Skip Navigation Links
Exit Print View
Configuring Oracle Java CAPS Master Indexes (Repository)     Java CAPS Documentation
search filter icon
search icon
Document Information
Related Topics
Master Index Configuration Overview (Repository)
About the Master Index Configuration Files (Repository)
Object Definition
Candidate Select
Match Field
Threshold
Best Record
Field Validation
Security
Enterprise Data Manager
Modifying the Master Index XML Files Directly (Repository)
Using the Master Index Configuration Editor-Repository
Object Definition File
Candidate Select File
Threshold File
Match Field File
Best Record File
Field Validation File
Enterprise Data Manager File
Match Configuration File (matchConfigFile.cfg)
Maintaining Version Control in the Master Index (Repository) Configuration Files
Checking Configuration Files Out With the Configuration Editor-Repository
Checking Configuration Files In With the Configuration Editor-Repository
Working With the XML Editor
Saving a Configuration File to the Repository
Validating XML Files
Copying, Cutting, and Pasting Files
Configuring the Master Index Object Structure (Repository)
Adding an Object to the Master Index Object Structure (Repository)
To Add an Undefined Object (Configuration Editor)
To Add a Predefined Object (Configuration Editor)
To Add an Undefined Object (XML editor)
Modifying an Object's Name In the Master Index Object Definition (Repository)
To Modify an Object's Name (Configuration Editor)
To Modify an Object's Name (XML Editor)
Deleting an Object From the Master Index Object Structure (Repository)
To Delete an Object (Configuration Editor)
To Delete an Object (XML Editor)
Adding a Field to the Master Index Object Structure (Repository)
To Add a Field (Configuration Editor)
To Add a Field (XML Editor)
Deleting a Field from the Master Index Object Structure (Repository)
To Delete a Field (Configuration Editor)
To Delete a Field (XML Editor)
Modifying Master Field Properties (Repository)
To Modify Field Properties (Configuration Editor)
To Modify Field Properties (XML Editor)
Defining Relationships Between Master Index Objects (Repository)
To Define Object Relationships (XML Editor)
Master Index Field Properties and Name Restrictions (Repository)
Master Index Field Name Restrictions (Repository)
Master Index Configuration Editor Field Properties (Repository)
Master Index Field Property Elements (Repository)
Creating a Master Index Basic Query (Repository)
To Create a Basic Query (Configuration Editor)
To Create a Basic Query (XML Editor)
Master Index Query Builder Dialog Box Fields and XML Elements (Repository)
Creating Master Index Blocking Queries (Repository)
To Create a Blocking Query (Configuration Editor)
To Create a Blocking Query (XML Editor)
Master Index Query Block Fields and XML Elements (Repository)
Modifying Master Index Queries (Repository)
Modifying a Master Index Query (Repository)
To Modify a Basic Query (Configuration Editor)
To Modify a Query (XML Editor)
Adding a Query Block to a Master Index Query (Repository)
To Add a Query Block (Configuration Editor)
To Add a Query Block (XML Editor)
Modifying a Query Block for a Master Index Query (Repository)
To Modify a Query Block (Configuration Editor)
To Modify a Query Block (XML Editor)
Deleting a Query Block From a Master Index Query (Repository)
To Delete a Query Block (Configuration Editor)
To Delete a Query Block (XML Editor)
Deleting a Master Index Query (Repository)
To Delete a Query (Configuration Editor)
To Delete a Query
Configuring Master Index Processing Options (Repository)
Specifying Master Index Custom Logic Classes (Repository)
To Specify Custom Logic for External System Messages
To Specify Custom Logic for the Enterprise Data Manager
Specifying the Master Index Update Mode (Repository)
To Specify Potential Duplicates be Reevaluated at Each Update
To Specify Potential Duplicates not be Reevaluated at Each Update
Configuring Master Index Merged Record Updates (Repository)
To Allow Merged Record Updates
To Prevent Merged Record Updates
Specifying the Master Index Blocking Query for Matching (Repository)
To Specify the Blocking Query for Matching
Setting Master Index Blocking Query Options (Repository)
To Set Blocking Query Options
Configuring Matching Parameters (Repository)
Specifying the Master Index Decision Maker Class (Repository)
To Specify the Decision Maker Class
Defining How to Handle Multiple Assumed Matches (OneExactMatch) (Repository)
To Create Potential Duplicates When Multiple Records Match
To Match the Highest Weighted Records When Multiple Records Match
Specifying Whether Same System Matches are Allowed (SameSystemMatch) (Repository)
To Allow Same System Records to be Automatically Merged
To Prevent Same System Records From Being Automatically Merged
Specifying the Master Index Duplicate Threshold (Repository)
To Specify the Duplicate Threshold (Configuration Editor)
To Specify the Duplicate Threshold (XML Editor)
Specifying the Master Index Match Threshold (Repository)
To Specify the Match Threshold (Configuration Editor)
To Specify the Match Threshold (XML Editor)
Adding and Deleting Master Index Decision Maker Parameters (Repository)
To Add a New Decision Maker Parameter
To Delete a Decision Maker Parameter
Configuring Master Index EUIDs (Repository)
Specifying the Master Index EUID Generator Class (Repository)
To Specify the EUID Generator Class
Specifying the Master Index EUID Length (Repository)
To Specify the EUID Length
Specifying a Master Index Checksum Length (Repository)
To Specify a Checksum Length
Specifying the Master Index Chunk Size (Repository)
To Specify the Chunk Size
Adding and Deleting Master Index EUID Generator Parameters (Repository)
To Add EUID Generator Parameters
To Delete EUID Generator Parameters
Defining Master Index Normalization Rules (Repository)
Defining a Master Index Field to be Normalized (Repository)
To Define a Field to be Normalized (Configuration Editor)
To Define a Field to be Normalized (XML Editor)
Master Index Normalization and Standardization Structure Properties (Repository)
Master Index Locale Codes Properties (Repository)
Modifying a Master Index Normalization Definition (Repository)
To Modify a Normalization Definition (Configuration Editor)
To Modify a Normalization Structure (XML Editor)
Deleting a Master Index Normalization Definition (Repository)
To Delete a Normalization Definition
To Delete a Normalization Structure
Defining Master Index Standardization Rules (Repository)
Defining Master Index Fields to be Standardized (Repository)
To Define Fields to be Standardized (Configuration Editor)
To Define Fields to be Standardized (XML Editor)
Master Index Standardization Source and Target Field Elements (Repository)
Modifying a Master Index Standardization Definition (Repository)
To Modify a Standardization Definition (Configuration Editor)
To Modify a Standardization Definition (XML Editor)
Deleting a Master Index Standardization Definition (Repository)
To Delete a Standardization Definition (Configuration Editor)
Defining Phonetic Encoding for the Master Index (Repository)
Defining Master Index Fields for Phonetic Encoding (Repository)
To Define a Field for Phonetic Encoding (Configuration Editor)
To Define a Field for Phonetic Encoding (XML Editor)
Master Index Phonetic Encoding Fields and Elements (Repository)
Modifying a Master Index Phonetic Encoding Definition (Repository)
To Modify a Phonetic Encoding Definition (Configuration Editor)
To Modify a Phonetic Encoding Definition (XML Editor)
Deleting a Master Index Phonetic Encoding Definition (Repository)
To Delete a Phonetic Encoding Definition (Configuration Editor)
To Delete a Phonetic Encoding Definition (XML Editor)
Defining a Master Index Phonetic Encoder (Repository)
To Define a Phonetic Encoder (Configuration Editor)
To Define a Phonetic Encoder (XML Editor)
Master Index Encoder Elements and Types (Repository)
Modifying a Master Index Phonetic Encoder (Repository)
To Modify a Phonetic Encoder (Configuration Editor)
To Modify a Phonetic Encoder (XML Editor)
Deleting a Master Index Phonetic Encoder (Repository)
To Delete a Phonetic Encoder (Configuration Editor)
To Delete a Phonetic Encoder (XML Editor)
Defining the Master Index Match String (Repository)
Creating the Master Index Match String (Repository)
To Create the Match String (Configuration Editor)
To Create the Match String (XML Editor)
Modifying the Master Index Match String (Repository)
To Modify the Match String (Configuration Editor)
To Modify the Match String (XML Editor)
Defining how Master Index Query Blocks are Processed (Repository)
To Specify the Block Picker
To Specify the Pass Controller Class
Defining the Master Index Survivor Calculator (Repository)
Specifying the Master Index Survivor Helper (Repository)
To Specify the Survivor Helper
Specifying a Master Index Default Survivor Strategy (Repository)
To Specify a Default Survivor Strategy
Configuring the Default Survivor Strategy
Master Index Default Survivor Strategy Parameter Elements (Repository)
Defining the Master Index Single Best Record Structure (Repository)
To Specify a Candidate Field
Deleting Candidate Fields
Defining a Master Index Survivor Strategy for a Field or Object (Repository)
To Define a Survivor Strategy for a Field
Defining Master Index Custom Weighted Strategies (Repository)
Defining Custom Weighted Strategies
Configuring Weighted Strategies
Modifying Weighted Calculator Parameters
Deleting Weighted Calculator Parameters
Master Index Weighted Calculator Parameter Elements (Repository)
Configuring Master Index Update Policies (Repository)
Defining Master Index Update Policies (Repository)
To Define Update Policies
Setting the Master Index Update Policy Flag (Repository)
To Set the Update Policy Flag
Defining Custom Field Validations for the Master Index (Repository)
To Implement a Validation Rule
Configuring the Match Engine (Repository)
Specifying a Match Engine for the Master Index (Repository)
To Configure the Match Engine
Configuring the Comparison Functions for a Master Index Application (Repository)
To Configure the Comparison Functions (Configuration Editor)
To Configure the Comparison Functions (Text Editor)
Match Comparator Configuration Properties for Oracle Java CAPS Master Index (Repository)
Configuring the Standardization Engine (Repository)
Specifying a Standardization Engine for the Master Index (Repository)
To Specify the Standardization Engine
Modifying Master Index Standardization Files (Repository)
To Modify Standardization Data Configuration Files
Loading Standardization Files to a Master Index Application (Repository)
To Load Standardization Files
Configuring the Master Index EDM Appearance (Repository)
Adding Objects to the EDM
To Add an Object to the EDM
Modifying EDM Objects
To Modify an EDM Object
Deleting Objects From the EDM
To Delete an Object
Adding Fields to the EDM
To Define New Fields
EDM Field Configuration Elements
Removing Fields From the EDM
To Remove a Field From the EDM
Modifying EDM Field Display Options
To Modify a Field's Display Options
Specifying a Drop-Down List for an EDM Field
To Specify a Drop-Down List
Specifying an EDM Field's Length and Format
To Modify a Field's Length and Format
Modifying an EDM Field's Data Type
To Modify the Data Type
Defining Key Fields for an Object (Repository)
To Modify the Key Status
Masking Field Values on the EDM
To Mask Field Values on the EDM
Defining EDM Object Relationships (Repository)
To Define Relationships
Defining EDM Local ID Labels (Repository)
To Define Local ID Labels
Configuring the Master Index EDM Search Pages (Repository)
Specifying Standard EDM Search Page Properties (Repository)
To Specify Standard Search Page Properties
Creating a Search Page for the EDM (Repository)
Step 1: Define the Search Page
Step 2: Define the Search Fields
Step 3: Specify Search Options
EDM Search Page Definition Elements
EDM Search Field Definition Elements
EDM Search Option Elements
Modifying a Search Page on the EDM (Repository)
Modifying a Search Page Definition
Modifying Search Fields
Modifying Search Options
Configuring Master Index EDM Page Layouts (Repository)
Specifying the Initial View for the EDM (Repository)
To Specify the Initial View
Configuring the EDM Search Results Page (Repository)
To Configure the Search Results Page
Configuring the EDM View/Edit Page (Repository)
To Configure the View/Edit Page
Configuring the EDM Create System Record Page (Repository)
To Configure the Create EO Page
Configuring the EDM History Page (Repository)
To Configure the History Page
Configuring the EDM Match Review Page (Repository)
To Configure the Match Review Page
Configuring the EDM Reports and Reports Page (Repository)
Configuring the Reports Page
Configuring Reports
EDM Reports and Reports Page Configuration Elements (Repository)
Configuring the EDM Audit Log Pages (Repository)
To Configure the Audit Log Pages
Configuring Master Index EDM Implementation Information (Repository)
Specifying the Master Controller JNDI Class (Repository)
To Specify the Master Controller JNDI Class
Specifying the Master Index Report Generator JNDI Class (Repository)
To Specify the Report Generator JNDI Class
Specifying Master Index Validation Services (Repository)
To Specify the Validation Service
Setting Master Index Debug Options (Repository)
To Set Debug Options
Specifying a Master Index Field Masking Class (Repository)
To Specify a Field Masking Class
The Decision Maker is configured in the Threshold file and defines how to handle certain decision points in the matching process, such as weight thresholds, how to handle multiple records above the match threshold, and whether records originating from the same system can be automatically matched.
You can customize the Decision Maker by performing any of the following actions:
If you create your own Decision Maker class, you can specify the new class to be used by changing the value of the decision-maker-class element.
  1. In the Projects window, expand the Configuration node in the project you want to modify, and then double-click the Threshold file.
  2. Scroll to the DecisionMakerConfig element.
  3. Change the value of the decision-maker-class element to the path and name of the new Decision Maker class.
    For example:
    <decision-maker-class>com.stc.eindex.decision.impl.MyDecisionMaker
    </decision-maker-class>
  4. Save and close the file.
The OneExactMatch parameter determines how records above the match threshold are processed. This parameter can only be modified directly in the XML file. For more information, see Threshold Configuration (Repository) in Understanding Oracle Java CAPS Master Index Configuration Options (Repository) and Understanding Master Index Operational Processes (Repository) in Understanding Oracle Java CAPS Master Index Processing (Repository).
  2. Scroll to the OneExactMatch element in the DecisionMakerConfig element.
  3. Change the value of the parameter-value element to true.
    For example:
    <parameter>
       <parameter-name>OneExactMatch</parameter-name>
     <parameter-type>java.lang.Boolean</parameter-type>
     <parameter-value>true</parameter-value>
    </parameter>
  3. Change value of the parameter-value element to false.
    For example:
    <parameter>
     <parameter-value>false</parameter-value>
    </parameter>
The SameSystemMatch parameter determines whether two records with local IDs from the same system can be merged automatically. If your local systems contain reliable data, and rarely duplicate their own records, set this parameter to true. This parameter can only be modified directly through the XML file.
  2. Scroll to the SameSystemMatch element in the DecisionMakerConfig element.
  3. Change the value of the parameter-value element to false.
    For example:
    <parameter>
     <parameter-name>SameSystemMatch</parameter-name>
    </parameter>
    For example:
    <parameter>
    </parameter>
The duplicate threshold is the lowest matching probability weight at which two records are considered potential duplicates of one another. Any records with lower probability weights are not considered to be possible matches. Any records between the duplicate and match thresholds are flagged as potential duplicates, and must be resolved manually. You can configure the duplicate threshold by using the Configuration Editor or by modifying the XML file directly.
  1. In the Projects window, right-click the master index application you want to modify, and then click Open.
  2. If the Configuration Editor dialog box appears, click Edit to check out the listed files.
    The Configuration Editor appears.
  3. Click the Matching tab.
  4. In the Duplicate Threshold field, enter the lowest weight at which two records should be considered a potential match.
    Note - This value can be any float value lower than the match threshold but higher than the lowest possible matching probability weight.
  5. On the Configuration Editor toolbar, click Save.
  2. Scroll to the DuplicateThreshold element in the DecisionMakerConfig element.
  3. Change the value of the parameter-value element. For example:
    <parameter>
       <parameter-name>DuplicateThreshold</parameter-name>
       <parameter-type>java.lang.Float</parameter-type>
       <parameter-value>7.9</parameter-value>
    </parameter>
The match threshold specifies the matching probability weight at which two records will be automatically merged, depending on the value of the OneExactMatch parameter and the number of records at or above the match threshold. You can configure the match threshold by using the Configuration Editor or by modifying the XML file directly.
  4. In the Match Threshold field, enter the lowest weight at which two records should be considered a match.
    Note - This value can be any float value higher than the duplicate threshold but lower than the highest possible matching probability weight.
  2. Scroll to the MatchThreshold element in the DecisionMakerConfig element.
    For example:
    <parameter>
       <parameter-name>MatchThreshold</parameter-name>
       <parameter-value>28.5</parameter-value>
    </parameter>
New parameters cannot be used with the default Decision Maker class and existing parameters should not be deleted. If you create a custom Decision Maker class, you might need to add new parameters or delete existing ones for the new class. You can only perform these tasks by modifying the XML file directly.
  3. Create a parameter element inside the parameters element, but outside any existing parameter elements. Define the following elements:
    • parameter-name – The name of the parameter.
    • parameter-type – The type of parameter. Valid values are java.lang.Long, java.lang.Short, java.lang.Byte, java.lang.String, java.lang.Integer, java.lang.Boolean, java.lang.Double, or java.lang.Float.
    • parameter-value – The value of the parameter.
      For example:
      <parameters>
         <parameter>
         </parameter>
         <parameter>
            <parameter-name>MaxDuplicates</parameter-name>
            <parameter-value>5</parameter-value>
         </parameter>
      </parameters>
  3. To delete one parameter, remove all text between and including the parameter element.
    For example, to delete the ExtensiveSearch parameter in the following sample, you would delete the boldface text.
    <parameters>
       <parameter>
       </parameter>
       <parameter>
          <parameter-name>ExtensiveSearch</parameter-name>
       </parameter>
    </parameters>
  4. To remove all parameters, remove all text between and including the starting and ending parameters element.
  5. Save and close the file.
