| Skip Navigation Links | |
| Exit Print View | |
Sun Server X3-2 (formerly Sun Fire X4170 M3) Product Notes, Version 1.2 |
Getting the Latest Software and Firmware
Single-Processor to Dual-Processor Upgrade Is Not Supported
Update Your System to the Latest Software Release
Avoid Overwriting the Embedded Oracle System Assistant USB Flash Drive
Oracle Solaris 10 8/11 Required Patches
Preinstalled Oracle VM Server and Oracle VM Manager Compatibility Requirements
Supported Operating System Limitations
Segfaults Might Occur on Servers Running 64-bit Linux Operating Systems
Failure of a Single Server Fan Module Might Impact Performance
Standby Over-temperature Protection
MAC Address Mapping to Ethernet Ports
Inspect Grounding Strap on 3.5-inch HDD Bracket Before Installing
Issues Resolved in This Software Release
Issues Resolved in Previous Software Releases
Oracle Solaris Operating System Known Issues
Linux Operating Systems and Virtual Machine Known Issues
Oracle System Assistant Known Issues
Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
You might need to update the firmware on your Sun Storage 6 Gb SAS PCIe HBA Internal (SGX-SAS6-INT-Z), Sun Storage 6 Gb SAS PCIe HBA External (SGX-SAS6-EXT-Z), or Sun Storage 6 Gb SAS PCIe RAID HBA Internal (SGX-SAS6-R-INT-Z) card to support the Unified Extensible Firmware Interface (UEFI) BIOS if you are not using a card that was shipped with your system. You might need to update your HBA firmware if:
You receive a replacement card for a faulty HBA.
You order an HBA separately from your system.
You want to use an HBA that you already own.
You can use Oracle System Assistant or Oracle Hardware Management Pack to update your HBA firmware. For information on updating HBA firmware using Oracle System Assistant, see “Update Firmware” in the Sun Server X3-2 Administration Guide. For information on updating HBA firmware using Oracle Hardware Management Pack, see “Set Up Software and Firmware Using Oracle Hardware Management Pack” in the Sun Server X3-2 Administration Guide.
Note - Alternatively, you can configure your system to use Legacy BIOS. For information, see “Selecting Legacy BIOS or UEFI Boot Mode” in the Sun Server X3-2 Administration Guide.
