Configuration Reference Home
Oracle Unified Directory - Saturation Load Balancing Algorithm
The Saturation Load Balancing Algorithm is a load balancing algorithm based on the saturation.
A saturation load balancing algorithm distributes the requests to its routes according to the route priority and the route saturation level. The saturation level is a percentage expressing the saturation of the route. A value of 0 indicates the route is fully operational while a value of 100 shows the route as DOWN. The route with the highest priority and with a saturation level below its saturation threshold is elected to handle the request. When all the routes are saturated (i.e. all the routes have a current saturation level above or equal to their saturation threshold), the route with the lowest saturation level is choosen.
Parent Component
The Saturation Load Balancing Algorithm component inherits from the Load Balancing Algorithm
Properties
A description of each property follows.
Basic Properties: Advanced Properties:
 None ↓ java-class
Advanced Properties
java-class
Description
Specifies the fully-qualified name of the Java class that provides the Saturation Load Balancing Algorithm implementation.
Default Value
com.sun.dps.server.workflowelement.loadbalancing.SaturationLoadBalancingAlgorithm
Allowed Values
A java class that implements or extends the class(es) :
com.sun.dps.server.workflowelement.loadbalancing.AbstractLoadBalancingAlgorithm
Multi-valued
No
Required
Yes
Admin Action Required
None
Advanced Property
Yes
Read-only
No
