Skip Navigation Links
Exit Print View
Oracle Java CAPS BPEL Designer and Service Engine User's Guide     Java CAPS Documentation
search filter icon
search icon
Document Information
Overview
The JBI Runtime Environment
To View the Installed or Deployed JBI Components
The BPEL Designer
The BPEL Service Engine
The Composite Application Project
BPEL Designer and Service Engine Features
BPEL Service Engine Features
Supported WS-BPEL 2.0 Constructs
BPEL Service Engine and Oracle SOA Suite
Understanding the BPEL Module Project
Creating Sample Processes in the BPEL Designer
A Synchronous Sample Process
An Asynchronous Sample Process
Travel Reservation Service Sample
Creating a Sample BPEL Module Project
Navigating in the BPEL Designer
The BPEL Designer Window
The BPEL Editor Views
Cloning Document Views
Element Documentation and Report Generation
Creating Documentation for an Element
Generation a Report
The Navigator Window
XML View
Logical View
The Properties Window
Scrolling
Collapsing and Expanding Process Blocks in the Diagram
To Collapse and Expand a Process Block
Zooming In and Out of the Diagram
Printing BPEL Diagrams and Source Files
To Preview and Print a BPEL Diagram or Source File
To Customize Print Options
To Customize Page Settings
Creating a BPEL Module Project
Starting GlassFish
To Check the Status of the GlassFish V2 Application Server in the NetBeans IDE
To Register the GlassFish V2 Application Server with the NetBeans IDE
To Start the GlassFish V2 Application Server in the NetBeans IDE
Creating a new BPEL Module Project
To Create a BPEL Module Project
Creating the XML Schema and the WSDL Document
Creating a BPEL Process Using the BPEL Designer
To Create the BPEL Process
Creating a Composite Application Project
To Create a New Composite Application Project
Building and Deploying the Composite Application Project
To Build and Deploy the Composite Application Project
Testing the Composite Application
Test the HelloWorldApplication Composite Application Project
Summary
Developing a BPEL Process Using the Diagram
The BPEL Diagram
Configuring Element Properties in the Design View
Finding Usages of BPEL Components
To Find Usages of a BPEL Component
Saving Your Changes
The BPEL Designer Palette Elements
Drop-Zones
The Process Element
Adding BPEL Components to the Process
BPEL Process Properties
The Web Service Elements
Using the Invoke Element
Usage
Invoke Properties
Correlations
Using the Receive Element
Usage
Receive properties
Correlations
Using the Reply Element
Usage
Reply Properties
Correlations
Using the Partner Link Element
Partner Link Types and Roles
Usage
Partner Link Properties
Partner Link Layout
Dynamic Partner Links and Dynamic Addressing
The Basic Activities
Using the Assign Element
Usage
Assign Element Properties
Using the JavaScript Element
Usage
JavaScript Element Properties
Using the Validate Element
Usage
Validate Element Properties
Using the Empty Element
Usage
Empty Element Properties
Using the Wait Element
Usage
Wait Element Properties
Using the Throw Element
Usage
Throw Element Properties
Using the Rethrow Element
Usage
ReThrow Element Properties
Using the Exit Element
Usage
Exit Element Properties
Using the Compensate Element
Usage
Compensate Element Properties
Using the CompensateScope Element
Usage
CompensateScope Element Properties
The Structured Activities
Using the If Element
Usage
Adding an Else If Branch to the If Element
Adding an Else Branch to the If Element
Reordering Else If Branches
If Element Properties
Using the While Element
Usage
While Element Properties
Using the Repeat Until Element
Usage
Repeat Until Element Properties
Using the For Each Element
Usage
For Each Element Properties
Using the Pick Element
Usage
Adding an On Alarm branch
Pick Element Properties
Using the Flow Element
Usage
Adding Branches to the Flow Element
Changing the Order of Elements inside Flow
Flow Element Properties
Using the Sequence Element
Usage
Adding Child Activities to the Sequence
Changing the Order of Elements inside Sequence
Sequence Element Properties
Using the Scope Element
Usage
Variables
To Define a Variable
To Edit a Variable
Using the BPEL Mapper
About the BPEL Mapper
To Open the BPEL Mapper Window
Creating BPEL Mappings
To Create a Mapping Without Using any Functions
To Use a Function in a Mapping
To Delete a Link or Function in a Mapping
Working with Predicates
To Create a Predicate
To Edit a Predicate
To Delete a Predicate
XPath Function Reference
Operator
Boolean
String
Nodes
Number
Date & Time
BPEL
Mapping Examples
Assign Activity Scenario
If Activity Scenario
Predicate Scenario
Using Type Cast and Pseudo-Components
Type Cast
Pseudo-Component
Type Cast and Validation
Type Cast and Pseudo Component Limitations
Using Normalized Message Properties
Using Normalized Message Properties in a BPEL Process
Using Predefined Normalized Message Properties in a BPEL Process
To Use Predefined Normalized Message Properties in a BPEL Process
Adding Additional Normalized Message Properties to a BPEL Process
To Add a Normalized Message Property Shortcut to a BPEL Process
To Edit an NM Property Shortcut
To Delete an NM Property Shortcut
To Add a Normalized Message Property to a BPEL Process
BPEL Code Generation Using NM Properties
General Normalized Message Properties
Binding Component Specific Normalized Message Properties
Using Handlers
Using a Fault Handler
When to Use
Usage
Catch Element
Catch Element Properties
Catch All Element
Using an Event Handler
When to Use
Usage
On Event Element
Usage
On Alarm Element
On Alarm Element Properties
Using a Compensation Handler
When to Use
To Add a Compensation Handler to Scope or Invoke Elements
Using a Termination Handler
When to Use
To Add a Termination Handler to Scope or Process Elements
Using Correlation
Understanding Correlation. Using the Correlation Wizard
Elements That Use and Express Correlation
Defining Correlation Using the Correlation Wizard
Validation
Validation Criteria
Validation Types
Notifications
The Output window
The Design view
The Navigator window
BPEL Process Logging and Alerting
Defining Logging
To Log the Variable Value
To Set the Log Level for the BPEL Service Engine
To View the Log File
Defining Alerting
Configuring the BPEL Service Engine Runtime Properties
Accessing the BPEL Service Engine Runtime Properties
Runtime Property Descriptions
BPEL Service Engine Deployment Artifacts
Testing and Debugging BPEL Processes
Testing a BPEL Process
To Add a Test Case and Bind it to a BPEL Operation
To Set the Test Properties
To Customize Test Input
To Run the Test Cases
Looking at Test Case Results
Steps in Debugging BPEL Processes
Starting and Finishing a BPEL Debugging Session
Using Breakpoints to Debug BPEL Processes
Debugging Commands
To disable a breakpoint
Group operations over breakpoints
Monitoring Execution of BPEL Processes
BPEL Debugger Windows
Sessions Window
BPEL Process Instances Window
Correlation Sets and Faults information
Local Variables Window
Watches Window
BPEL Process Execution Window
BPEL Partner Links Window
BPEL Debugger Console Messages
Monitoring the BPEL Service Engine
Installing the BPEL Monitor API and Command Line Monitoring Tool
To Install the Monitoring Tool
Using the BPEL Monitor Command Line Tool
To Use the BPEL Monitor Command Line Tool
Command Usage Pattern
More Information
Configuring Quality of Service (QOS) Properties, Throttling, and Redelivery
Configuring the Quality of Service Properties
To Access the Config QOS Properties Editor
Configuring Message Throttling
Configuring an Endpoint for Throttling
Configuring Redelivery
Using Dynamic Partner Links and Dynamic Addressing
Using a Literal to Construct an Endpoint
Using an Existing Partner Link's Endpoint
Using an Incoming Message to Extract the Endpoint
Using a Database Query to Provide an Endpoint
Sending Service Endpoint References
Configuring Persistence for the BPEL Service Engine
Setting the JVM Classpath to the Database JDBC Drivers
To Set the GlassFish JVM Classpath Settings
Configuring the User and Database for Persistence
Derby (JavaDB)
Oracle
MySQL
Setting max_allowed_packet
Creating an XA Connection Pool and a JDBC Resource
To Create an XA Connection Pool
Create a New JDBC Resource
Creating a Non-XA Connection Pool and JDBC Resource
Enabling Persistence for the BPEL Service Engine
To Enable Persistence for the BPEL Service Engine
Truncating and Dropping Tables
Drop and Truncate Scripts
Configuring Failover for the BPEL Service Engine
Failover Considerations
BPEL BluePrints
Troubleshooting
Using BPEL Schemas Different from the BPEL 2.0 Specification
Service Endpoint Conflict
Relationship of Service Endpoint to Test Cases
Troubleshooting Port Numbers
GlassFish V2 Application Server HTTP Port
Travel Reservation Service Endpoint Conflict
Change URLs
Test Run
Test Run Failures
Disabling Firewalls when Using Servers
Required Correlation Set Usage is Not Detected by the Validation System
The proceeding sections describe the steps used to create a simple BPEL Module project. To demonstrate the procedures we are using the Synchronous sample project.
Accordingly, the typical procedure to follow when building a BPEL process is:
  1. Creating a new BPEL Module Project using the New Project wizard. Creating the BPEL module project also includes:
    1. Creating an XML Schema using the XSD Editor.
    2. Creating the WSDL Documents using the New WSDL Editor.
    3. Create the BPEL Processes using the BPEL Designer.
  2. Creating a Composite Application Project.
    When new projects are created using the sample projects that are included with GlassFish, the Composite Application projects are created automatically. When you create a project from scratch, you need to create the Composite Application project manually.
  3. Add JBI Modules to the Composite Application project.
  4. (Optional) Build the Composite Application project and make sure that the Application Server is started.
  5. Build and Deploy the Composite Application Project to the BPEL Service Engine.
  6. Test the BPEL Process.
    For sample processes, test cases are automatically created; for new projects, you need to create at least one test case.
  7. (Optional) Debug the BPEL process.
Starting GlassFish
The BPEL Service Engine starts together with GlassFish. Before deploying and performing test runs of a Composite Application project in the NetBeans IDE, make sure that the GlassFish Application Server is started.
  1. If the Services window is not visible, choose Window -> Services.
  2. In the Services window, expand the Servers node.
    The Servers node should contain a GlassFish V2 sub-node. If the GlassFish V2 node does not appear, go to To Register the GlassFish V2 Application Server with the NetBeans IDE:
    If a green arrow badge appears on the GlassFish V2 node, the server is running. If a green arrow badge does not appear, go to To Start the GlassFish V2 Application Server in the NetBeans IDE.
  2. In the Services window, right-click the Servers node and then select Add Server.
    The Add Server Instance dialog box opens.
  3. On the Choose Server page of the dialog box, select GlassFish V2 from the Server field.
  4. (Optional) In the Name field, change the default name for the server.
    The IDE uses this name to identify the server.
  5. Click Next.
    The Platform Location Folder page opens.
  6. In the Platform Location field, click Browse and select the installation location of the application server.
  7. Select the Register Local Default Domain radio button and click Next.
  8. Enter the user name and password for the domain's administrator.
    If you accepted the default values during the installation, the user name is admin and the password is adminadmin.
  9. Click Finish.
  1. In the Services window, right-click the GlassFish V2 node and choose Start.
  2. Wait for the following message to appear in the Output window:
    Application server startup complete.
    When the server is running, the IDE displays a green arrow badge on the GlassFish V2 node.
    The BPEL Service Engine is represented as sun-bpel-engine in the Services window of the IDE, under the GlassFish V2 -> JBI nodes.
The following sections use the Synchronous sample project, and provide step-by-step directions for creating a simple BPEL module project, using the Synchronous sample project.
  1. In the NetBeans IDE, choose File > New Project.
    The New Projects wizard appears.
  2. Under Categories, select Service Oriented Architecture.
  3. Under Projects, select BPEL Moduleand click Next.
    image:Image displays the New Project dialog box
  4. In the Name and Location page, enter the project name (for this example HelloWorld) and specify the project location or accept the defaults.
    image:Image displays the New BPEL Module dialog box
  5. Click Finish.
    The Projects window now contains a project node for the BPEL Module project.
    image:Image shows new BPEL module project in the Projects window
Generally, the steps used to create a BPEL module project are:
  1. Create a New BPEL Project
  2. Create the XML Schema or XSD file
  3. Create the WSDL Documents
  4. Create the BPEL Process
The XSD file (XML Schema) helps to define the projects message structure or operations. Complex message structures are defined in the XSD file and imported into the WSDL Document. The WSDL Documents define the interfaces for the project. The BPEL Designer enables you to graphically design your BPEL business process.
To create the XML Schema and WSDL Document for this tutorial, following the directions provided in Creating a “Hello World” Composite Application. After you have created the XML Schema and WSDL, return here.
Now that you have created your XML Schema and WSDL Document, you can create your BPEL process.
  1. In the Projects window, expand your BPEL module project node, right-click the Process Files node, and choose New -> BPEL Process.
    The New BPEL Process dialog box appears.
    image:Image shows the New BPEL Process dialog box
  2. Enter a name for the process file name (HelloWorldProcess for this example), and click Finish.
    The new BPEL file opens in the Design view of the BPEL Designer.
    If the Palette and Properties windows are not displayed in your current view, click Windows -> Reset Windows on the NetBeans menu.
    image:Image shows the NetBeans IDE displaying the Design view of the BPEL Designer
  3. Add a partner link to the BPEL Process.
    1. In the Projects window, expand your project's Process Files node and select the .wsdl file (Synchronous.wsdl for this example).
    2. Drag the WSDL file from the Projects window to the left side of the Design view canvas.
      The IDE provides visual prompts to show you where you can drop the selection.
      The BPEL Editor adds a partner link to the canvas.
      image:Image shows a new partner link added to the BPEL process in the BPEL Editor
  4. Add a Receive activity to the BPEL Process.
    1. From the Web Service section of the Palette window, select the Receive activity.
    2. Drag the Receive activity to the HelloWorldProcess process box in the Design view canvas, between the Process Start and the Process End activities.
      The Receive1 activity is added to the process box.
    3. Click the Receive1 activity's Edit icon.
      The Receive1 Property Editor appears.
    4. On the Main tab, change the value in the Name field to start.
    5. From the Partner Link drop-down list, choose PartnerLink1.
      The IDE populates the Operation field with NewWSDLOperation.
    6. Click the Create button next to the Input Variable Field.
      The New Input Variable dialog box appears.
    7. Click OK to accept the default values.
    8. Click OK to close the Receive1 Property Editor.
      The Design view displays the new connection between PartnerLink1 and the Start activity in the process box.
      image:Image shows the partner link connected to the new Start activity in the BPEL Editor
  5. Add a Reply activity to the BPEL Process.
    1. Select the Reply activity in the Web Service section of the Palette. Drag and drop the Reply to the prompt between the Start activity and the Process End activity in the process box on the design view canvas.
      A Reply1 activity is added to the design view canvas.
    2. Click the Reply1 activity's Edit icon.
      The Reply1 Property Editor appears.
    3. On the Main tab, change the value in the Name field to End.
    4. From the Partner Link drop-down list, choose PartnerLink1.
    5. To create anew output variable, make sure that Normal Response is selected, and click the Create button next to the Input Variable Field.
      The New Input Variable dialog box appears. Click OK to accept the default values.
    6. Click OK to close the Reply1 Property Editor.
      The Design view displays the new connection between the End activity in the process box and PartnerLink1.
      image:Image shows the new Start activity connected to the partner link in the BPEL Editor
  6. Add a Assign activity to the BPEL Process.
    1. Select the Assign activity in the Basic Activities section of the Palette. Drag and drop the Assign to the prompt between the Start activity and the End activity in the process box on the design view canvas.
      The Assign1 activity is added to the design view canvas.
    2. Select the Assign1 activity and click the Mapper button on the editors toolbar.
      The BPEL Mapper appears.
    3. Map the paramA node under Variables -> NewWSDLOperationIn -> inputType in the Output pane of the BPEL Mapper, to the paramA node under Variables -> NewWSDLOperationOut -> resultType in the Input pane of the Mapper. To do this, select the paramA node under Variables -> NewWSDLOperationIn -> inputType in the Output pane, and drag your cursor to the paramA node under Variables -> NewWSDLOperationOut -> resultType in the Input pane.
      This assignment copies the input statement into the output.
      image:Image shows the BPEL Mapper as described in context
  7. To save your changes click the Save All icon in the IDE menu bar.
A BPEL Module project is not directly deployable. You must first add a BPEL Module project, as a JBI module, to a Composite Application project. You can then deploy the Composite Application project. Deploying the project makes the service assembly available to the application server and enables its service units to run.
  1. Choose File > New Project (Ctrl-Shift-N).
  2. In the Categories list choose Service Oriented Architecture, in the Projects list choose Composite Application, and click Next.
  3. In the Name and Location page, change the project name to HelloWorldApplication, and specify the location of project files.
  4. To set the new Composite Application the main project as main, leave the Set as Main Project checkbox selected, and click Finish.
  5. To add the BPEL Module as a JBI module to the Composite Application project, right-click the new Composite Application and choose Add JBI Module.
    The Select Project dialog box opens.
  6. Select the HelloWorld project you created earlier and click Add Project JAR Files.
    The Select Project dialog box closes and the HelloWorld.jar file is added to the JBI Modules node of the HelloWorldApplication Composite Application
Building a project compiles the BPEL source file and packages the BPEL file and web service artifacts, including WSDL and XSD files, into a JAR archive. Deploying the project compiles the files in the Composite Application project, packages the compiled BPEL and related web service artifacts (including WSDL and XSD files) into an archive, and deploys them to the Application Server.
  1. Right-click the Composite Application project's node, and choose Build.
    When the build is complete the Output window reports Build Successful. If the Output window is not visible, choose Window -> Output -> Output.
  2. Right-click the Composite Application project's node, and choose Deploy.
  3. Deployment has succeeded when you see a Build successful message in the GlassFish tab of the Output window.
  4. Open the Services window and expand Servers -> GlassFish V2 -> JBI -> Service Assemblies to see your new deployed Service Assembly.
    If you do not see the deployed project, right-click the Service Assemblies node and choose Refresh.
    image:Image shows the new Service Assembly in the Services window as described in context
You can test your Composite Application project by adding test cases, binding to the operation, supplying input, and then using the tester.
  1. In the Projects window, expand the HelloWorldApplication project node, right-click the Test node, and choose New Test Case.
    The New Test Case wizard opens.
  2. Accept the default test case name, TestCase1, and click Next.
  3. From the Select the WSDL Document page, expand the HelloWorld - Process Files node, select Synchronous.wsdl, and click Next.
  4. From the Select the Operation to Test page, select the Operation1 and click Finish.
    A new TestCase1 node is added under the project's Test node in the Projects window, containing two sub-nodes, Input and Output.
    The Source Editor appears containing the Input file, Input.xml
    Note - If the Source Editor does not contain a tab for Input.xml, double-click the Input node in the Projects window to open the file.
  5. From the Input.xml tab of the Source Editor, do the following:
    1. Locate the line:
      <syn:paramA>?string?<syn:paramA>
    2. Replace ?string? with Hello World, so that the line appears as follows:
      <syn:paramA>Hello World<syn:paramA>
    3. From the NetBeans IDE menu bar, click Save All.
    image:Image shows the Source Editor containing the Input.xml as described in context
  6. In the Projects window, double-click the Output node under Test -> TestCase1.
    Output.xml is opened in the Source Editor. Initially, Output.xml is empty until the first test run populates the file.
  7. In the Projects window, right-click the TestCase1 node and choose Run.
    When the Overwrite Empty Output dialog box appears, click Yes to accept new output. The first test run populates the Output.xml file displayed in the Source Editor.
    The test compares the output to the contents of the output file. Because the first run of the test has nothing to compare itself to, the first test fails. Subsequent test runs will compare their output with the contents of Output.xml and should succeed.
  8. Run the test again.
    The test case is compared to the current output file and succeeds.
Summary
You just created the HelloWorld, synchronous sample project. This sample project is available in the NetBeans IDE's samples file under Project/Samples/SOA/Synchronous BPEL Process.
This tutorial above demonstrates how to:
