Skip Navigation Links
Exit Print View
Oracle Java CAPS Master Index Configuration Guide     Java CAPS Documentation
search filter icon
search icon
Document Information
Related Topics
Master Index Configuration Overview
About the Master Index Configuration Files
object.xml
query.xml
mefa.xml
master.xml
update.xml
filter.xml
validation.xml
security.xml
midm.xml
Modifying the Master Index XML Files Directly
Using the Master Index Master Index Configuration Editor
object.xml
query.xml
master.xml
mefa.xml
update.xml
validation.xml
midm.xml
Match Configuration File (matchConfigFile.cfg)
Maintaining Version Control in the Master Index Configuration Files
Copying, Cutting, and Pasting Files
Configuring the Master Index Object Structure
Adding an Object to the Master Index Object Structure
To Add an Undefined Object (Configuration Editor)
To Add a Predefined Object (Configuration Editor)
To Add an Undefined Object (XML editor)
Modifying an Object's Name In the Master Index Object Definition
To Modify an Object's Name (Configuration Editor)
To Modify an Object's Name (XML Editor)
Deleting an Object From the Master Index Object Structure
To Delete an Object (Configuration Editor)
To Delete an Object (XML Editor)
Adding a Field to the Master Index Object Structure
To Add a Field (Configuration Editor)
To Add a Field (XML Editor)
Deleting a Field from the Master Index Object Structure
To Delete a Field (Configuration Editor)
To Delete a Field (XML Editor)
Modifying Master Field Properties
To Modify Field Properties (Configuration Editor)
To Modify Field Properties (XML Editor)
Defining Relationships Between Master Index Objects
To Define Object Relationships (XML Editor)
Master Index Field Properties and Name Restrictions
Master Index Field Name Restrictions
Master Index Configuration Editor Field Properties
Master Index Field Property Elements
Creating a Master Index Basic Query
To Create a Basic Query (Configuration Editor)
To Create a Basic Query (XML Editor)
Master Index Query Builder Dialog Box Fields and XML Elements
Creating Master Index Blocking Queries
To Create a Blocking Query (Configuration Editor)
To Create a Blocking Query (XML Editor)
Master Index Query Block Fields and XML Elements
Modifying Master Index Queries
Modifying a Master Index Query
To Modify a Basic Query (Configuration Editor)
To Modify a Query (XML Editor)
Adding a Query Block to a Master Index Query
To Add a Query Block (Configuration Editor)
To Add a Query Block (XML Editor)
Modifying a Query Block for a Master Index Query
To Modify a Query Block (Configuration Editor)
To Modify a Query Block (XML Editor)
Deleting a Query Block From a Master Index Query
To Delete a Query Block (Configuration Editor)
To Delete a Query Block (XML Editor)
Deleting a Master Index Query
To Delete a Query (Configuration Editor)
To Delete a Query
Configuring Master Index Processing Options
Specifying Master Index Custom Logic Classes
To Specify Custom Logic for External System Messages
To Specify Custom Logic for the Master Index Data Manager
Specifying the Master Index Update Mode
To Specify Potential Duplicates be Reevaluated at Each Update
To Specify Potential Duplicates not be Reevaluated at Each Update
Configuring Master Index Merged Record Updates
To Allow Merged Record Updates
To Prevent Merged Record Updates
Specifying the Master Index Blocking Query for Matching
To Specify the Blocking Query for Matching
Setting Master Index Blocking Query Options
To Set Blocking Query Options
Defining Master Index Transactional Support
To Configure the Master Index for Local Transactions
To Configure the Master Index to Distributed Transactions Across Applications
To Configure the Master Index for Distributed Transactions Within the Master Index Application Only
Configuring Matching Parameters
Specifying the Master Index Decision Maker Class
To Specify the Decision Maker Class
Defining How to Handle Multiple Assumed Matches (OneExactMatch)
To Create Potential Duplicates When Multiple Records Match
To Match the Highest Weighted Records When Multiple Records Match
Specifying Whether Same System Matches are Allowed (SameSystemMatch)
To Allow Same System Records to be Automatically Merged
To Prevent Same System Records From Being Automatically Merged
Specifying the Master Index Duplicate Threshold
To Specify the Duplicate Threshold (Configuration Editor)
To Specify the Duplicate Threshold (XML Editor)
Specifying the Master Index Match Threshold
To Specify the Match Threshold (Configuration Editor)
To Specify the Match Threshold (XML Editor)
Adding and Deleting Master Index Decision Maker Parameters
To Add a New Decision Maker Parameter
To Delete a Decision Maker Parameter
Configuring Master Index EUIDs
Specifying the Master Index EUID Generator Class
To Specify the EUID Generator Class
Specifying the Master Index EUID Length
To Specify the EUID Length
Specifying a Master Index Checksum Length
To Specify a Checksum Length
Specifying the Master Index Chunk Size
To Specify the Chunk Size
Adding and Deleting Master Index EUID Generator Parameters
To Add EUID Generator Parameters
To Delete EUID Generator Parameters
Defining Master Index Normalization Rules
Defining a Master Index Field to be Normalized
To Define a Field to be Normalized (Configuration Editor)
To Define a Field to be Normalized (XML Editor)
Master Index Normalization and Standardization Structure Properties
Master Index Variants Properties
Modifying a Master Index Normalization Definition
To Modify a Normalization Definition (Configuration Editor)
To Modify a Normalization Structure (XML Editor)
Deleting a Master Index Normalization Definition
To Delete a Normalization Definition
To Delete a Normalization Structure
Defining Master Index Standardization Rules
Defining Master Index Fields to be Standardized
To Define Fields to be Standardized (Configuration Editor)
To Define Fields to be Standardized (XML Editor)
Master Index Standardization Source and Target Field Elements
Modifying a Master Index Standardization Definition
To Modify a Standardization Definition (Configuration Editor)
To Modify a Standardization Definition (XML Editor)
Deleting a Master Index Standardization Definition
To Delete a Standardization Definition (Configuration Editor)
Defining Phonetic Encoding for the Master Index
Defining Master Index Fields for Phonetic Encoding
To Define a Field for Phonetic Encoding (Configuration Editor)
To Define a Field for Phonetic Encoding (XML Editor)
Master Index Phonetic Encoding Fields and Elements
Modifying a Master Index Phonetic Encoding Definition
To Modify a Phonetic Encoding Definition (Configuration Editor)
To Modify a Phonetic Encoding Definition (XML Editor)
Deleting a Master Index Phonetic Encoding Definition
To Delete a Phonetic Encoding Definition (Configuration Editor)
To Delete a Phonetic Encoding Definition (XML Editor)
Defining a Master Index Phonetic Encoder
To Define a Phonetic Encoder (Configuration Editor)
To Define a Phonetic Encoder (XML Editor)
Master Index Encoder Elements and Types
Modifying a Master Index Phonetic Encoder
To Modify a Phonetic Encoder (Configuration Editor)
To Modify a Phonetic Encoder (XML Editor)
Deleting a Master Index Phonetic Encoder
To Delete a Phonetic Encoder (Configuration Editor)
To Delete a Phonetic Encoder (XML Editor)
Defining the Master Index Match String
Creating the Master Index Match String
To Create the Match String (Configuration Editor)
To Create the Match String (XML Editor)
Modifying the Master Index Match String
To Modify the Match String (Configuration Editor)
To Modify the Match String (XML Editor)
Defining how Master Index Query Blocks are Processed
To Specify the Block Picker
To Specify the Pass Controller Class
Defining the Master Index Survivor Calculator
Specifying the Master Index Survivor Helper
To Specify the Survivor Helper
Specifying a Master Index Default Survivor Strategy
To Specify a Default Survivor Strategy
Configuring the Default Survivor Strategy
Master Index Default Survivor Strategy Parameter Elements
Defining the Master Index Single Best Record Structure
To Specify a Candidate Field
Deleting Candidate Fields
Defining a Master Index Survivor Strategy for a Field or Object
To Define a Survivor Strategy for a Field
Defining Master Index Custom Weighted Strategies
Defining Custom Weighted Strategies
Configuring Weighted Strategies
Modifying Weighted Calculator Parameters
Deleting Weighted Calculator Parameters
Master Index Weighted Calculator Parameter Elements
Filtering Default Values From Master Index Processes
To Filter Default Values From the SBR, Blocking Query, or Match Process
Filter Definition Elements
Configuring Master Index Update Policies
Defining Master Index Update Policies
To Define Update Policies
Setting the Master Index Update Policy Flag
To Set the Update Policy Flag
Defining Custom Field Validations for the Master Index
To Implement a Validation Rule
Configuring the Match Engine
Specifying a Match Engine for the Master Index
To Configure the Match Engine
Configuring the Comparison Functions for a Master Index Application
To Configure the Comparison Functions (Configuration Editor)
To Configure the Comparison Functions (Text Editor)
Match Comparator Configuration Properties for Oracle Java CAPS Master Index
Importing Custom Comparison Functions
To Import a Comparison Function
Deleting a Custom Comparison Function
To Delete a Custom Comparison Function
Configuring the Standardization Engine
Specifying a Standardization Engine for the Master Index
To Specify the Standardization Engine
Modifying Master Index Standardization Files
To Modify Standardization Data Configuration Files
Importing Standardization Data Types and Variants
To Import a Data Type or Variant
Deleting a Standardization Variant or Data Type
To Delete a Variant or Data Type
Configuring the Master Index MIDM Appearance
Adding Objects to the MIDM
To Add an Object to the MIDM
Modifying MIDM Objects
To Modify an MIDM Object
Deleting Objects From the MIDM
To Delete an Object
Adding Fields to the MIDM
To Define New Fields
MIDM Field Configuration Elements
Removing Fields From the MIDM
To Remove a Field From the MIDM
Modifying MIDM Field Display Options
To Modify a Field's Display Options
Specifying a Drop-Down List for an MIDM Field
To Specify a Drop-Down List
Specifying an MIDM Field's Length and Format
To Modify a Field's Length and Format
Modifying an MIDM Field's Data Type
To Modify the Data Type
Defining Key Fields for an Object
To Modify the Key Status
Masking Field Values on the MIDM
To Mask Field Values on the MIDM
Defining MIDM Object Relationships
To Define Relationships
Defining MIDM Local ID Labels
To Define Local ID Labels
Configuring the Master Index MIDM Pages
Specifying the Initial View for the MIDM
To Specify the Initial View
Configuring the MIDM Duplicate Records Page
Configuring Duplicate Records Display Options
Configuring Duplicate Records Search Pages
Configuring the Duplicate Records Results List
Duplicate Records Page Configuration Elements
Duplicate Records Search Page Elements
Duplicate Records Search Results List Elements
Configuring the MIDM Record Details Page
To Configure Record Details Display Options
Creating Search Pages on the Record Details Page
Step 1: Define the Search Page
Step 2: Define the Search Fields
Step 3: Specify Search Options
Record Details Search Page Definition Elements
Record Details Search Field Definition Elements
Record Details Search Option Elements
Modifying a Search Page on the Record Details Page
Modifying a Search Page Definition
Modifying Search Fields
Modifying Record Details Search Page Options
Configuring the MIDM Assumed Matches Page
To Configure the Assumed Matches Page
Configuring the MIDM Transactions Page
To Configure the Transactions Page
Configuring the MIDM Reports Page
Configuring the Reports Page Definition
Configuring Production Reports
Configuring Activity Reports
Production Reports Definition Elements
Activity Reports Definition Elements
Activity Reports Page Definition Elements
Activity Reports Search Elements
Activity Reports Results Elements
Configuring the MIDM Source Record Page
Configuring the Source Record Page Definition
Configuring the Tabbed Pages on the Source Record Page
Configuring the MIDM Audit Log Page
To Configure the Audit Log Page
Configuring Master Index MIDM Implementation Information
Specifying the Master Controller JNDI Class
To Specify the Master Controller JNDI Class
Specifying the Master Index Report Generator JNDI Class
To Specify the Report Generator JNDI Class
Specifying Master Index Validation Services
To Specify the Validation Service
Setting Master Index Debug Options
To Set Debug Options
Specifying a Master Index Field Masking Class
To Specify a Field Masking Class
The Master Controller defines how transactions are processed, and is configured in master.xml. You can specify Java classes that insert additional logic into the match process, configure the blocking query to use for matching, define how merged record updates are handled, and specify whether a record’s potential duplicates are reevaluated after it is updated. You can customize the Master Controller by performing any of the following actions.
The logic-class element specifies custom match processing logic for messages coming from external systems. The and logic-class-gui element specifies custom match processing logic for the MIDM. If no custom plug-ins were created to define the custom logic, leave these elements empty. Custom logic classes can only be specified by modifying the XML file directly.
  1. In the Projects window, expand the Configuration node in the project you want to modify, and then double-click master.xml.
  2. In the MasterControllerConfig element, change the value of the logic-class element to the name of the custom plug-in that contains the back-end logic.
    For example:
    <logic-class>com.sun.mdm.index.user.CustomProcessing</logic-class>
  3. Save and close the file.
  2. In the MasterControllerConfig element, change the value of the logic-class-gui element to the name of the custom plug-in that contains the MIDM logic.
    For example:
    <logic-class-gui>com.sun.mdm.index.user.CustomMIDM</logic-class-gui>
The update-mode element specifies whether potential duplicates are reevaluated for a record each time the record is updated. If you specify that potential duplicates are reevaluated, the reevaluation only occurs when updates are made to fields involved in blocking and matching. The update mode can only be specified by modifying the XML file directly.
  2. In the MasterControllerConfig element, change the value of the update-mode element to Pessimistic.
    For example:
    <update-mode>Pessimistic</update-mode>
  2. In the MasterControllerConfig element, change the value of the update-mode element to Optimistic.
    For example:
    <update-mode>Optimistic</update-mode>
The merged-record-update element allows you to define whether updates can be made to records with a status of Merged.
  2. In the MasterControllerConfig element, change the value of the merged-record-update element to Enabled.
    For example:
    <merged-record-update>Enabled</merged-record-update>
  2. In the MasterControllerConfig element, change the value of the merged-record-update element to Disabled.
    For example:
    <merged-record-update>Disabled</merged-record-update>
You need to specify the query that will be used by the master index application to retrieve a candidate selection pool of records that closely match an incoming record and that will be used for probabilistic weighting. The name of the blocking query you specify here must match the name of one of the blocking queries defined in query.xml. You can only specify one blocking query for matching in the master index application.
Note - Modifying the blocking query once your system is in production is not recommended because it can cause issues with data integrity.
  2. Scroll to the execute-match element in the MasterControllerConfig element.
  3. Modify the value of the query-builder name to the name of the blocking query you want to use. For example:
    <execute-match>
     <query-builder name="MY-BLOCKER">
     <option key="key" value="value"/>
     </query-builder>
    </execute-match>
    Note - Make sure the name you specify exactly matches the name of one of the blocking queries defined in query.xml.
  4. Set the blocking query options, as described in Setting Master Index Blocking Query Options.
  5. Save and close the file.
Key and value pairs are designed to fine-tune the operation of custom blocking queries. In the default blocking queries defined in query.xml, key and value pairs are not used. However, if you create a custom blocking query, you can configure the query to use key and value pairs. The key describes the option, and the value specifies the value of the option.
  2. Scroll to the execute-match element.
  3. To specify a key and value pair, modify the values of the key and value attributes in the option element.
    For example:
    <option key="wildcard" value="true"/>
  4. To delete a key and value pair, remove the option element.
You can define the master index application to distribute transactions across applications, to distribute transactions only within the master index application, or to not use distributed transactions at all. You can define transactional support by using the Configuration Editor or by modifying the XML file directly. When you define transactional support for the master index, make sure to use the appropriate transaction properties for the database connection in the GlassFish Admin Console.
  1. In the Projects window, right-click the Configuration node in the project you want to modify, and then click Edit.
    The Configuration Editor appears.
  2. Click the Deployment tab.
  3. In the Transaction Mode field, select LOCAL.
  4. On the Configuration Editor toolbar, click Save.
  5. To configure the database connection, launch the application service Admin Console, and do one of the following:
    • If the database connection is already defined, do the following on the Admin Console:
      1. In the left frame, expand Resources > JDBC > Connection Pools.
      2. Select the database connection pool that is defined for your master index application.
      3. On the Edit Connection Pool page, select either javax.sql.DataSource or javax.sql.ConnectionPoolDataSource for the Resource Type and click Save.
    • If the database connection is not already defined, follow the instructions provided in Defining the Database Connection Pools in Oracle Java CAPS Master Index User’s Guide. Select either javax.sql.DataSource or javax.sql.ConnectionPoolDataSource for the connection pool Resource Type.
  3. In the Transaction Mode field, select XA (across applications).
  5. Launch the application server Admin Console (from NetBeans, click the Services tab, expand Servers, right-click the domain, and select View Admin Console).
  6. To configure the database connection, launch the application service Admin Console, and do one of the following:
      3. On the Edit Connection Pool page, select javax.sql.XADataSource for the Resource Type and click Save.
    • If the database connection is not already defined, follow the instructions provided in Defining the Database Connection Pools in Oracle Java CAPS Master Index User’s Guide. Select javax.sql.XADataSource for the Resource Type.
  3. In the Transaction Mode field, select XA (within application only).
  5. To configure the database connection, launch the application server Admin Console and do one of the following:
