Skip Navigation Links
Exit Print View
Oracle Fusion Middleware Administration Guide for Oracle Unified Directory 11g Release 1 (11.1.1)
search filter icon
search icon
Document Information
Preface
1.  Starting and Stopping the Server
2.  Configuring the Server Instance
3.  Configuring the Proxy Components
4.  Configuring Security Between Clients and Servers
Getting SSL Up and Running Quickly
To Accept SSL-Based Connections Using a Self-Signed Certificate
Configuring Key Manager Providers
Key Manager Provider Overview
Using the JKS Key Manager Provider
To Self-Sign the Certificate
To Sign the Certificate by Using an External Certificate Authority
To Configure the JKS Key Manager Provider
Using the PKCS #12 Key Manager Provider
Using the PKCS #11 Key Manager Provider
Developing Custom Key Manager Providers
Configuring Trust Manager Providers
Overview of Certificate Trust Mechanisms
Using the Blind Trust Manager Provider
Using the JKS Trust Manager Provider
Using the PKCS #12 Trust Manager Provider
Configuring Certificate Mappers
Using the Subject Equals DN Certificate Mapper
Using the Subject Attribute to User Attribute Certificate Mapper
Using the Subject DN to User Attribute Certificate Mapper
Using the Fingerprint Certificate Mapper
Configuring SSL and StartTLS for LDAP and JMX
Configuring the LDAP and LDAPS Connection Handlers
To Enable a Connection Handler
To Specify a Connection Handler's Listening Port
To Specify a Connection Handler's Authorization Policy
To Specify a Nickname for a Connection Handler's Certificate
To Specify a Connection Handler's Key Manager Provider
To Specify a Connection Handler's Trust Manager Provider
To Enable StartTLS Support
To Enable SSL-Based Communication
Enabling SSL in the JMX Connection Handler
Using SASL Authentication
Supported SASL Mechanisms
Authorization IDs
SASL Options for the ANONYMOUS Mechanism
SASL Options for the CRAM-MD5 Mechanism
SASL Options for the DIGEST-MD5 Mechanism
SASL Options for the EXTERNAL Mechanism
SASL Options for the GSSAPI Mechanism
SASL Options for the PLAIN Mechanism
Configuring SASL Authentication
Configuring SASL External Authentication
Configuring the LDAP Connection Handler to Allow SASL EXTERNAL Authentication
Configuring the EXTERNAL SASL Mechanism Handler
Configuring SASL DIGEST-MD5 Authentication
Configuring SASL GSSAPI Authentication
Configuring Kerberos and the Oracle Unified Directory Directory Server for GSSAPI SASL Authentication
To Configure Kerberos V5 on a Host
To Specify SASL Options for Kerberos Authentication
Example Configuration of Kerberos Authentication Using GSSAPI With SASL
Assumptions for This Example
All Machines: Edit the Kerberos Client Configuration File
All Machines: Edit the Administration Server ACL Configuration File
KDC Machine: Edit the KDC Server Configuration File
KDC Machine: Create the KDC Database
KDC Machine: Create an Administration Principal and Keytab
KDC Machine: Start the Kerberos Daemons
KDC Machine: Add Host Principals for the KDC and Oracle Unified Directory Machines
KDC Machine: Add an LDAP Principal for the Directory Server
KDC Machine: Add a Test User to the KDC
Directory Server Machine: Install the Directory Server
Directory Server Machine: Create and Configure the Directory Server LDAP
Directory Server Machine: Configure the Directory Server to Enable GSSAPI
Directory Server Machine: Add a Test User to the Directory Server
Directory Server Machine: Obtain a Kerberos Ticket as the Test User
Client Machine: Authenticate to the Directory Server Through GSSAPI
Troubleshooting Kerberos Configuration
Testing SSL, StartTLS, and SASL Authentication With ldapsearch
ldapsearch Command Line Arguments Applicable To Security
Testing SSL
Testing StartTLS
Testing SASL External Authentication
Controlling Connection Access Using Allowed and Denied Rules
Property Syntax of Allowed and Denied Client Rules
Configuring Allowed and Denied Client Rules
5.  Configuring Security Between the Proxy and the Data Source
6.  Managing Oracle Unified Directory With Oracle Directory Services Manager
7.  Managing Directory Data
8.  Replicating Directory Data
9.  Controlling Access To Data
10.  Managing Users and Groups With dsconfig
11.  Managing Password Policies
12.  Managing Directory Schema
13.  Monitoring Oracle Unified Directory
14.  Tuning Performance
15.  Advanced Administration
Chapter 4
Oracle Unified Directory provides several mechanisms to secure traffic between the client and the server. The topics in this section describe these mechanisms, and how to configure them.
For information about securing access to directory data, see Chapter 9, Controlling Access To Data.
For information about configuring security between the Oracle Unified Directory proxy and the directory server or data source, see Chapter 5, Configuring Security Between the Proxy and the Data Source.
This chapter covers the following topics:
