Go to main content
Sun Server X3-2 (formerly Sun Fire X4170 M3) Product Notes Version 1.7
Exit Print View
Updated: April 2017
Inspect Grounding Strap on 3.5-inch HDD Bracket Before Installing
The 3.5-inch hard disk drive (HDD) bracket that is used in the Sun Server X3-2 incorporates a spring-loaded metal grounding strap, which is located on the right side of the HDD bracket. A deflection in the grounding strap can cause the strap to catch on the server disk cage, which can further damage the grounding strap. Once damaged, the grounding strap cannot be repaired and the HDD bracket must be replaced.
Before installing a 3.5-inch HDD into your system, visually inspect the grounding strap to ensure that the end of the strap is seated correctly in the HDD bracket. See the following figure for an example of a grounding strap that is seated correctly.
Figure 1  Grounding Strap Seated Correctly in the HDD Bracket
image:Figure showing a grounding strap that is seated correctly in the HDD bracket.
If the grounding strap is not seated correctly, or is protruding past the outer edge of the HDD bracket, the HDD bracket should be replaced. See the following figure for an example of a grounding strap that is not seated correctly.
Figure 2  Grounding Strap Not Seated Correctly in the HDD Bracket
image:Figure showing a grounding strap that is not seated correctly in the HDD bracket.
