Skip Navigation Links
Exit Print View
Oracle Java CAPS BPEL Designer and Service Engine User's Guide     Java CAPS Documentation
search filter icon
search icon
Document Information
The JBI Runtime Environment
To View the Installed or Deployed JBI Components
The BPEL Designer
The BPEL Service Engine
The Composite Application Project
BPEL Designer and Service Engine Features
BPEL Service Engine Features
Supported WS-BPEL 2.0 Constructs
BPEL Service Engine and Oracle SOA Suite
Understanding the BPEL Module Project
Creating Sample Processes in the BPEL Designer
A Synchronous Sample Process
An Asynchronous Sample Process
Travel Reservation Service Sample
Creating a Sample BPEL Module Project
Navigating in the BPEL Designer
The BPEL Designer Window
The BPEL Editor Views
Cloning Document Views
Element Documentation and Report Generation
Creating Documentation for an Element
Generation a Report
The Navigator Window
XML View
Logical View
The Properties Window
Collapsing and Expanding Process Blocks in the Diagram
To Collapse and Expand a Process Block
Zooming In and Out of the Diagram
Printing BPEL Diagrams and Source Files
To Preview and Print a BPEL Diagram or Source File
To Customize Print Options
To Customize Page Settings
Creating a BPEL Module Project
Starting GlassFish
To Check the Status of the GlassFish V2 Application Server in the NetBeans IDE
To Register the GlassFish V2 Application Server with the NetBeans IDE
To Start the GlassFish V2 Application Server in the NetBeans IDE
Creating a new BPEL Module Project
To Create a BPEL Module Project
Creating the XML Schema and the WSDL Document
Creating a BPEL Process Using the BPEL Designer
To Create the BPEL Process
Creating a Composite Application Project
To Create a New Composite Application Project
Building and Deploying the Composite Application Project
To Build and Deploy the Composite Application Project
Testing the Composite Application
Test the HelloWorldApplication Composite Application Project
Developing a BPEL Process Using the Diagram
The BPEL Diagram
Configuring Element Properties in the Design View
Finding Usages of BPEL Components
To Find Usages of a BPEL Component
Saving Your Changes
The BPEL Designer Palette Elements
The Process Element
Adding BPEL Components to the Process
BPEL Process Properties
The Web Service Elements
Using the Invoke Element
Invoke Properties
Using the Receive Element
Receive properties
Using the Reply Element
Reply Properties
Using the Partner Link Element
Partner Link Types and Roles
Partner Link Properties
Partner Link Layout
Dynamic Partner Links and Dynamic Addressing
The Basic Activities
Using the Assign Element
Assign Element Properties
Using the JavaScript Element
JavaScript Element Properties
Using the Validate Element
Validate Element Properties
Using the Empty Element
Empty Element Properties
Using the Wait Element
Wait Element Properties
Using the Throw Element
Throw Element Properties
Using the Rethrow Element
ReThrow Element Properties
Using the Exit Element
Exit Element Properties
Using the Compensate Element
Compensate Element Properties
Using the CompensateScope Element
CompensateScope Element Properties
The Structured Activities
Using the If Element
Adding an Else If Branch to the If Element
Adding an Else Branch to the If Element
Reordering Else If Branches
If Element Properties
Using the While Element
While Element Properties
Using the Repeat Until Element
Repeat Until Element Properties
Using the For Each Element
For Each Element Properties
Using the Pick Element
Adding an On Alarm branch
Pick Element Properties
Using the Flow Element
Adding Branches to the Flow Element
Changing the Order of Elements inside Flow
Flow Element Properties
Using the Sequence Element
Adding Child Activities to the Sequence
Changing the Order of Elements inside Sequence
Sequence Element Properties
Using the Scope Element
To Define a Variable
To Edit a Variable
Using the BPEL Mapper
About the BPEL Mapper
To Open the BPEL Mapper Window
Creating BPEL Mappings
To Create a Mapping Without Using any Functions
To Use a Function in a Mapping
To Delete a Link or Function in a Mapping
Working with Predicates
To Create a Predicate
To Edit a Predicate
To Delete a Predicate
XPath Function Reference
Date & Time
Mapping Examples
Assign Activity Scenario
If Activity Scenario
Predicate Scenario
Using Type Cast and Pseudo-Components
Type Cast
Type Cast and Validation
Type Cast and Pseudo Component Limitations
Using Normalized Message Properties
Using Normalized Message Properties in a BPEL Process
Using Predefined Normalized Message Properties in a BPEL Process
To Use Predefined Normalized Message Properties in a BPEL Process
Adding Additional Normalized Message Properties to a BPEL Process
To Add a Normalized Message Property Shortcut to a BPEL Process
To Edit an NM Property Shortcut
To Delete an NM Property Shortcut
To Add a Normalized Message Property to a BPEL Process
BPEL Code Generation Using NM Properties
General Normalized Message Properties
Binding Component Specific Normalized Message Properties
Using Handlers
Using a Fault Handler
When to Use
Catch Element
Catch Element Properties
Catch All Element
Using an Event Handler
When to Use
On Event Element
On Alarm Element
On Alarm Element Properties
Using a Compensation Handler
When to Use
To Add a Compensation Handler to Scope or Invoke Elements
Using a Termination Handler
When to Use
To Add a Termination Handler to Scope or Process Elements
Using Correlation
Understanding Correlation. Using the Correlation Wizard
Elements That Use and Express Correlation
Defining Correlation Using the Correlation Wizard
Validation Criteria
Validation Types
The Output window
The Design view
The Navigator window
BPEL Process Logging and Alerting
Defining Logging
To Log the Variable Value
To Set the Log Level for the BPEL Service Engine
To View the Log File
Defining Alerting
Configuring the BPEL Service Engine Runtime Properties
Accessing the BPEL Service Engine Runtime Properties
Runtime Property Descriptions
BPEL Service Engine Deployment Artifacts
Testing and Debugging BPEL Processes
Testing a BPEL Process
To Add a Test Case and Bind it to a BPEL Operation
To Set the Test Properties
To Customize Test Input
To Run the Test Cases
Looking at Test Case Results
Steps in Debugging BPEL Processes
Starting and Finishing a BPEL Debugging Session
Using Breakpoints to Debug BPEL Processes
Debugging Commands
To disable a breakpoint
Group operations over breakpoints
Monitoring Execution of BPEL Processes
BPEL Debugger Windows
Sessions Window
BPEL Process Instances Window
Correlation Sets and Faults information
Local Variables Window
Watches Window
BPEL Process Execution Window
BPEL Partner Links Window
BPEL Debugger Console Messages
Monitoring the BPEL Service Engine
Installing the BPEL Monitor API and Command Line Monitoring Tool
To Install the Monitoring Tool
Using the BPEL Monitor Command Line Tool
To Use the BPEL Monitor Command Line Tool
Command Usage Pattern
More Information
Configuring Quality of Service (QOS) Properties, Throttling, and Redelivery
Configuring the Quality of Service Properties
To Access the Config QOS Properties Editor
Configuring Message Throttling
Configuring an Endpoint for Throttling
Configuring Redelivery
Using Dynamic Partner Links and Dynamic Addressing
Using a Literal to Construct an Endpoint
Using an Existing Partner Link's Endpoint
Using an Incoming Message to Extract the Endpoint
Using a Database Query to Provide an Endpoint
Sending Service Endpoint References
Configuring Persistence for the BPEL Service Engine
Setting the JVM Classpath to the Database JDBC Drivers
To Set the GlassFish JVM Classpath Settings
Configuring the User and Database for Persistence
Derby (JavaDB)
Setting max_allowed_packet
Creating an XA Connection Pool and a JDBC Resource
To Create an XA Connection Pool
Create a New JDBC Resource
Creating a Non-XA Connection Pool and JDBC Resource
Enabling Persistence for the BPEL Service Engine
To Enable Persistence for the BPEL Service Engine
Truncating and Dropping Tables
Drop and Truncate Scripts
Configuring Failover for the BPEL Service Engine
Failover Considerations
BPEL BluePrints
Using BPEL Schemas Different from the BPEL 2.0 Specification
Service Endpoint Conflict
Relationship of Service Endpoint to Test Cases
Troubleshooting Port Numbers
GlassFish V2 Application Server HTTP Port
Travel Reservation Service Endpoint Conflict
Change URLs
Test Run
Test Run Failures
Disabling Firewalls when Using Servers
Required Correlation Set Usage is Not Detected by the Validation System
The section covers the following topics:
The Java Business Integration (JBI) runtime environment provides the runtime capability for SOA tools in the NetBeans IDE. The JBI runtime environment includes several components that interact using a services model. This model is based on Web Services Description Language (WSDL) 2.0. Components that supply or consume services within the JBI environment are referred to as Service Engines. One of these components is the The BPEL Service Engine that provides services for executing business processes. Components that provide access to services that are external to the JBI environment are called Binding Components.
JBI components are installed as part of the GlassFish application server, which is packaged with the NetBeans IDE.
  1. In the IDE, open the Services window, expand the GlassFish server node and expand the JBI node.
  2. If you do not see the JBI node, right-click the GlassFish server and select Start to start the application server.
image:Image shows the JBI nodes under the GlassFish in the NetBeans IDE Server window
For a detailed overview of the Java Business Integration concept and a description of JBI nodes, see the JBI Component Technical Overview.
The BPEL Designer
The BPEL Designer provides a highly-graphic framework that allows you to create and visualize business processes that are compliant with the WS-BPEL 2.0 specification. The BPEL Designer feature of the NetBeans IDE allows you to easily create and edit BPEL processes. These processes can then be executed by the BPEL Service Engine on the GlassFish Application Server.
The BPEL Designer consists of four editing windows called views:
The BPEL Service Engine provides runtime services for deploying BPEL processes. The BPEL Service Engine is used to execute WS-BPEL 2.0 (or simply BPEL) compliant business processes. WS-BPEL 2.0 (Web Services Business Process Execution Language) is an XML-based language used to program business processes.
Business processes typically involve the exchange, or orchestration, of messages between the process and other web services known as partner services. The contract between a business process and partner services is described in WSDL 1.1. The message exchange between a business process and partner services is wrapped in the WSDL 1.1 message wrapper, as defined by the JBI specification, and routed via the JBI Normalized Message Router (NMR). The NMR interacts with external web services, not resident on the local JVM, via binding components. Binding components are responsible for encapsulating protocol-specific details. Transactions between the BPEL Service Engine and collocated EJBs or web components are handled through the Java EE service engine.
WS-BPEL 2.0 utilizes several XML specifications: WSDL 1.1, XML Schema 1.0, XPath 1.0, and XSLT 1.0. Note that the JBI specification is targeted toward WSDL 2.0 and accommodates WSDL 1.1 by defining the wrapper. The BPEL Service Engine supports one-way, request-response operations (as defined in WSDL 1.1), within stateful, long-running interactions that involve two or more parties. Asynchronous request-response is accomplished using two one-way operations, one implemented by a partner, the other implemented by the business process using correlation.
The Composite Application project is used to create a Service Assembly that can be deployed to the Java Business Integration (JBI) runtime environment.
Within the Composite Application project, you can:
To deploy a Composite Application to the BPEL Service Engine, it must include a JBI module created from a BPEL Module project. Within a Composite Application Project that includes a JBI module, you can also create and execute test cases that can then be run against the deployed BPEL processes.
For more information about working with Composite Application projects, see Understanding the BPEL Module Project and Testing and Debugging BPEL Processes sections of this guide.
