| Skip Navigation Links | |
| Exit Print View | |
Sun Server X3-2 (formerly Sun Fire X4170 M3) Product Notes, Version 1.2 |
Getting the Latest Software and Firmware
Single-Processor to Dual-Processor Upgrade Is Not Supported
Avoid Overwriting the Embedded Oracle System Assistant USB Flash Drive
Oracle Solaris 10 8/11 Required Patches
Preinstalled Oracle VM Server and Oracle VM Manager Compatibility Requirements
Supported Operating System Limitations
Update HBA Firmware to Support UEFI BIOS
Segfaults Might Occur on Servers Running 64-bit Linux Operating Systems
Failure of a Single Server Fan Module Might Impact Performance
Standby Over-temperature Protection
MAC Address Mapping to Ethernet Ports
Inspect Grounding Strap on 3.5-inch HDD Bracket Before Installing
Issues Resolved in This Software Release
Issues Resolved in Previous Software Releases
Oracle Solaris Operating System Known Issues
Linux Operating Systems and Virtual Machine Known Issues
Oracle System Assistant Known Issues
Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
It is highly recommended that you update your system to the latest software release before you use the system. Software releases often include bug fixes, and updating ensures that your server software is compatible with the latest server firmware and other component firmware and software.
You can get the latest available system BIOS, Oracle Integrated Lights Out Manager (ILOM), firmware, and drivers from Oracle by performing the Get Updates task in Oracle System Assistant. An Internet connection is required. For instructions on how to use the Get Updates task, see “Get Updates for a New Platform Software Release” in the Sun Server X3-2 Administration Guide.
You can also download the latest firmware and software updates from My Oracle Support at http://support.oracle.com. For information about downloading firmware and software from My Oracle Support, see .
