Skip Navigation Links
Exit Print View
Oracle Java CAPS HTTP Binding Component User's Guide     Java CAPS Documentation
search filter icon
search icon
Document Information
Using the HTTP Binding Component
About the HTTP Binding Component
HTTP/SOAP Binding Architecture
HTTP Binding Component Features
Service Provider Features
Service Consumer Features
Security Features
HTTP Binding Component Example Scenario
Purchase Order Example
SOAP Processing
SOAP 1.1 WSDL Extensibility Elements
SOAP 1.1 Connectivity Element
SOAP 1.1 address Element
SOAP 1.1 Binding Elements
SOAP 1.1 binding Element
SOAP 1.1 operation Element
SOAP 1.1 body Element
SOAP 1.1 fault Element
SOAP 1.1 header and headerfault Elements
SOAP 1.2 WSDL Extensibility Elements
SOAP 1.2 Connectivity Element
SOAP 1.2 address Element
SOAP 1.2 Binding Elements
SOAP 1.2 binding Element
SOAP 1.2 operation Element
SOAP 1.2 body Element
SOAP 1.2 fault Element
SOAP 1.2 header and headerfault Elements
WS-I Basic Profile 1.1
HTTP Processing
HTTP WSDL Extensibility Elements
HTTP Connectivity Element
HTTP address Element
HTTP Binding Elements
HTTP binding Element
HTTP operation Element
HTTP urlEncoded Element
HTTP urlReplacement Element
HTTP GET and POST Processing
XML/HTTP GET Processing
Configuring the HTTP Binding Component for HTTP Get Interactions
Binding Details
http:binding Element
http:address Element
http:operation Element
http:urlEncoded Element
http:urlReplacement
Using the HTTP Binding Component with the HTTP POST Method
Binding Details
HTTP POST Treatment of http:urlEncoded and http:urlReplacement
HTTP Binding Component Runtime Properties
HTTP Binding Component Client Endpoint Properties
Accessing the HTTP Binding Component Client Endpoint Properties
HTTP BC Client Endpoint Configuration Properties
Using Normalized Message Properties to Propagate Binding Context Information
Using Normalized Message Properties in a BPEL Process
Using Predefined Normalized Message Properties in a BPEL Process
To use predefined normalized message properties in a BPEL process
Adding Additional Normalized Message Properties to a BPEL Process
To add a Normalized Message Property Shortcut to a BPEL process
To edit an NM Property Shortcut
To delete an NM Property Shortcut
To add a Normalized Message Property to a BPEL process
BPEL Code Generation Using NM Properties
SOAP HTTP Binding Component Specific Normalized Message Properties
Quality of Service (QOS) Features
Configuring the Quality of Service Properties
Message Throttling: Configuring and Using
Configuring the HTTP Binding Component Endpoint for Throttling
Redelivery: Configuring and Using
Using the Tango Web Service Features with the HTTP Binding Component
Configuring Reliable Message Delivery
Installing the Synchronous BPEL Process sample
Configuring Web Services for a Project from the CASA Editor
Configuring the Tango Web Services Attributes exposed by the HTTP Binding Component
Accessing the Tango (WSIT) Web Service Attribute Configuration
Accessing the WS-Policy Attachment Editor for a Specific Endpoint
Server Configuration--Web Service Attributes
Client Configuration -- Web Service Attributes
HTTP Binding Component Security
Using Basic Authentication with the HTTP Binding Component
Basic Authentication Supported Features
Authentication Mechanisms for Consumer Endpoints
WssTokenCompare Username/Password Authentication
Using the Access Manager for Authentication and Authorization
Installing the Access Manager Add-on
Installing Access Manager with Java Application Platform SDK
Configure the HTTP Binding Component to use Access Manager
Using the OpenSSO Web Services Security (WSS) Agent for Authentication and Authorization
Install OpenSSO Enterprise Server
Configure the HTTP Binding Component to use OpenSSO Web Service Security
Using the GlassFish Realm Security to Authenticate the HTTP Client Credentials
Configuring Security Mechanisms
Username Authentication with Symmetric Key
Mutual Certificates Security
Transport Security (SSL)
Message Authentication over SSL
SAML Authorization over SSL
Endorsing Certificate
SAML Sender Vouches with Certificates
SAML Holder of Key
STS Issued Token
STS Issued Token with Service Certificate
STS Issued Endorsing Token
Using Application Variables to Define Name/Value Pairs
Using Application Variables for password protection
Creating a password Application Variable
Using Application Configuration to Configure Connectivity Parameters
To apply a named Config Extension to the Application Configuration
Enhanced Logging
Statistics Monitoring
Using WS-Transaction
Clustering Support for the HTTP Binding Component
HTTP Load Balancer
Configuring the HTTP Binding Component for Clustering
Understanding the ${HttpDefaultPort} Token
Common User Scenarios
Validating HTTP Extensibility Elements from the WSDL Editor
Adding a SOAP Template to a WSDL Document
Adding an HTTP Template to a WSDL Document
Web Service Client Calling an Operation Using HTTP Basic Authentication
Web Service Implementing an Operation Protected by HTTP Basic Authentication
Web Service Client Calling an Operation Using SSL Authentication
Web Service Implements an Operation Protected by SSL Authentication
The HTTP Binding Component, acting as a service consumer, services HTTP requests or SOAP requests from HTTP clients, transforms (normalizes) them, and sends them to the normalized message router.
Service consumer features include:
