Configuration Reference Home
Oracle Unified Directory - Distribution Workflow Element
The Distribution Workflow Element is used to partition a DIT into subsets of entries.
Parent Component
The Distribution Workflow Element component inherits from the Workflow Element
Relations From this Component
The following components have a direct COMPOSITION relation FROM Distribution Workflow Elements :
The following components have a direct AGGREGATION relation FROM Distribution Workflow Elements :
Properties
A description of each property follows.
Basic Properties: Advanced Properties:
↓ base-dn ↓ force-modify-dn
↓ enabled ↓ java-class
↓ global-index-catalog
Basic Properties
base-dn
Description
Identifies the portion of the DIT targeted by the distribution. The base DN of the subtree to partition is specified by this base-dn attribute.
Default Value
None
Allowed Values
A valid DN.
Multi-valued
No
Required
Yes
Admin Action Required
None
Advanced Property
No
Read-only
Yes
enabled
Description
Indicates whether the Workflow Element is enabled for use in the server. If a Workflow Element is not enabled, then its contents are not accessible when processing operations.
Default Value
None
Allowed Values
true
false
Multi-valued
No
Required
Yes
None
Advanced Property
No
Read-only
No
Description
The global index used by the distribution workflow element.
Default Value
None
Allowed Values
The DN of any Extension. The referenced global index catalog must be enabled.
Multi-valued
No
Required
No
None
Advanced Property
No
Read-only
No
Advanced Properties
force-modify-dn
Description
This flag determines if a modify DN is always accepted or not. Considering the following distribution: partition1=[1..1000[ and partition2=[1000..2000[. And considering the DIT where user entries are stored in [ou=people,dc=example,dc=com]. When a modify DN is targeting the entry uid=1,ou=people,dc=example,dc=com: modifying the RDN uid=1 to uid=2 is always accepted because the new entry stays in partition1. Modifying the RDN uid=1 to uid=1200 is not accepted because the new entry would need to be moved to the partition2, and moving entries from one partition to another is not supported. If the flag forceModifyDN is set to true then the request is accepted anyway but the new entry stays in partition1. Note that when the forceModifyDN flag is set to true then the distribution should be configured with a global index catalog because when entries are "moved" the distribution algorithm might not be able to locate them properly.
Default Value
false
Allowed Values
true
false
Multi-valued
No
Required
No
None
Advanced Property
Yes
Read-only
No
java-class
Description
Specifies the fully-qualified name of the Java class that provides the Distribution Workflow Element implementation.
Default Value
com.sun.dps.server.workflowelement.distribution.DistributionWorkflowElement
Allowed Values
A java class that implements or extends the class(es) :
org.opends.server.workflowelement.WorkflowElement
Multi-valued
No
Required
Yes
None
Advanced Property
Yes
Read-only
No
