Skip Navigation Links
Exit Print View
Understanding Oracle Java CAPS Master Index Configuration Options (Repository)     Java CAPS Documentation
search filter icon
search icon
Document Information
Related Topics
About Oracle Java CAPS Master Index (Repository)
Features of Oracle Java CAPS Master Index
Configuration Overview for Oracle Java CAPS Master Index (Repository)
About the Configuration Files for Oracle Java CAPS Master Index (Repository)
Master Index Object Definition File
Master Index Candidate Select File
Master Index Match Field File
Master Index Threshold File
Master Index Best Record File
Master Index Field Validation File
Master Index Security File
Master Index Enterprise Data Manager File
Match and Standardization Engine Configuration Files
Using the Editors for Oracle Java CAPS Master Index (Repository)
XML Editors
Configuration Editor - Repository
Master Index Object Definition Configuration (Repository)
Master Index Object Definition Components (Repository)
Master Index Object Definition Objects
Master Index Object Definition Fields
Master Index Object Definition Relationships
The Master Index Object Definition File (Repository)
Modifying the Master Index Object Definition
Object Definition File Description
Object Definition File Example
Candidate Select Configuration (Repository)
Query Builder Components (Repository)
Basic Queries in a Master Index (Repository)
Blocking Queries in a Master Index (Repository)
Phonetic Queries in a Master Index (Repository)
Range Searching (Repository)
The Candidate Select File (Repository)
Modifying the Candidate Select File
Candidate Select File Description
Candidate Select Example
Range Search Processing (Repository)
Basic Query Range Searching
Blocking Query Range Searching
Blocking Query Offset Values
Blocking Query Constants
Blocking Query Offset and Constant Combinations
Threshold Configuration (Repository)
Manager Service Components (Repository)
Custom Logic Classes
Update Mode
Merged Record Updates
Blocking Query
Decision Maker
EUID Generator
The Threshold File (Repository)
Modifying the Threshold File
Threshold File Description
Threshold File Example
Match Field Configuration (Repository)
Matching Service Components (Repository)
Standardization Configuration
Matching Configuration
Match and Standardization Engines
Block Picker and Pass Controller
Phonetic Encoders
Sample Standardization and Matching Sequence (Repository)
The Match Field File (Repository)
Modifying the Match Field File
Match Field File Description
Match Field File Example
Best Record Configuration (Repository)
The Survivor Calculator and the SBR (Repository)
Update Manager Components (Repository)
Survivor Helper
Survivor Helper Default Strategy
Survivor Helper Weighted Strategy
Survivor Helper Union Strategy
Weighted Calculator
Weighted Calculator SourceSystem Strategy
Weighted Calculator SystemAgreement Strategy
Weighted Calculator MostRecentModified Strategy
Update Manager Policies
Update Manager Update Policies
Update Manager Update Policy Flag
The Best Record File (Repository)
Modifying the Best Record File
Best Record File Description
Best Record File Example
Weighted Calculator Logic
Field Validation Configuration (Repository)
The Field Validation File (Repository)
Modifying the Field Validation File
Field Validation File Structure
Field Validation File Example
Enterprise Data Manager Configuration
About the EDM
EDM Configuration Components
Object and Field Properties
Relationships
Page Configurations
Audit Log
Local ID Labels
Search Page Configuration
Implementation Configuration
The Enterprise Data Manager File Structure
Modifying the Enterprise Data Manager File
Enterprise Data Manager File Description
Enterprise Data Manager File Example
Master Index Field Notations
ePath Notation
ePath Syntax
ePath Notation Example
Qualified Field Name Notation
Qualified Field Name Syntax
Qualified Field Name Example
Simple Field Name Notation
Simple Field Notation Syntax
Simple Field Notation Example
The configuration files use specific notations to define a specific field or a group of fields in an enterprise or system object. There are three different types of notations used by Oracle Java CAPS Master Index.
The following topics describe each type of notation used:
ePath Notation
In the Best Record file, an element path, called an ePath, is used to specify the location of a field or list of fields. ePaths are also used in the StandardizationConfig element of the Match Field file. An ePath is a sequence of nested nodes in an enterprise record where the most nested element is a data field or a list of data fields. ePaths allow you to retrieve and transform values that are located in the object tree.
ePath strings can be of four basic types:
A context node is specified when evaluating each ePath expression. The context is considered as the root node of the structure for evaluation.
These topics describe and illustrate how to form ePath strings:
ePath Syntax
The syntax of an ePath consists of three components: nodes, qualifiers, and fields, as shown below.
node{.node{”[”qualifier’]’}+}+.field
The following sample illustrates an object structure containing a system object from Site A with a local ID of 111. The object contains a first name, last name, and three addresses. Following the sample, there are several ePath examples that refer to various elements of this object structure along with a description of the data in the sample object structure referred by each ePath.
Enterprise
   SystemObject - A 111
      Person
         FirstName
         LastName
         -Address
            AddressType = Home
            Street = 800 Royal Oaks Dr.
            City = Monrovia
            State = CA
            PostalCode = 91016
         -Address
            AddressType = Office
            Street = 181 2nd Ave..
            City = Monrovia
            State = CA
            PostalCode = 91016
         -Address
            AddressType = Billing
            Street = 100 Grand Avenue
            City = El Segundo
            State = CA
            PostalCode = 90245
In the Candidate Select file and the MatchingConfig element of the Match Field file use qualified field names to specify the location of a field. This method defines a specific field and is not used to define a list of fields. A qualified field name is a sequence of nested nodes in an enterprise record where the most nested element is a data field.
There are two types of qualified field names.
The following topics describe and illustrate how to form qualified field name strings.
The syntax of a fully qualified field name is:
Enterprise.SystemSBR.parent_object.child_object.field_name
where parent_object refers to the name of the parent object in the index, child_object refers to the name of the child object that contains the field, and field_name is the full name of the field. If the parent object contains the field being defined, the child object is not required in the path.
The syntax of a qualified field name is:
The following sample illustrates an object structure that could be defined in the Object Definition file. The object contains a Person parent object, and Address and Phone child objects.
Person
   FirstName
   LastName
   DateOfBirth
   Gender
   -Address
      AddressType
      StreetAddress
      Street
      City
      State
      PostalCode
   -Phone
      PhoneType
      PhoneNumber
The following fully qualified field names are valid for the sample structure above.
The qualified field names that correspond with the fully qualified names listed above are:
In the Enterprise Data Manager file, simple field names are used to specify the location of a field that appears on the EDM. These are used in the GUI configuration section of the file. Simple field names define a specific field and are not used to define a list of fields. They include only the field name and the name of the object that contains the field. Simple field names allow you to define fields within the context of an object.
The following topics describe and illustrate how to form simple field notations:
The syntax of a simple field name is:
object.field_name
where object refers to the name of the object that contains the field being defined and field_name is the full name of the field.
Person
   FirstName
   LastName
   DateOfBirth
   Gender
   -Address
      AddressType
      StreetAddress
      Street
      City
      State
      PostalCode
   -Phone
      PhoneType
      PhoneNumber
The following simple field names are valid for the sample structure above.
