ILOM
Update BIOS firmware.
Yes
Yes
Yes
Update Oracle ILOM firmware.
Yes
Yes
Yes
Configure Oracle ILOM.
Yes
Yes
Yes
Update HBA firmware.
Yes
No
Yes
Update expander firmware.
Yes
No
Yes
Install Windows operating system and drivers.
Yes
No
No
Install Linux operating system and drivers.
Yes
No
No
Install Oracle VM software and drivers.
Yes
No
No
Monitor hardware components.
No
Yes
Yes
Configure RAID.
Yes
No
Yes
