Configuration Reference Home
Oracle Unified Directory - Load Balancing Workflow Element
The Load Balancing Workflow Element is used route requests to a set of routes.
The Load Balancing Workflow Element is used route requests to a set of routes. From the load balancing workflow element perspective, a route is a workflow element. Whether the route is a Proxy LDAP workflow element, or another load balancing workflow element, or a workflow element of any type does not matter.
Parent Component
The Load Balancing Workflow Element component inherits from the Workflow Element
Relations From this Component
The following components have a direct COMPOSITION relation FROM Load Balancing Workflow Elements :
Properties
A description of each property follows.
Basic Properties: Advanced Properties:
↓ enabled ↓ java-class
Basic Properties
enabled
Description
Indicates whether the Workflow Element is enabled for use in the server. If a Workflow Element is not enabled, then its contents are not accessible when processing operations.
Default Value
None
Allowed Values
true
false
Multi-valued
No
Required
Yes
Admin Action Required
None
Advanced Property
No
Read-only
No
Advanced Properties
java-class
Description
Specifies the fully-qualified name of the Java class that provides the Load Balancing Workflow Element implementation.
Default Value
com.sun.dps.server.workflowelement.loadbalancing.LoadBalancingWorkflowElement
Allowed Values
A java class that implements or extends the class(es) :
org.opends.server.workflowelement.WorkflowElement
Multi-valued
No
Required
Yes
None
Advanced Property
Yes
Read-only
No
