Configuration Reference Home
Oracle Unified Directory - Client Connection Monitor Provider
The Client Connection Monitor Provider exposes monitor information about the set of client connections that are established to the Directory Server.
Parent Component
The Client Connection Monitor Provider component inherits from the Monitor Provider
Properties
A description of each property follows.
Basic Properties: Advanced Properties:
↓ enabled ↓ java-class
Basic Properties
enabled
Description
Indicates whether the Monitor Provider is enabled for use.
Default Value
None
Allowed Values
true
false
Multi-valued
No
Required
Yes
Admin Action Required
None
Advanced Property
No
Read-only
No
Advanced Properties
java-class
Description
Specifies the fully-qualified name of the Java class that provides the Client Connection Monitor Provider implementation.
Default Value
org.opends.server.monitors.ClientConnectionMonitorProvider
Allowed Values
A java class that implements or extends the class(es) :
org.opends.server.api.MonitorProvider
Multi-valued
No
Required
Yes
None
Advanced Property
Yes
Read-only
No
