Configuration Reference Home
Oracle Unified Directory - Connection Handler
Connection Handler
Note: this is an abstract component, that cannot be instantiated.
Connection Handlers are responsible for handling all interaction with the clients, including accepting the connections, reading requests, and sending responses.
Direct Subcomponents
The following Connection Handlers are available in the server :
These Connection Handlers inherit from the properties described below.
Properties
A description of each property follows.
Basic Properties: Advanced Properties:
↓ allowed-client  None
↓ denied-client
↓ enabled
↓ java-class
Basic Properties
allowed-client
Description
Specifies a set of host names or address masks that determine the clients that are allowed to establish connections to this Connection Handler. Valid values include a host name, a fully qualified domain name, a domain name, an IP address, or a subnetwork with subnetwork mask.
Default Value
All clients with addresses that do not match an address on the deny list are allowed. If there is no deny list, then all clients are allowed.
Allowed Values
An IP address mask
Multi-valued
Yes
Required
No
Admin Action Required
None. Changes to this property take effect immediately and do not interfere with connections that may have already been established.
Advanced Property
No
Read-only
No
denied-client
Description
Specifies a set of host names or address masks that determine the clients that are not allowed to establish connections to this Connection Handler. Valid values include a host name, a fully qualified domain name, a domain name, an IP address, or a subnetwork with subnetwork mask. If both allowed and denied client masks are defined and a client connection matches one or more masks in both lists, then the connection is denied. If only a denied list is specified, then any client not matching a mask in that list is allowed.
Default Value
If an allow list is specified, then only clients with addresses on the allow list are allowed. Otherwise, all clients are allowed.
Allowed Values
An IP address mask
Multi-valued
Yes
Required
No
Advanced Property
No
Read-only
No
enabled
Description
Indicates whether the Connection Handler is enabled.
Default Value
None
Allowed Values
true
false
Multi-valued
No
Required
Yes
None
Advanced Property
No
Read-only
No
java-class
Description
Specifies the fully-qualified name of the Java class that provides the Connection Handler implementation.
Default Value
None
Allowed Values
A java class that implements or extends the class(es) :
org.opends.server.api.ConnectionHandler
Multi-valued
No
Required
Yes
The Connection Handler must be disabled and re-enabled for changes to this setting to take effect
Advanced Property
No
Read-only
No
