Oracle Unified Directory - Soft Reference Entry Cache
The Soft Reference Entry Cache is a Directory Server entry cache implementation that uses soft references to manage objects to allow them to be freed if the JVM is running low on memory.
Parent Component
The Soft Reference Entry Cache component inherits from the Entry Cache
Properties
A description of each property follows.
Basic Properties
cache-level
Description Specifies the cache level in the cache order if more than one instance of the cache is configured.
Default Value None
Allowed Values An integer value. Lower value is 1.
Multi-valued No
Required Yes
Admin Action Required None
Advanced Property No
Read-only No
enabled
Description Indicates whether the Entry Cache is enabled.
Default Value None
Allowed Values true
false
Multi-valued No
Required Yes
Read-only No
exclude-filter
Description The set of filters that define the entries that should be excluded from the cache.
Default Value None
Allowed Values A String
Multi-valued Yes
Required No
Read-only No
include-filter
Description The set of filters that define the entries that should be included in the cache.
Default Value None
Multi-valued Yes
Required No
Read-only No
Advanced Properties
java-class
Description Specifies the fully-qualified name of the Java class that provides the Soft Reference Entry Cache implementation.
Default Value org.opends.server.extensions.SoftReferenceEntryCache
Allowed Values A java class that implements or extends the class(es) :
org.opends.server.api.EntryCache
Multi-valued No
Required Yes
Admin Action Required The Soft Reference Entry Cache must be disabled and re-enabled for changes to this setting to take effect
Advanced Property Yes
Read-only No
lock-timeout
Description Specifies the length of time in milliseconds to wait while attempting to acquire a read or write lock.
Default Value 3000ms
Allowed Values A duration Syntax . A value of "-1" or "unlimited" for no limit. Lower limit is 0 milliseconds.
Multi-valued No
Required No
Read-only No
