Skip Navigation Links
Exit Print View
Oracle Java CAPS Master Index Configuration Guide     Java CAPS Documentation
search filter icon
search icon
Document Information
Related Topics
Master Index Configuration Overview
About the Master Index Configuration Files
object.xml
query.xml
mefa.xml
master.xml
update.xml
filter.xml
validation.xml
security.xml
midm.xml
Modifying the Master Index XML Files Directly
Using the Master Index Master Index Configuration Editor
object.xml
query.xml
master.xml
mefa.xml
update.xml
validation.xml
midm.xml
Match Configuration File (matchConfigFile.cfg)
Maintaining Version Control in the Master Index Configuration Files
Copying, Cutting, and Pasting Files
Configuring the Master Index Object Structure
Adding an Object to the Master Index Object Structure
To Add an Undefined Object (Configuration Editor)
To Add a Predefined Object (Configuration Editor)
To Add an Undefined Object (XML editor)
Modifying an Object's Name In the Master Index Object Definition
To Modify an Object's Name (Configuration Editor)
To Modify an Object's Name (XML Editor)
Deleting an Object From the Master Index Object Structure
To Delete an Object (Configuration Editor)
To Delete an Object (XML Editor)
Adding a Field to the Master Index Object Structure
To Add a Field (Configuration Editor)
To Add a Field (XML Editor)
Deleting a Field from the Master Index Object Structure
To Delete a Field (Configuration Editor)
To Delete a Field (XML Editor)
Modifying Master Field Properties
To Modify Field Properties (Configuration Editor)
To Modify Field Properties (XML Editor)
Defining Relationships Between Master Index Objects
To Define Object Relationships (XML Editor)
Master Index Field Properties and Name Restrictions
Master Index Field Name Restrictions
Master Index Configuration Editor Field Properties
Master Index Field Property Elements
Creating a Master Index Basic Query
To Create a Basic Query (Configuration Editor)
To Create a Basic Query (XML Editor)
Master Index Query Builder Dialog Box Fields and XML Elements
Creating Master Index Blocking Queries
To Create a Blocking Query (Configuration Editor)
To Create a Blocking Query (XML Editor)
Master Index Query Block Fields and XML Elements
Modifying Master Index Queries
Modifying a Master Index Query
To Modify a Basic Query (Configuration Editor)
To Modify a Query (XML Editor)
Adding a Query Block to a Master Index Query
To Add a Query Block (Configuration Editor)
To Add a Query Block (XML Editor)
Modifying a Query Block for a Master Index Query
To Modify a Query Block (Configuration Editor)
To Modify a Query Block (XML Editor)
Deleting a Query Block From a Master Index Query
To Delete a Query Block (Configuration Editor)
To Delete a Query Block (XML Editor)
Deleting a Master Index Query
To Delete a Query (Configuration Editor)
To Delete a Query
Configuring Master Index Processing Options
Specifying Master Index Custom Logic Classes
To Specify Custom Logic for External System Messages
To Specify Custom Logic for the Master Index Data Manager
Specifying the Master Index Update Mode
To Specify Potential Duplicates be Reevaluated at Each Update
To Specify Potential Duplicates not be Reevaluated at Each Update
Configuring Master Index Merged Record Updates
To Allow Merged Record Updates
To Prevent Merged Record Updates
Specifying the Master Index Blocking Query for Matching
To Specify the Blocking Query for Matching
Setting Master Index Blocking Query Options
To Set Blocking Query Options
Defining Master Index Transactional Support
To Configure the Master Index for Local Transactions
To Configure the Master Index to Distributed Transactions Across Applications
To Configure the Master Index for Distributed Transactions Within the Master Index Application Only
Configuring Matching Parameters
Specifying the Master Index Decision Maker Class
To Specify the Decision Maker Class
Defining How to Handle Multiple Assumed Matches (OneExactMatch)
To Create Potential Duplicates When Multiple Records Match
To Match the Highest Weighted Records When Multiple Records Match
Specifying Whether Same System Matches are Allowed (SameSystemMatch)
To Allow Same System Records to be Automatically Merged
To Prevent Same System Records From Being Automatically Merged
Specifying the Master Index Duplicate Threshold
To Specify the Duplicate Threshold (Configuration Editor)
To Specify the Duplicate Threshold (XML Editor)
Specifying the Master Index Match Threshold
To Specify the Match Threshold (Configuration Editor)
To Specify the Match Threshold (XML Editor)
Adding and Deleting Master Index Decision Maker Parameters
To Add a New Decision Maker Parameter
To Delete a Decision Maker Parameter
Configuring Master Index EUIDs
Specifying the Master Index EUID Generator Class
To Specify the EUID Generator Class
Specifying the Master Index EUID Length
To Specify the EUID Length
Specifying a Master Index Checksum Length
To Specify a Checksum Length
Specifying the Master Index Chunk Size
To Specify the Chunk Size
Adding and Deleting Master Index EUID Generator Parameters
To Add EUID Generator Parameters
To Delete EUID Generator Parameters
Defining Master Index Normalization Rules
Defining a Master Index Field to be Normalized
To Define a Field to be Normalized (Configuration Editor)
To Define a Field to be Normalized (XML Editor)
Master Index Normalization and Standardization Structure Properties
Master Index Variants Properties
Modifying a Master Index Normalization Definition
To Modify a Normalization Definition (Configuration Editor)
To Modify a Normalization Structure (XML Editor)
Deleting a Master Index Normalization Definition
To Delete a Normalization Definition
To Delete a Normalization Structure
Defining Master Index Standardization Rules
Defining Master Index Fields to be Standardized
To Define Fields to be Standardized (Configuration Editor)
To Define Fields to be Standardized (XML Editor)
Master Index Standardization Source and Target Field Elements
Modifying a Master Index Standardization Definition
To Modify a Standardization Definition (Configuration Editor)
To Modify a Standardization Definition (XML Editor)
Deleting a Master Index Standardization Definition
To Delete a Standardization Definition (Configuration Editor)
Defining Phonetic Encoding for the Master Index
Defining Master Index Fields for Phonetic Encoding
To Define a Field for Phonetic Encoding (Configuration Editor)
To Define a Field for Phonetic Encoding (XML Editor)
Master Index Phonetic Encoding Fields and Elements
Modifying a Master Index Phonetic Encoding Definition
To Modify a Phonetic Encoding Definition (Configuration Editor)
To Modify a Phonetic Encoding Definition (XML Editor)
Deleting a Master Index Phonetic Encoding Definition
To Delete a Phonetic Encoding Definition (Configuration Editor)
To Delete a Phonetic Encoding Definition (XML Editor)
Defining a Master Index Phonetic Encoder
To Define a Phonetic Encoder (Configuration Editor)
To Define a Phonetic Encoder (XML Editor)
Master Index Encoder Elements and Types
Modifying a Master Index Phonetic Encoder
To Modify a Phonetic Encoder (Configuration Editor)
To Modify a Phonetic Encoder (XML Editor)
Deleting a Master Index Phonetic Encoder
To Delete a Phonetic Encoder (Configuration Editor)
To Delete a Phonetic Encoder (XML Editor)
Defining the Master Index Match String
Creating the Master Index Match String
To Create the Match String (Configuration Editor)
To Create the Match String (XML Editor)
Modifying the Master Index Match String
To Modify the Match String (Configuration Editor)
To Modify the Match String (XML Editor)
Defining how Master Index Query Blocks are Processed
To Specify the Block Picker
To Specify the Pass Controller Class
Defining the Master Index Survivor Calculator
Specifying the Master Index Survivor Helper
To Specify the Survivor Helper
Specifying a Master Index Default Survivor Strategy
To Specify a Default Survivor Strategy
Configuring the Default Survivor Strategy
Master Index Default Survivor Strategy Parameter Elements
Defining the Master Index Single Best Record Structure
To Specify a Candidate Field
Deleting Candidate Fields
Defining a Master Index Survivor Strategy for a Field or Object
To Define a Survivor Strategy for a Field
Defining Master Index Custom Weighted Strategies
Defining Custom Weighted Strategies
Configuring Weighted Strategies
Modifying Weighted Calculator Parameters
Deleting Weighted Calculator Parameters
Master Index Weighted Calculator Parameter Elements
Filtering Default Values From Master Index Processes
To Filter Default Values From the SBR, Blocking Query, or Match Process
Filter Definition Elements
Configuring Master Index Update Policies
Defining Master Index Update Policies
To Define Update Policies
Setting the Master Index Update Policy Flag
To Set the Update Policy Flag
Defining Custom Field Validations for the Master Index
To Implement a Validation Rule
Configuring the Match Engine
Specifying a Match Engine for the Master Index
To Configure the Match Engine
Configuring the Comparison Functions for a Master Index Application
To Configure the Comparison Functions (Configuration Editor)
To Configure the Comparison Functions (Text Editor)
Match Comparator Configuration Properties for Oracle Java CAPS Master Index
Importing Custom Comparison Functions
To Import a Comparison Function
Deleting a Custom Comparison Function
To Delete a Custom Comparison Function
Configuring the Standardization Engine
Specifying a Standardization Engine for the Master Index
To Specify the Standardization Engine
Modifying Master Index Standardization Files
To Modify Standardization Data Configuration Files
Importing Standardization Data Types and Variants
To Import a Data Type or Variant
Deleting a Standardization Variant or Data Type
To Delete a Variant or Data Type
Configuring the Master Index MIDM Appearance
Adding Objects to the MIDM
To Add an Object to the MIDM
Modifying MIDM Objects
To Modify an MIDM Object
Deleting Objects From the MIDM
To Delete an Object
Adding Fields to the MIDM
To Define New Fields
MIDM Field Configuration Elements
Removing Fields From the MIDM
To Remove a Field From the MIDM
Modifying MIDM Field Display Options
To Modify a Field's Display Options
Specifying a Drop-Down List for an MIDM Field
To Specify a Drop-Down List
Specifying an MIDM Field's Length and Format
To Modify a Field's Length and Format
Modifying an MIDM Field's Data Type
To Modify the Data Type
Defining Key Fields for an Object
To Modify the Key Status
Masking Field Values on the MIDM
To Mask Field Values on the MIDM
Defining MIDM Object Relationships
To Define Relationships
Defining MIDM Local ID Labels
To Define Local ID Labels
Configuring the Master Index MIDM Pages
Specifying the Initial View for the MIDM
To Specify the Initial View
Configuring the MIDM Duplicate Records Page
Configuring Duplicate Records Display Options
Configuring Duplicate Records Search Pages
Configuring the Duplicate Records Results List
Duplicate Records Page Configuration Elements
Duplicate Records Search Page Elements
Duplicate Records Search Results List Elements
Configuring the MIDM Record Details Page
To Configure Record Details Display Options
Creating Search Pages on the Record Details Page
Step 1: Define the Search Page
Step 2: Define the Search Fields
Step 3: Specify Search Options
Record Details Search Page Definition Elements
Record Details Search Field Definition Elements
Record Details Search Option Elements
Modifying a Search Page on the Record Details Page
Modifying a Search Page Definition
Modifying Search Fields
Modifying Record Details Search Page Options
Configuring the MIDM Assumed Matches Page
To Configure the Assumed Matches Page
Configuring the MIDM Transactions Page
To Configure the Transactions Page
Configuring the MIDM Reports Page
Configuring the Reports Page Definition
Configuring Production Reports
Configuring Activity Reports
Production Reports Definition Elements
Activity Reports Definition Elements
Activity Reports Page Definition Elements
Activity Reports Search Elements
Activity Reports Results Elements
Configuring the MIDM Source Record Page
Configuring the Source Record Page Definition
Configuring the Tabbed Pages on the Source Record Page
Configuring the MIDM Audit Log Page
To Configure the Audit Log Page
Configuring Master Index MIDM Implementation Information
Specifying the Master Controller JNDI Class
To Specify the Master Controller JNDI Class
Specifying the Master Index Report Generator JNDI Class
To Specify the Report Generator JNDI Class
Specifying Master Index Validation Services
To Specify the Validation Service
Setting Master Index Debug Options
To Set Debug Options
Specifying a Master Index Field Masking Class
To Specify a Field Masking Class
You can configure certain pages that appear on the MIDM by modifying the midm.xml. Each page on the MIDM is configured separately, though many contain the same XML elements and attributes. For the Record Details page, you can configure and create search pages and search results lists. If you add a new query to query.xml and you want to access that query from the MIDM, you need to create a new search page for the query on the Record Details page. The Dashboard page cannot be configured.
Perform any of the following actions to configure the pages of the MIDM.
By default, the Record Details page appears when a user logs in to the Master Index Data Manager. You can specify any of the other tabbed pages as the initial view. Each page on the MIDM is identified by a screen ID in midm.xml, which is an integer defined in the screen-id element for each page. Use this ID to specify which page to display first when a user logs in.
  1. In the Projects window, expand the Configuration node in the project you want to modify, and then double-click midm.xml.
    The file opens in the NetBeans XML editor.
  2. Locate the page definition for the page you want to display first, and note the value of its screen-id element.
  3. Scroll to the initial-screen-id element, located in the gui-definition element.
  4. Enter the value of the screen-id element for the page you want to display first.
  5. Save and close the file.
The Duplicate Records page allows you to search for potential duplicate records, view a results list, and then view a comparison of the records you select. It also provides features to resolve or merge the potential duplicates in question. You can configure several aspects of the Duplicate Records page, including display options, search pages, and the results list.
The following topics provide instructions for each type of configuration:
You can configure certain display options for the Duplicate Records page, such as the name of the tabbed heading and the order in which the tab appears on the MIDM. Below is a sample of the display option elements for the Duplicate Records page.
<duplicate-records>
   <root-object>Person</root-object>
   <tab-name>Duplicate Records</tab-name>
   <screen-id>3</screen-id>
   <display-order>1</display-order>
</duplicate-records>
You should never need to modify the root-object or screen-id element for the Duplicate Records page.
To Configure Duplicate Records Display Options
  2. Scroll to the duplicate-records element (located in the gui-definition element).
  3. To specify a different name for the Duplicate Record tab, modify the value of the tab-name element.
  4. To change the order in which the Duplicate Records tab appears on the MIDM, change the value of the display-order element.
    Note - You might need to renumber the remaining tabs to keep the numbering sequential.
For the Duplicate Records search pages, you can configure the names of the searches that can be performed, the fields to use as search criteria (within a limited set of system fields), and instructions for performing a search. Below is a sample of the search page configuration for the Duplicate Records page.
<duplicate-records>
      <simple-search-page>
         <screen-title>Advanced Search</screen-title>
         <search-result-id>0</search-result-id>
         <search-screen-order>0</search-screen-order>
         <show-euid>true</show-euid>
         <show-lid>true</show-lid>
         <show-status>true</show-status>
         <show-create-date>true</show-create-date>
         <show-create-time>true</show-create-time>
         <instruction></instruction>
         <field-group/>
      </simple-search-page>
To Configure the Duplicate Records Search Page
  3. Modify any of the elements described in Duplicate Records Search Page Elements.
  4. Save and close the file.
For the Duplicate Records results list, you can configure the number of results to display at one time, the total number of results a search can return, and the fields that appear in the results list. Below is a sample results list configuration for the Duplicate Records page.
<duplicate-records>
   <search-result-pages>
      <search-result-list-page>
         <item-per-page>10</item-per-page>
         <max-result-size>100</max-result-size>
         <field-group>
            <description></description>
            <field-ref>Person.FirstName</field-ref>
            <field-ref>Person.LastName</field-ref>
            <field-ref>Person.SSN</field-ref>
            <field-ref>Person.DOB</field-ref>
            <field-ref>Person.Gender</field-ref>
         </field-group>
      </search-result-list-page>
   </search-result-pages>
To Configure the Duplicate Records Results List
  3. Modify any of the elements described in Duplicate Records Search Results List Elements.
  4. To add a field to the results list, create and name a new field-ref element in the field-group element.
  5. To delete a field from the results list, delete the field-ref element defining the field.
  6. Save and close the file.
The following two tables describe the configuration elements in midm.xml for the Duplicate Records search and results pages. The same elements are also used for the Source Record View/Edit page.
The following table lists and describes the configurable elements for the Duplicate Records and Source Record search pages.
Table 1 Duplicate Records Search Page Configuration
Element/Attribute
Description
search-pages
A container element that lists and defines the searches that are available from the page.
simple-search-page
A container element that defines one type of search for the Duplicate Records page. You can define multiple simple search pages.
screen-title
The name of the search as it appears on the search page. MIDM users can select a type of search to perform based on the titles you define for the searches here.
search-screen-order
The order in which the search page appears on the MIDM.
show-euid
An indicator of whether to display the EUID field as search criteria. Specify true to display the EUID; otherwise specify false.
show-lid
An indicator of whether to display the local ID and system fields as search criteria. Specify true to display the fields; otherwise specify false.
show-status
An indicator of whether to display the record status field as search criteria. Specify true to display the field; otherwise specify false.
show-create-date
An indicator of whether to display the create date field to allow searching on the date the potential duplicate flag was created. Specify true to display the field; otherwise specify false.
show-create-time
An indicator of whether to display the create time field to allow searching on the time the potential duplicate flag was created. Specify true to display the field; otherwise specify false.
instruction
A short statement to help the user process a search. The text you enter here appears above the search fields on the Search page.
field-group
A list of fields that appear on the Search page. You can define multiple field groups, and each group can be contained in a labelled box on the Search page.
description
A description of the fields defined for the field-group element. This value appears as a box label for the area of the page that contains the specified fields.
field-ref
One field definition for a field in the field group. Use the simple field name of the field with their corresponding objects as the root. For example, the path to the FirstName field in the Person object is “Person.FirstName”. You can define multiple field-ref elements for each field group.
The following table lists and describes the configurable elements for the Duplicate Records search results list.
Table 2 Duplicate Records Search Results Configuration
Element/Attribute
Description
search-result-pages
A container element for a list of search result page definitions.
A container element for the configuration information for the search results page.
item-per-page
The number of resulting records to display on one page.
max-result-size
The maximum number of records to return for a search.
field-group
A container element for a list of fields that appear in the search results.
description
A brief description for the field group. This value appears on the MIDM above the fields that are returned from a search.
field-ref
A definition for one field that appears in the search results list. Use the simple field names with their corresponding objects as the root. For example, the path to the FirstName field in the Person object is “Person.FirstName”. You can define multiple field-ref elements.
You can configure certain display options for the Record Details page, such as the name of the tabbed heading and the order in which the tab appears on the MIDM. You can also create, modify, and delete search pages and search results lists. Search configuration is described in Creating Search Pages on the Record Details Page and Modifying a Search Page on the Record Details Page.
Below is a sample of the display option elements for the Record Details page.
<record-details>
   <tab-name>Record Details</tab-name>
   <screen-id>1</screen-id>
   <display-order>2</display-order>
You should never need to modify the root-object or screen-id element.
  2. Scroll to the record-details element (located in the gui-definition element).
  3. To specify a different name for the Record Details tab, modify the value of the tab-name element.
  4. To change the order in which the Record Details tab appears on the MIDM, change the value of the display-order element.
Several search pages are created by the Master Index Wizard based on the information you specify. You can create and customize new search pages for the Record Details page. Each search you define must use a query that is defined in query.xml.
Follow these steps to create a new search page:
The first step in creating a search page is to define certain properties for the appearance of the page, such as its name, whether to display the EUID or local ID field, and general instructions for the search.
Note - If either the EUID field or the local ID and system fields appear on a search page, any values entered into these fields take precedence over information entered into other search fields. For example, if an invalid EUID is entered but valid first and last names are entered, no results are returned due to the invalid EUID. The EUID field takes precedence over the local ID and system fields.
To Define the Search Page
  1. In the Projects window, expand the Configuration node in the Project you want to modify, and then double-click midm.xml.
  2. Scroll to the record-details element, and then create a simple-search-page element.
    Make sure the new element falls within the record-details element, but outside any existing simple-search-page elements. For example:
    <record-details>
    </record-details>
  3. In the new simple-search-page element, create the elements listed in Record Details Search Page Definition Elements and enter the appropriate value for each element.
    For example:
    <record-details>
          <screen-title>Address Search</screen-title>
          <search-result-id>1</search-result-id>
          <show-lid>false</show-lid>
          <instruction>Enter address information below.</instruction>
    </record-details>
  4. Continue to Step 2: Define the Search Fields.
Once you define the search page, you need to specify the fields that appear on the page. Fields are specified in field groups, and each field group represents an area on the search page. All fields specified for a field group appear in the area defined by that group. The label for the area is defined by the description of the field group.
To Define Search Fields
  1. Complete Step 1: Define the Search Page.
  2. In the new simple-search-page element, create a field-group element.
    For example:
       <screen-title>Simple Person Search</screen-title>
       <search-result-id>2</search-result-id>
       <search-screen-order>1</search-screen-order>
       <show-euid>false</show-euid>
       <field-group>
       </field-group>
  3. In the new field-group element, create the elements and attributes listed in Record Details Search Field Definition Elements and enter the appropriate value for each.
    For example:
       <field-group>
          <description>Address</description>
          <field-ref>Address.AddressType</field-ref>
          <field-ref>Address.AddressLine1</field-ref>
          <field-ref>Address.AddressLine2</field-ref>
          <field-ref required=“true”>Address.City</field-ref>
          <field-ref>Address.State</field-ref>
       </field-group>
  4. Repeat steps 2 and 3 for each field group you want to display on the selected search page.
  5. Continue to Step 3: Specify Search Options.
After you define the criteria fields for the MIDM search, you can specify certain options for the search, such as the types of available searches, whether each search is weighted, and whether the search allows wildcard characters.
Note - Wildcards should not be allowed for blocking queries or phonetic searches.
To Specify Search Options
  1. Complete Step 2: Define the Search Fields.
  2. In the simple-search-page element you created, create a search-option element.
    For example:
       <field-group>
       </field-group>
       <search-option>
       </search-option>
  3. In the new search-option element, create the elements listed in Record Details Search Option Elements and enter the appropriate value for each element.
    For example:
    <search-option>
       <display-name>Alpha Search</display-name>
       <query-builder>ALPHA-SEARCH</query-builder>
       <weighted>false</weighted>
       <parameter>
         <name>UseWildCard</name>
         <value>true</value>
       </parameter>
    </search-option>
  4. Repeat the previous two steps for each search type you want to make available on the selected search page.
    Note - If you define multiple search option elements, an option button (labelled by the value of the display-name element) appears on the search page for each search option.
The following table lists and describes the elements you can configure in midm.xml to define the search pages on the Record Details page.
Element
Description
screen-title
The name of the search as it appears on the search page. Users can select a type of search to perform based on the titles you define for the searches here.
search-result-id
The unique identifier for the search results page that appears for the search. You can define multiple search results pages for each MIDM page, and each results page has a unique ID. You can enter any of the search result ID values defined in the search-results-pages element.
search-screen-order
show-euid
An indicator of whether to display the EUID. Specify true to display the EUID; otherwise specify false. Only display this field if you want it to take precedence over all other search criteria.
show-lid
An indicator of whether to display the local ID and system fields. Specify true to display the fields; otherwise specify false. Only display these fields if you want them to take precedence over all other search criteria (except the EUID field).
instruction
The following table lists and describes the elements you can configure in midm.xml to define the fields for each search on the Record Details page.
Element/Attribute
Description
description
field-ref
One field definition for a field in the field group. Use the simple field names of the fields with their corresponding objects as the root. For example, the path to the FirstName field in the Person object is “Person.FirstName”. You can define multiple field-ref elements for each field group, each of which are further configured by the following two optional attributes.
field-ref/required
An indicator of whether the field is required in order to perform a search. Specify any of the following values:
  • true – The corresponding field is required to perform the search. These fields are marked with an asterisk (*) on the search page.
  • false – The corresponding field is not required to perform the search. If the required attribute is not defined, the default is false.
  • one of – The corresponding fields with this designation are a group of search criteria, at least one of which is required to perform the search. This designation specifies that at least one field in the group of fields with the “one of” designation is required. If a group of fields is designated as “one of”, those fields are marked with a dagger (†) on the search page.
Tip - If you make a field required for a search, it is a good idea to make it required when creating a record as well by specifying true for the required property for the field in object.xml. Otherwise, searches performed from the MIDM could result in no possible matches even though possible matches exist.
field-ref/choice
An indicator of whether the field allows you to search by a range of values rather than an exact value. Specify any of the following values:
  • exact – The search is performed on the exact value entered (wildcard characters may be allowed). If the choice attribute is not specified, this is the default value.
  • range – The search is performed on a range of values based on the entered search criteria. Fields with this designation appear twice on the search page, once with “From” appended to the field label and once with “to” appended to the field label. If you specify “range” for a field in a search that uses a blocking query, be sure to modify the query block in query.xml accordingly.
Tip - You can specify the same field for both exact and range searching by adding it twice to the field list with different attribute values, giving the choice of performing an exact search or a range search from the MIDM. For more information about range searching, see Range Searching in Oracle Java CAPS Master Index Configuration Reference .
The following table lists and describes the elements you can configure in midm.xml to define the attributes for each search on the MIDM, such as which query to use, whether the search results are weighted, and so on.
Element
Description
display-name
A short phrase describing the type of search to perform, such as “Alphanumeric Search” or “Phonetic Search”. This appears next to the option button on the search page when multiple search options are defined.
query-builder
The type of query to use when this type of search is selected. The value entered here must match a query-builder name in query.xml.
weighted
An indicator of whether the results of the search are assigned matching probability weights. Specify true to assign matching weights; specify false to return unweighted results.
candidate-threshold
The maximum number of records to return for a search. This value must be a positive number and can only be used for blocking queries. Setting the candidate threshold to zero is equivalent to not setting a threshold.
parameter
A list of optional parameters for the search, specified by name and value elements (described below).
name
The name of the parameter. Currently, only UseWildCard is available.
value
The value of the parameter. For the UseWildCard parameter, this is an indicator of whether the parameter is enabled or disabled. Specify true to allow wildcard characters; specify false to perform exact-match searches.
Once a search page is defined for the Record Details page, it can be modified as needed. Be sure to review the search pages automatically generated by the wizard to see if any further configuration is required. You can perform any of the following actions to customize existing search page elements.
Once a search page is defined for the Record Details page, you can modify the search page definition. The search page definition includes properties like the name of the page, the order of the search, the results list to use for the search, and so on.
To Modify a Search Page Definition
  2. Scroll to the simple-search-page element you want to modify in the record-details element.
  3. In the simple-search-page element, change the value of any of the elements listed in Record Details Search Page Definition Elements.
    For example:
       <screen-title>Customer Search</screen-title>
       <search-screen-order>2</search-screen-order>
       <instruction>Enter the EUID below.</instruction>
Once field groups and fields are specified for a Record Details search page, you can modify the properties of the group and of the fields contained in a group. For more information about the elements that contain the search field configuration, see Record Details Search Field Definition Elements.
To Modify Search Fields
  3. In the field-group you want to modify, do any of the following:
    • To modify the name of the area in which the field group appears in the MIDM, change the value of the description element.
    • To add a new field to a field group, create and name a new field-ref element in the appropriate field-group element.
    • To modify the name of a field defined for a field group, change the value of the field-ref element.
    • To specify whether a field is required, add a required attribute and specify a value defined in Record Details Search Page Definition Elements.
    • To specify whether a field is used for range searching, add a choice attribute and specify a value defined in Record Details Search Field Definition Elements.
    • To delete a field from a field group, delete all text between and including the field-ref tags that define the field to be deleted.
    • To delete an entire field group, delete all text between and including the field-group tags that define the field group to be deleted.
Once search options are defined for a Record Details search page, you can modify those options if needed. For more information about the elements that define search options, see Record Details Search Option Elements.
To Modify Search Page Options
  3. In the search-option element, and do any of the following:
    • To modify the name of the search option button, change the value of the display-name element.
    • To modify the query type of the selected search, change the value of the query-builder element. The query you specify must match a query defined in query.xml.
    • To specify that a search return weighted results, change the value of the weighted element to true.
    • To specify that a search return unweighted results, change the value of the weighted element to false.
    • To specify that wildcard characters can be used in a search, change the UseWildCard parameter value element to true.
    • To specify that wildcard characters cannot be used in a search, change the UseWildCard parameter value element to false.
The Assumed Matches page allows you to search for assumed match records, view a results list, and then view the details for the record you select. You can also undo an assumed match if you think it was made in error. You can configure the name of the tabbed heading for the page, the display order, the number of records to return and display for a search, and the fields to display in the result list. The fields on the search page and in the results list are automatically generated and cannot be modified.
Below is a sample Assumed Matches page definition.
<assumed-matches>
   <tab-name>Assumed Matches</tab-name>
   <screen-id>4</screen-id>
   <display-order>3</display-order>
   <search-pages/>
         <field-group>
            <field-ref>Person.Address.AddressLine1</field-ref>
            <field-ref>Person.Address.AddressLine2</field-ref>
         </field-group>
</assumed-matches>
  2. Scroll to the assumed-matches element (located in the gui-definition element).
  3. Make any of the following configuration changes:
    • To specify a new name for the Assumed Matches tab, modify the value of the tab-name element.
    • To change the order in which the Assumed Matches tab appears on the MIDM, change the value of the display-order element.
      Note - If you change the order of one tab, make sure to change the order of the remaining tabs so no tabs have an identical display order value.
    • To specify the number of records to display on the Assumed Matches search results list, change the value of the item-per-page element.
    • To specify a maximum number of records to return for an Assumed Matches search, change the value of the max-result-size element.
    • To add a search description, enter the description text into the description element.
    • To modify the fields that appear in the results list in addition to the system fields, change the value of an existing field-ref element, create a new field-ref element, or delete an existing field-ref element.
      For example:
      <field-group>
             </field-group>
The Transactions page allows you to search for transaction records, view a results list, and then view the changes for the record you select. You can configure the name of the tabbed heading for the page, the display order, and the number of records to return and to display in the results list. The fields on the search page and results list are automatically generated and cannot be modified with the exception of the EUID, system, and local ID.
Below is the default Transactions page definition.
<transactions>
   <tab-name>Transactions</tab-name>
   <screen-id>2</screen-id>
   <display-order>4</display-order>
   <search-pages>
   </search-pages>
         <field-group/>
</transactions>
  2. Scroll to the transactions element (located in the gui-definition element).
    • To specify a new name for the Transactions tab, modify the value of the tab-name element.
    • To change the order in which the Transactions tab appears on the MIDM, change the value of the display-order element.
    • To include the EUID as a Transactions search field, change the value of the show-euid element to true.
    • To exclude the EUID from the Transactions search fields, change the value of the show-euid element to false.
    • To include the system and local ID as Transactions search fields, change the value of the show-lid element to true.
    • To exclude the system and local ID from the Transactions search fields, change the value of the show-euid element to false.
    • To specify the number of records to display on the Transactions search results list, change the value of the item-per-page element.
    • To specify a maximum number of records to return for a Transactions search, change the value of the max-result-size element.
Configuring the Reports page consists of configuring the page itself and configuring the individual reports. Production reports are each configured in the same way in their own sub-screen definition element. Activity reports are configured together in one sub-screen definition. The sub-screen definitions means there are a series of tabbed pages within the Reports page for each different type of report.
Perform any of the following tasks to configure the reports:
For the Reports page, you can configure the name of the tabbed heading for the page and the order in which the tab appears on the MIDM. The report configuration section defines the appearance of the Reports page, and is located within a set of reports tags near the end of the file. Following is a sample of the Reports page configuration elements.
<reports>
   <tab-name>Reports</tab-name>
   <screen-id>6</screen-id>
   <display-order>5</display-order>
   <search-pages/>
   <search-result-pages/>
To Configure the Reports Page Definition
  2. Scroll to the reports element (located in the gui-definition element).
  3. To specify a different name for the Reports tab, modify the value of the tab-name element.
  4. To change the order in which the Reports tab appears on the MIDM, change the value of the display-order element.
  5. When you have finished configuring the Reports page, save and close the file.
A sub-screen on the Reports page is defined for each of the production reports. Use these sections to configure each production report to display information as you want to view it. You can also specify which reports can be run from the MIDM. Following is an example of a report configuration stanza.
<subscreen>
   <enable>true</enable>
   <tab-name>Potential Duplicate Report</tab-name>
   <report-name>Potential Duplicate</report-name>
   <screen-id>0</screen-id>
   <search-pages/>
         <max-result-size>2000</max-result-size>
         <field-group>
            <field-ref>Person.Address.City</field-ref>
         </field-group>
</subscreen>
To Configure Production Reports
Perform the following steps for each production report.
  2. Scroll to the reports element (located in the gui-def element.
  3. For each report, specify values for the elements and attributes listed in Production Reports Definition Elements.
  4. When you have finished configuring each report, save and close the file.
A sub-screen on the Reports page is defined for all of the activity reports. Use this sections to configure each activity report to display information as you want to view it. You can also specify which reports can be run from the MIDM. Following is an excerpt from the Activity report configuration stanza.
<subscreen>
   <tab-name>Activity Report</tab-name>
   <report-name>Transaction Summary</report-name>
   <screen-id>5</screen-id>
   <search-pages>
         <screen-title>Weekly Activity</screen-title>
         <report-name>Weekly Transaction Summary Report</report-name>
         <field-group/>
   </search-pages>
         <field-group/>
</subscreen>
To Configure Activity Reports
Perform the following steps for each production and activity report.
  2. Scroll to the reports element. This section is located near the end of the file.
  3. In the subscreen element that defines the activity reports, modify any of the elements described in Activity Reports Page Definition Elements to configure the Activity Reports page:
  4. For each activity report, modify any of the elements described in Activity Reports Search Elements.
  5. To specify the size and display of the results returned for the search, modify any of the elements described in Activity Reports Results Elements.
  6. When you have finished configuring each report, save and close the file.
The following table lists and describes the elements you can configure in midm.xml to define the production reports.
Element/Attribute
Description
enable
An indicator of whether to display the report search page on the Reports page. Specify true to display the report search page and enable the report; specify false to disable the report.
tab-name
The name to display on the tabbed heading for the report.
report-name
The name of the report as it appears on the generated report.
display-order
An integer indicating the order in which each report tab appears on the Reports page. If you change the display order of one report, make sure to change the others to keep the numbers consecutive.
item-per-page
The number of items to display on one page of the report search results.
max-result-size
The number of records to display on the report. if no value is entered, or if the value is zero (0), the size defaults to 1000 records. To retrieve all records for a report, enter a very large value for this element.
description
A description of the fields defined for the field-group element. This value appears as a label for the area of the page that contains the specified fields.
field-ref
One field definition for a field in the field group. Use the simple field names of the fields with their corresponding objects as the root. For example, the path to the FirstName field in the Person object is “Person.FirstName”. You can define multiple field-ref elements for each field group.
The following tables list and describe the elements you can configure for the activity reports in midm.xml.
The following table lists and describes the elements you can configure in midm.xml to define the Activity Reports page.
Element/Attribute
Description
enable
An indicator of whether to display the Activity Reports search page on the Reports page. Specify true to display the report search page and enable the report; specify false to disable the report.
tab-name
report-name
display-order
An integer indicating the order in which the Activity Reports tab appears on the Reports page. If you change the display order of one report, make sure to change the others to keep the numbers consecutive.
The following table lists and describes the elements you can configure in midm.xml to define each activity report search.
Element/Attribute
Description
screen-title
The name of the report search page as it appears on the Activity Reports page.
report-name
search-screen-order
An integer indicating the order in which each activity report appears on the Activity Reports page. If you change the display order of one report, make sure to change the others to keep the numbers consecutive.
The following table lists and describes the elements you can configure in midm.xml to define each activity report search result.
Element/Attribute
Description
item-per-page
max-result-size
The Source Record page is where anMIDM user adds new records to the master index database and performs actions against a source record rather than an enterprise record. This page includes sub-screen configurations, which means there are a series of tabbed pages within the Source Record page. These pages each provide different functions, such as view and edit, compare and merge, and create a new record.
You can configure certain display options for the main Source Record page, including the order in which the tab appears on the MIDM and the name of the page.
To Configure the Source Record Page Definition
  2. Scroll to the source-record element (located in the gui-definition element).
  3. To specify a different name for the Source Record tab, modify the value of the tab-name element.
  4. To change the order in which the Source Record tab appears on the MIDM, change the value of the display-order element.
You can configure any of the pages on the Source Record page by changing the tab name and display order and by enabling or disabling each page. Do not modify the search page or search results list for the sub-screens. Below is a sample configuration for the View/Edit page on the Source Record page.
<subscreen>
   <tab-name>View/Edit</tab-name>
   <display-order>0</display-order>
You should never need to modify the root-object or screen-id elements.
To Configure the Source Record Tabbed Pages
  2. Scroll to the source-records element, and then to the subscreen element containing name of the tab you want to modify.
  3. To specify a new name for the tab, modify the value of the tab-name element.
  4. To disable the sub-screen, change the value of the enable element to false.
  5. To enable the sub-screen, change the value of the enable element to true.
  6. To change the order in which the tab appears on the Source Records page, change the value of the display-order element.
  7. Save and close the file.
When enabled, the audit log stores a history of each instance in which information from the object tables in the master index database is accessed. The MIDM allows you to search for and view the audit log entries. You can enable or disable the audit log, change the display order, and customize the size of the results list. Below is the default Audit Log page definition.
<audit-log>
   <allow-insert>false</allow-insert>
   <tab-name>Audit Log</tab-name>
   <screen-id>7</screen-id>
   <display-order>7</display-order>
   <search-pages>
   </search-pages>
         <field-group/>
</audit-log>
  2. Scroll to the audit-log element (located in the gui-definition element).
  3. Make any of the following changes:
    • To specify that records be written to the audit log, change the value of the allow-insert element to true.
    • To specify that records not be written to the audit log, change the value of the allow-insert element to false.
    • To change the name of the Audit Log tab on the MIDM, change the value of the tab-name element.
    • To change the order in which the Audit Log appears on the MIDM, change the value of the display-order parameter to a different integer.
    • To change the number of Audit Log search results that appear on one page, change the value of the item-per-page element.
    • To change the maximum number of audit log records that can be returned for a search, change the value of the max-result-size element.
