Skip Navigation Links
Exit Print View
Sun Server X3-2 (formerly Sun Fire X4170 M3)
Product Notes, Version 1.2.1
search filter icon
search icon
Document Information
Using This Documentation
Getting the Latest Software and Firmware
About This Documentation
Related Documentation
Feedback
Support and Accessibility
Sun Server X3-2 Product Notes
Sun Server X3-2 Name Change
Supported Hardware
Supported Firmware Versions
Supported Operating Systems
Important Operating Notes
Operational Changes for UEFI BIOS Configuration
Single-Processor to Dual-Processor Upgrade Is Not Supported
Update Your System to the Latest Software Release
Avoid Overwriting the Embedded Oracle System Assistant USB Flash Drive
Oracle Solaris 10 8/11 Required Patches
Preinstalled Oracle VM Server and Oracle VM Manager Compatibility Requirements
Supported Operating System Limitations
Update HBA Firmware to Support UEFI BIOS
Segfaults Might Occur on Servers Running 64-bit Linux Operating Systems
Failure of a Single Server Fan Module Might Impact Performance
Standby Over-temperature Protection
MAC Address Mapping to Ethernet Ports
Inspect Grounding Strap on 3.5-inch HDD Bracket Before Installing
Battery Module
Server Management Tools
Supported PCIe Cards
Resolved Issues
Resolved Issue for This Software Release
Resolved Issues for Previous Software Releases
Known Issues
Hardware Known Issues
Oracle Solaris Operating System Known Issues
Linux Operating Systems and Virtual Machine Known Issues
Oracle System Assistant Known Issues
Documentation Known Issues
Software Release 1.2.1 Documentation Incorrectly Implies Ability to Set RAID Volume as Global Hot Spare
Cautions Statements Added to the Sun Server X3-2 Service Manual
Correction to the Version of the Oracle VM Server Software Preinstalled on the Server
Note Changed to Caution Statement in the Sun Server X3-2 Installation Guide for Oracle VM
Corrections to the Sun Server X3-2 Installation Guide for Linux Operating Systems
Incorrect Layout of the Sun Server X3-2 Front Panel Controls and Indicators Documented in the Sun Server X3-2 Installation Guide and the Sun Server X3-2 Service Manual
Sun Server X3-2 Installation Guide Updated to Include Configuration Instructions for the Oracle Linux Operating System Preinstalled on the Server
Sun Server X3-2 Service Manual Updated to Include URLs to the Sun Server X3-2 Service Animations
Operating Altitude Limits for China Markets
Translated Documents Use Abbreviated Titles
Incorrect Server Name in the Printed Getting Started Guide
Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
In the translated versions of the PDF documents, the document titles used in cross-references are abbreviated. The abbreviated titles correspond to the complete document titles listed in the table that follows.
Table 12 Complete Document Titles
Abbreviated Document Title
Site Planning
Sun Server X3-2 Site Planning Guide
Installation
Oracle Solaris Installation
Sun Server X3-2 Installation Guide for the Oracle Solaris Operating System
Oracle VM Installation
Linux Installation
Sun Server X3-2 Server Installation Guide for Linux Operating Systems
Windows Installation
Sun Server X3-2 Installation Guide for Windows Operating Systems
VMware ESXi Installation
Sun Server X3-2 Installation Guide for VMware ESXi
Service
Administration
Sun Server X3-2 Administration Guide
