The Global Index Replication Changes Local Backend Workflow Element exposes all operations of the Global Index Replication through a Backend interface.
The Global Index Replication Changes Local Backend Workflow Element provides an LDAP access to browse the replication changes of all Global Index Catalogs of an instance.
The Global Index Replication Changes Local Backend Workflow Element component inherits from the Local Backend Workflow Element
A description of each property follows.
Basic Properties: | Advanced Properties: |
↓ base-dn | ↓ java-class |
↓ enabled |
Description | Specifies the base DN(s) for the data that the backend handles. A single backend may be responsible for one or more base DNs. Note that no two backends may have the same base DN although one backend may have a base DN that is below a base DN provided by another backend. If any of the base DNs is subordinate to a base DN for another backend, then all base DNs for that backend must be subordinate to that same base DN. |
Default Value | None |
Allowed Values | A valid DN. |
Multi-valued | Yes |
Required | Yes |
Admin Action Required | None. No administrative action is required by default although some action may be required on a per-backend basis before the new base DN may be used. |
Advanced Property | No |
Read-only | No |
Description | Indicates whether the Workflow Element is enabled for use in the server. If a Workflow Element is not enabled, then its contents are not accessible when processing operations. |
Allowed Values | true false |
Multi-valued | No |
Required | Yes |
Admin Action Required | None |
Read-only | No |
Description | Specifies the fully-qualified name of the Java class that provides the Global Index Replication Changes Local Backend Workflow Element implementation. |
Default Value | com.sun.dps.server.globalindex.debug.GlobalIndexReplicationChangesBackend |
Allowed Values | A java class that implements or extends the class(es) : org.opends.server.workflowelement.WorkflowElement |
Multi-valued | No |
Required | Yes |
Advanced Property | Yes |
Read-only | No |
