Skip Navigation Links
Exit Print View
Sun Blade 6000 Virtualized 40 GbE Network Express Module
Product Notes
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Feedback
Support and Accessibility
Updates and Releases
Firmware Update Available
Enhancements
Product Compatibility Information
Supported Software and Firmware
Available Firmware and Software
Supported Operating Systems
Supported Drivers
Supported Hardware
Server and Storage Modules
Chassis and Midplane
Hardware and Networking Issues
sxge Device Corresponding to Port 1 Cannot Communicate with External Hosts in 40G or 1G Mode
CMM Minimum Version and CMM ILOM Upgrade Requirement (7046303)
Cannot Unload sxge When Interfaces are Unplumbed (7045733)
Workaround
Operating System Issues
Hot Plug is Not Supported by VMware
Workaround
PCI Correctable Errors Might Occur When Using NEM (7012350 and 7064505)
Hot Plug is Not Supported by Windows 2008 R2 with Sun Blade X6270 M2 and NEM (7050066)
Workaround
Sometimes sxge Ports Fail to Enumerate During Hot-plug with Sun Blade X6270 M2 Blades (7087921)
Oracle Solaris OS
Oracle Linux OS
Workaround
Oracle ILOM and LDOM Issues
ILOM Web GUI Reports Error: “Command Failed” (16092938)
Workaround
Highest Lane Number in show peu Output is Incorrect (7039713)
Unable to Access NEM by Clicking on Graphic from the CMM ILOM Web GUI (7099903)
Workaround
On SPARC T3-1B blades running Oracle Solaris 10 (09/10) or (08/11), sxge module cannot be unloaded even when all sxge interfaces are unplumbed.
