Skip Navigation Links | |
Exit Print View | |
Oracle Fusion Middleware Deployment Planning Guide for Oracle Unified Directory 11g Release 1 (11.1.1) |
1. Overview of Oracle Unified Directory
2. Overview of the Directory Server
3. Overview of the Proxy Server
4. Overview of the Replication Gateway
Load Balancing Using the Proxy
Data Distribution Using the Proxy
How the DN Renaming Workflow Element Works
6. Example Deployments Using the Directory Server
7. Example Deployments Using the Proxy Server
8. Simple Proxy Deployments Using the Command Line Interface
This chapter describes in more detail the role of each of the proxy building blocks. The chapter covers the following topics:
Note - Before you read this chapter, you must review Oracle Unified Directory Installation Types for a better understanding.
