Skip Navigation Links
Exit Print View
Oracle Java CAPS BPEL Designer and Service Engine User's Guide     Java CAPS Documentation
search filter icon
search icon
Document Information
The JBI Runtime Environment
To View the Installed or Deployed JBI Components
The BPEL Designer
The BPEL Service Engine
The Composite Application Project
BPEL Designer and Service Engine Features
BPEL Service Engine Features
Supported WS-BPEL 2.0 Constructs
BPEL Service Engine and Oracle SOA Suite
Understanding the BPEL Module Project
Creating Sample Processes in the BPEL Designer
A Synchronous Sample Process
An Asynchronous Sample Process
Travel Reservation Service Sample
Creating a Sample BPEL Module Project
Navigating in the BPEL Designer
The BPEL Designer Window
The BPEL Editor Views
Cloning Document Views
Element Documentation and Report Generation
Creating Documentation for an Element
Generation a Report
The Navigator Window
XML View
Logical View
The Properties Window
Collapsing and Expanding Process Blocks in the Diagram
To Collapse and Expand a Process Block
Zooming In and Out of the Diagram
Printing BPEL Diagrams and Source Files
To Preview and Print a BPEL Diagram or Source File
To Customize Print Options
To Customize Page Settings
Creating a BPEL Module Project
Starting GlassFish
To Check the Status of the GlassFish V2 Application Server in the NetBeans IDE
To Register the GlassFish V2 Application Server with the NetBeans IDE
To Start the GlassFish V2 Application Server in the NetBeans IDE
Creating a new BPEL Module Project
To Create a BPEL Module Project
Creating the XML Schema and the WSDL Document
Creating a BPEL Process Using the BPEL Designer
To Create the BPEL Process
Creating a Composite Application Project
To Create a New Composite Application Project
Building and Deploying the Composite Application Project
To Build and Deploy the Composite Application Project
Testing the Composite Application
Test the HelloWorldApplication Composite Application Project
Developing a BPEL Process Using the Diagram
The BPEL Diagram
Configuring Element Properties in the Design View
Finding Usages of BPEL Components
To Find Usages of a BPEL Component
Saving Your Changes
The BPEL Designer Palette Elements
The Process Element
Adding BPEL Components to the Process
BPEL Process Properties
The Web Service Elements
Using the Invoke Element
Invoke Properties
Using the Receive Element
Receive properties
Using the Reply Element
Reply Properties
Using the Partner Link Element
Partner Link Types and Roles
Partner Link Properties
Partner Link Layout
Dynamic Partner Links and Dynamic Addressing
The Basic Activities
Using the Assign Element
Assign Element Properties
Using the JavaScript Element
JavaScript Element Properties
Using the Validate Element
Validate Element Properties
Using the Empty Element
Empty Element Properties
Using the Wait Element
Wait Element Properties
Using the Throw Element
Throw Element Properties
Using the Rethrow Element
ReThrow Element Properties
Using the Exit Element
Exit Element Properties
Using the Compensate Element
Compensate Element Properties
Using the CompensateScope Element
CompensateScope Element Properties
The Structured Activities
Using the If Element
Adding an Else If Branch to the If Element
Adding an Else Branch to the If Element
Reordering Else If Branches
If Element Properties
Using the While Element
While Element Properties
Using the Repeat Until Element
Repeat Until Element Properties
Using the For Each Element
For Each Element Properties
Using the Pick Element
Adding an On Alarm branch
Pick Element Properties
Using the Flow Element
Adding Branches to the Flow Element
Changing the Order of Elements inside Flow
Flow Element Properties
Using the Sequence Element
Adding Child Activities to the Sequence
Changing the Order of Elements inside Sequence
Sequence Element Properties
Using the Scope Element
To Define a Variable
To Edit a Variable
Using the BPEL Mapper
About the BPEL Mapper
To Open the BPEL Mapper Window
Creating BPEL Mappings
To Create a Mapping Without Using any Functions
To Use a Function in a Mapping
To Delete a Link or Function in a Mapping
Working with Predicates
To Create a Predicate
To Edit a Predicate
To Delete a Predicate
XPath Function Reference
Date & Time
Mapping Examples
Assign Activity Scenario
If Activity Scenario
Predicate Scenario
Using Type Cast and Pseudo-Components
Type Cast
Type Cast and Validation
Type Cast and Pseudo Component Limitations
Using Normalized Message Properties
Using Normalized Message Properties in a BPEL Process
Using Predefined Normalized Message Properties in a BPEL Process
To Use Predefined Normalized Message Properties in a BPEL Process
Adding Additional Normalized Message Properties to a BPEL Process
To Add a Normalized Message Property Shortcut to a BPEL Process
To Edit an NM Property Shortcut
To Delete an NM Property Shortcut
To Add a Normalized Message Property to a BPEL Process
BPEL Code Generation Using NM Properties
General Normalized Message Properties
Binding Component Specific Normalized Message Properties
Using Handlers
Using a Fault Handler
When to Use
Catch Element
Catch Element Properties
Catch All Element
Using an Event Handler
When to Use
On Event Element
On Alarm Element
On Alarm Element Properties
Using a Compensation Handler
When to Use
To Add a Compensation Handler to Scope or Invoke Elements
Using a Termination Handler
When to Use
To Add a Termination Handler to Scope or Process Elements
Using Correlation
Understanding Correlation. Using the Correlation Wizard
Elements That Use and Express Correlation
Defining Correlation Using the Correlation Wizard
Validation Criteria
Validation Types
The Output window
The Design view
The Navigator window
BPEL Process Logging and Alerting
Defining Logging
To Log the Variable Value
To Set the Log Level for the BPEL Service Engine
To View the Log File
Defining Alerting
Configuring the BPEL Service Engine Runtime Properties
Accessing the BPEL Service Engine Runtime Properties
Runtime Property Descriptions
BPEL Service Engine Deployment Artifacts
Testing and Debugging BPEL Processes
Testing a BPEL Process
To Add a Test Case and Bind it to a BPEL Operation
To Set the Test Properties
To Customize Test Input
To Run the Test Cases
Looking at Test Case Results
Steps in Debugging BPEL Processes
Starting and Finishing a BPEL Debugging Session
Using Breakpoints to Debug BPEL Processes
Debugging Commands
To disable a breakpoint
Group operations over breakpoints
Monitoring Execution of BPEL Processes
BPEL Debugger Windows
Sessions Window
BPEL Process Instances Window
Correlation Sets and Faults information
Local Variables Window
Watches Window
BPEL Process Execution Window
BPEL Partner Links Window
BPEL Debugger Console Messages
Monitoring the BPEL Service Engine
Installing the BPEL Monitor API and Command Line Monitoring Tool
To Install the Monitoring Tool
Using the BPEL Monitor Command Line Tool
To Use the BPEL Monitor Command Line Tool
Command Usage Pattern
More Information
Configuring Quality of Service (QOS) Properties, Throttling, and Redelivery
Configuring the Quality of Service Properties
To Access the Config QOS Properties Editor
Configuring Message Throttling
Configuring an Endpoint for Throttling
Configuring Redelivery
Using Dynamic Partner Links and Dynamic Addressing
Using a Literal to Construct an Endpoint
Using an Existing Partner Link's Endpoint
Using an Incoming Message to Extract the Endpoint
Using a Database Query to Provide an Endpoint
Sending Service Endpoint References
Configuring Persistence for the BPEL Service Engine
Setting the JVM Classpath to the Database JDBC Drivers
To Set the GlassFish JVM Classpath Settings
Configuring the User and Database for Persistence
Derby (JavaDB)
Setting max_allowed_packet
Creating an XA Connection Pool and a JDBC Resource
To Create an XA Connection Pool
Create a New JDBC Resource
Creating a Non-XA Connection Pool and JDBC Resource
Enabling Persistence for the BPEL Service Engine
To Enable Persistence for the BPEL Service Engine
Truncating and Dropping Tables
Drop and Truncate Scripts
Configuring Failover for the BPEL Service Engine
Failover Considerations
BPEL BluePrints
Using BPEL Schemas Different from the BPEL 2.0 Specification
Service Endpoint Conflict
Relationship of Service Endpoint to Test Cases
Troubleshooting Port Numbers
GlassFish V2 Application Server HTTP Port
Travel Reservation Service Endpoint Conflict
Change URLs
Test Run
Test Run Failures
Disabling Firewalls when Using Servers
Required Correlation Set Usage is Not Detected by the Validation System
The following topics provide information to help you troubleshoot common business process issues:
Test Run Failures
This release of the BPEL Designer supports the BPEL 2.0 final specification and does not support previous specifications. This means that when you open the BPEL files that comply with the previous versions of the specification, the BPEL Designer shows the Unable to Show the Diagram message.
If you see this message, do the following:
When deploying two or more Composite Application projects, a service endpoint conflict might occur and the deployment fails. In case of the service endpoint conflict, the following message is displayed:
Deploy service assembly failed. (partial success)
MESSAGE: (SOAPBC_DEPLOY_2) Failed to deploy: java.lang.Exception:
An activated endpoint already has the same SOAP Address location:
Service assembly deployment failed.
BUILD FAILED (total time: 31 seconds)
This could typically arise from trying to deploy nearly identical processes that are packaged in different Composite Application projects. The workaround for this issue is to use different endpoints during the deployment of different Composite Application projects.
Explanation: Even though you are deploying distinct Composite Applications and distinct BPEL processes, by default they will have the same endpoint addresses defined in their SynchronousSample.wsdl files. They will both contain the following endpoint address:
<service name="service1">
   <port name="port1" binding="tns:binding1">
      <soap:address location="http://localhost:18181/SynchronousSample"/>
If you attempt to deploy two Composite Applications (for example, SynchronousSampleApplication and SynchronousSample1Application ) with identical service endpoints, the deployment of the second one will fail due to the endpoint conflict.
You may wish to deploy more than one version of a Composite Application because you want to modify one or both of these processes and deploy both of them at the same time. Or you may want to compare their behavior. To do this you must first make their endpoint addresses distinct. This means editing the process WSDL file and adjusting the soap:address location attribute so that there is no conflict. You can adjust either the port number or the service name. For example, either of these would be sufficiently distinct from the original:
<soap:address location="http://localhost:18182/SynchronousSample"/>
<soap:address location="http://localhost:18181/SynchronousSampleNew"/>
Each Test Case in the Composite Application project will attempt to send the input message to the target process when you invoke the Test action. In order to know where to send the message, each test case has a property called destination. You can modify this property in the Properties window. To invoke the Properties window, right-click the test case node and then select Properties.
The value of the destination property is set at the time the test case is created. So if you subsequently change the service endpoint you will need to manually adjust the destination attribute for any previously generated test cases. Newly generated test cases, of course, will be OK.
By default, the installer attempts to configure the Application Server's HTTP port to be 8080. Some of the sample processes assume the 8080 value. If for any reason, the Application Server's HTTP port is not 8080, you will have to make adjustments to the samples.
In particular, the Travel Reservation Service sample will require several adjustments.
Assume, for instance, that the Application Server is listening on HTTP port 8090 (not on the default 8080). In this case, you will have to do the following:
Adjust Reservation Partner Services WSDL files
  1. In the TravelReservationService BPEL Module project, change the soap address value in the AirlineReservationService.wsdl from
  2. Similarly, update the soap address values in VehicleReservationService.wsdl and
Note: To find out which HTTP port the Application Server is listening on, open the Services window, right-click the GlassFish V2 Application Server's node and choose View Admin Console. This opens the GlassFish V2 Application Server Administration Console in your browser. Type username and password (default values are admin/adminadmin) and log in. Click Application Server in the left pane and choose the General tab in the right pane. The HTTP port value you need is the first in the HTTP Port(s): line.
Alternatively, the port numbers are defined in the domain.xml file, located in appserver_home/domains/domain_name/config. Look for the http-listener elements. The ports are defined for http-listener-1, http-listener-2, and admin-listener. By default, these values are 8080, 8181, and 4848 respectively. http-listener-1 is the port the Application Server is listening on.
Refer to the Service Endpoint Conflict section above for a general description of the problem. In case of the Travel Reservation Service sample, however, you have to take these additional steps:
If port 18181 is not available, and if you want to run TRS on another port, such as port 19191, perform the following steps:
Change URLs
Open TravelReservationService.wsdl.
In the service tag change,
soap:address location="http://localhost:18181/TravelReservation/buildItinerary"/
soap:address location="http://localhost:19191/TravelReservation/buildItinerary"/
Similarly, update URL's for airlineReserved, hotelReserved and vehicleReserved.
Adjust the Partner EJB project, ReservationPartnerServices
Perform the following steps:
  1. In the IDE, open the ReservationPartnerServices project.
    (The IDE created the ReservationPartnerServices project in the location where you created the TravelReservationService project.)
  2. In the Projects window, expand the ReservationPartnerServices project node, expand the Configuration Files node, and then double-click the ejb-jar.xml node to open the file in the visual editor.
  3. In the Design view, under Enterprise Beans, click ReservationCallBackProviderMDB to expand the entry. Expand Bean Environment and then Environment Entries.
  4. Under Environment Entries, select each entry and click Edit to change the 18181 port number in the Entry Value field.
    For example, for AirlineCallbackURL, change
Update the Destination Property
In the TravelReservationServiceApplication Composite project expand the Test node. For each test case node under it:
  1. Right-click the test case node and choose Properties.
  2. In the Properties window, update the value of the Destination property.
    Change http://localhost:18181/TravelReservation/buildItinerary
Test Run
When executing a test case:
Test Run Failures
If you receive a failed test run, you can do one of the following:
One particular case of test run failures is related to tests that use content-based correlation embedded in Input.xml (for example, the Input.xml files in the Travel Reservation Service test cases have <UniqueID>...</UniqueID> as the basis for correlation). In this situation, if you run the test case when there is already a running process instance initiated by the same test case, the second process instance will not be initiated and the test will fail. The following message will appear in the GlassFish V2 Application Server log:
Exception occurred while executing a business process instance.
An instance is associated with the correlation
You might have to disable any firewall in order to successfully deploy run, debug, or test applications on the Application Server or business processes on the BPEL Server.
The BPEL service engine requires strict usage of correlation sets. Currently the validation system does not detect violations of the following requirements:
