| Skip Navigation Links | |
| Exit Print View | |
Sun Server X3-2 (formerly Sun Fire X4170 M3) Product Notes, Version 1.2 |
Getting the Latest Software and Firmware
Single-Processor to Dual-Processor Upgrade Is Not Supported
Update Your System to the Latest Software Release
Avoid Overwriting the Embedded Oracle System Assistant USB Flash Drive
Oracle Solaris 10 8/11 Required Patches
Preinstalled Oracle VM Server and Oracle VM Manager Compatibility Requirements
Supported Operating System Limitations
Update HBA Firmware to Support UEFI BIOS
Segfaults Might Occur on Servers Running 64-bit Linux Operating Systems
Standby Over-temperature Protection
MAC Address Mapping to Ethernet Ports
Inspect Grounding Strap on 3.5-inch HDD Bracket Before Installing
Issues Resolved in This Software Release
Issues Resolved in Previous Software Releases
Oracle Solaris Operating System Known Issues
Linux Operating Systems and Virtual Machine Known Issues
Oracle System Assistant Known Issues
Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
