Skip Navigation Links | |
Exit Print View | |
Sun Blade 6000 Virtualized 40 GbE Network Express Module Product Notes |
Product Compatibility Information
Supported Software and Firmware
Available Firmware and Software
Hardware and Networking Issues
CMM Minimum Version and CMM ILOM Upgrade Requirement (7046303)
Cannot Unload sxge When Interfaces are Unplumbed (7045733)
Hot Plug is Not Supported by VMware
PCI Correctable Errors Might Occur When Using NEM (7012350 and 7064505)
Hot Plug is Not Supported by Windows 2008 R2 with Sun Blade X6270 M2 and NEM (7050066)
Sometimes sxge Ports Fail to Enumerate During Hot-plug with Sun Blade X6270 M2 Blades (7087921)
ILOM Web GUI Reports Error: “Command Failed” (16092938)
Highest Lane Number in show peu Output is Incorrect (7039713)
Unable to Access NEM by Clicking on Graphic from the CMM ILOM Web GUI (7099903)
In 40GbE or 1GbE mode, blades in a C10 chassis can communicate with each other over sxge interfaces corresponding to both ports. They cannot communicate with external hosts over the sxge interface corresponding to port-1.
To allow blade-to-blade communication over port 1, execute the following command at the NEM CLI:
set port 1 -l up
In 10GbE mode, the blades can communicate with each other as well as external hosts over the sxge interfaces corresponding to both ports.
