Skip Navigation Links
Exit Print View
Oracle Fusion Middleware Installation Guide for Oracle Unified Directory 11g Release 1 (11.1.1)
search filter icon
search icon
Document Information
Preface
1.  Before You Install Oracle Unified Directory 11g Release 1 (11.1.1)
2.  Installing the Software
Getting the Oracle Unified Directory Software
Installing Oracle Unified Directory
Performing a Silent Installation
Installing Oracle WebLogic Server
Installing the Oracle Application Development Framework
Configuring WebLogic Server for Oracle Directory Services Manager
Accessing Oracle Directory Services Manager
3.  Setting Up the Directory Server
4.  Setting Up the Proxy Server
5.  Setting Up the Replication Gateway
6.  Configuring the JVM, Java Options, and Database Cache
7.  Managing Oracle Unified Directory as a Windows Service
8.  Uninstalling Oracle Unified Directory
When you have installed the Oracle Application Development Framework, you must create a new WebLogic domain for ODSM. The following procedure outlines the configuration on a UNIX system.
  1. Run the configuration wizard from the following location:
    $ OUD Base Location Home/oracle_common/common/bin/config.sh
  2. On the Welcome screen, select Create a new WebLogic domain and click Next.
  3. On the Select Domain Source screen, select the Oracle Directory Services Manager check box.
    The Oracle JRF checkbox is selected automatically.
  4. Click Next.
  5. On the Specify Domain Name and Location screen, type a domain name and specify its location.
    A new WebLogic domain is created in this location, and ODSM and its related components are deployed into this domain.
    Make a note of the domain location as you will need it to start the WebLogic domain in the following procedure.
  6. On the Configure Administrator User Name and Password screen, type a name and password for the user who will administer this domain.
    The password must be at least eight characters and must contain at least one number or special character. Confirm the password and click Next.
    Make a note of these details as you will need them to start or restart the WebLogic domain in the following procedure.
  7. On the Configure Server Start Mode screen, select Production Mode.
    Select a valid JDK and click Next.
  8. On the Optional Configuration screen, click Next.
  9. On the Configuration Summary screen, verify the domain details and click Create.
  10. On the Creating Domain Screen, click Done.
